Incorrect flash usage report
I'm having an issue with flash usage reporting when building app. I'm using MCUBoot, so 2 images are generated.
First of all, my definition of partitions in an overlay file is the following (Original board is arduino nicla sense me).
I'm defining just slot0_partition as I will only update fw in serial recovery mode.
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x0 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0xc000 0x6e000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x7a000 0x6000>;
When I build the code, I receive these 2 memory usage reports:
           FLASH:       35288 B        48 KB     71.79%
            SRAM:       24800 B        64 KB     37.84%
        IDT_LIST:          0 GB         2 KB      0.00%
First one has sense and I suppose it corresponds to MCUboot, as 48KB is exactly 0xc000.
           FLASH:      186104 B     232960 B     79.89%
            SRAM:       63497 B        64 KB     96.89%
However, in the second one I can not understand the source of 232960 B region size. Shouldn't be 440KB (0x6e000)??
I also tried splitting into slot0 and slot1 but 232960 B region size keeps unmodified.
Thanks and best regards,
Pedro.
  • Hi Pedro,
    When you enable MCUBoot, Partition Manager will also be used and the overlay dts partition will not be used. Instead, you will find a file called partitions.yml  in the build folder which is the actual partition used.
    You will have something like this:
    app:
      address: 0xc200
      end_address: 0x46000
      region: flash_primary
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
      placement:
        align:
          start: 0x1000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - mcuboot_pad
      - app
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0xc200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x46000
      end_address: 0x80000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
        align_next: 0x1000
      share_size:
      - mcuboot_primary
    sram_primary:
      address: 0x20000000
      end_address: 0x20010000
      region: sram_primary
    You can see the mcuboot_primary_app size will be 0x39e00 or 0x38E00 .
    By default the MCUBoot will configure the main flash into two partitions : primary and secondary. This is to support dual bank DFU update.
    I'm not sure if there is a way to disable this, but one work around is to copy the file partitions.yml and call it pm_static.yml. Put it to the root folder of the project and then modify the mcuboot_primary and mcuboot_secondary to make the size of mcuboot_primary  cover the whole flash and mcuboot_secondary  has zero size.
  • Hi Hung,
    Thank you for your answer. I've deleted partitions definition in overlay dts and used pm_static.yml instead and it works.
    I have a question about different sections of this file, because for me it seems to be redundant information.
    What are the differences between app, mcuboot_primary and mcuboot_primary_app sections? I changed addresses and size in the 3, but I also noticed changing just mcuboot_primary also works (Seems to be ignoring app and mcuboot_primary_app).
    Why there is mcuboot_secondary but no mcuboot_secondary_app?
    Pedro.
  • Hi Pedro,
    As far as I know, MCUBoot expects two partititions, mcuboot_primary and mcuboot_secondary.
    mcuboot_primary contains the mcuboot_primary_app (where the application located) and the mcuboot_pad (where the padding is)
    The app partition could be a redundancy here because it would be identical to the mcuboot_primary_app.
     There is no point of having mcuboot_secondary_app because the app is not executed at the secondary lot. And padding not needed. It's simply the place where the new image is copied to.
