BSP_EVENT sending characters continuously.
hi team,
working environment: nRF 17.1.0 SDK, NRF 52832 DK, Uvision 5 Keil IDE, Windows 10 pro.
I am trying to send a NRF52832 Key press character to NRF 52840 Via ble_app_uart .
nrf52832 configured as peripheral (ble_app_uart.c)and nrf52840 configred as central(ble_app_uart_c).
here i have attached code at nrf52832 peripheral side, which suppose to send 'a' character on key press, but its sending continuous characters ,aaaaaaaaaaaaa.....
not able to figure out where am i going wrong. Any Suggestions!!!!
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_gpio.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                      /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define KBD_0             4
#define KBD_1             5
#define KBD_2             6
#define KBD_3             7
#define BTN_KBD0_A         0
#define BTN_KBD1_B         1
#define BTN_KBD2_C         2
#define BTN_KBD3_D         3
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
enum {
    BSP_USER_EVENT_RELEASE_0 = BSP_EVENT_KEY_LAST + 1, /**< Button 0 released */
    BSP_USER_EVENT_RELEASE_1,                          /**< Button 1 released */
    BSP_USER_EVENT_RELEASE_2,                          /**< Button 2 released */
    BSP_USER_EVENT_RELEASE_3,                          /**< Button 3 released */
    BSP_USER_EVENT_RELEASE_4,                          /**< Button 4 released */
    BSP_USER_EVENT_RELEASE_5,                          /**< Button 5 released */
    BSP_USER_EVENT_RELEASE_6,                          /**< Button 6 released */
    BSP_USER_EVENT_RELEASE_7,                          /**< Button 7 released */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
	  uint16_t length =(uint16_t)0x01;
    switch ((unsigned int)event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
			  case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD0_A):
            data_array[0]=KBD_0;
					  UNUSED_RETURN_VALUE(ble_nus_data_send(&m_nus, &data_array[0], &length, m_conn_handle));
				case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD0_A):
            data_array[0]=NULL;
					  UNUSED_RETURN_VALUE(ble_nus_data_send(&m_nus, NULL, &length, NULL));
			 /*case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD0_A):
        case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD1_B):
            data_array[1]=KBD_1;*/
			//	NRF_LOG_HEXDUMP_DEBUG(data_array[1], index);
					 // UNUSED_RETURN_VALUE(ble_nus_data_send(&m_nus, &data_array[1], &length, m_conn_handle));
				     //     while (nrf_gpio_pin_read(13)==0);
				       //data_array[1]=NULL;
			         //UNUSED_RETURN_VALUE(ble_nus_data_send(&m_nus, &data_array[1], &length, m_conn_handle));
           // break;
			/*	case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD1_B):
        case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD2_C):
            data_array[2]=KBD_2;
					  UNUSED_RETURN_VALUE(ble_nus_data_send(&m_nus, &data_array[2], &length, m_conn_handle));
				case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD2_C):
        case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD3_D):
            data_array[3]=KBD_3;
					  UNUSED_RETURN_VALUE(ble_nus_data_send(&m_nus, &data_array[3], &length, m_conn_handle));
				case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD3_D):
            break;*/
#define INIT_BSP_ASSIGN_RELEASE_ACTION(btn)                      \
    APP_ERROR_CHECK(                                             \
        bsp_event_to_button_action_assign(                       \
            btn,                                                 \
            BSP_BUTTON_ACTION_RELEASE,                           \
            (bsp_event_t)CONCAT_2(BSP_USER_EVENT_RELEASE_, btn)) \
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
  //  uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
           /* if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_BUTTONS|BSP_INIT_LEDS, bsp_event_handler);
    //err_code = bsp_btn_ble_init(NULL, &startup_event);
    //APP_ERROR_CHECK(err_code);
    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD0_A);
    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD1_B);
    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD2_C);
    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD3_D);
	   //bsp_board_init(BSP_INIT_LEDS);
static void log_init(void)
        nrf_pwr_mgmt_run();
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
Kind Regards,
Deepthi
  • hi team ,
    here i am with attaching receiver side code at NRF52840.
     * Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "app_error.h"
    #include "ble_db_discovery.h"
    #include "app_util.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_scan.h"
    #include <stddef.h>
    #include "nrf.h"
    #include "nrf_drv_usbd.h"
    #include "nrf_drv_clock.h"
    #include "nrf_delay.h"
    #include "nrf_drv_power.h"
    #include "app_usbd.h"
    #include "app_usbd_core.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_audio.h"
    #include "boards.h"
    #include "app_usbd_hid_mouse.h"
    #include "app_usbd_hid_kbd.h"
    #include "app_usbd_dummy.h"
    #include "bsp.h"
    #include "bsp_cli.h"
    #include "nrf_cli.h"
    //#include "nrf_cli_uart.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
                   NRF_SDH_BLE_CENTRAL_LINK_COUNT,
                   NRF_BLE_GQ_QUEUE_SIZE);
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief NUS UUID. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    /**@brief Function for handling asserts in the SoftDevice.
     * @details This function is called in case of an assert in the SoftDevice.
     * @warning This handler is only an example and is not meant for the final product. You need to analyze
     *          how your product is supposed to react in case of assert.
     * @param[in] line_num     Line number of the failing assert call.
     * @param[in] p_file_name  File name of the failing assert call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling the Nordic UART Service Client errors.
    static void nus_error_handler(uint32_t nrf_error)
    #define BUFFER_SIZE  (48)
     * @brief Enable power USB detection
     * Configure if example supports USB port connection
    #ifndef USBD_POWER_DETECTION
    #define USBD_POWER_DETECTION true
     * @brief Enable HID mouse class
    #define CONFIG_HAS_MOUSE    1
     * @brief Enable HID keyboard class
    #define CONFIG_HAS_KBD      1
     * @brief Mouse button count
    #define CONFIG_MOUSE_BUTTON_COUNT 2
     * @brief Mouse speed (value sent via HID when board button is pressed).
    #define CONFIG_MOUSE_MOVE_STEP (3)
     * @brief Mouse move repeat time in milliseconds
    #define CONFIG_MOUSE_MOVE_TIME_MS (5)
     * @brief Letter to be sent on LETTER button
     * @sa BTN_KBD_LETTER
    //#define CONFIG_KBD_LETTER APP_USBD_HID_KBD_G
     * @brief Propagate SET_PROTOCOL command to other HID instance
    #define PROPAGATE_PROTOCOL  0
    /*#define BTN_MOUSE_X_POS    0
    #define BTN_MOUSE_LEFT     1
    #define BTN_KBD_SHIFT      2
    #define BTN_KBD_LETTER     3
    enum {
    #define APP_USBD_INTERFACE_MOUSE 0
    #define APP_USBD_INTERFACE_KBD   1
    static void hid_mouse_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                          app_usbd_hid_user_event_t event);
     //@brief User event handler, HID keyboard
    static void hid_kbd_user_ev_handler(app_usbd_class_inst_t const * p_inst,
    APP_USBD_HID_MOUSE_GLOBAL_DEF(m_app_hid_mouse,
                                  APP_USBD_INTERFACE_MOUSE,
                                  NRF_DRV_USBD_EPIN1,
                                  CONFIG_MOUSE_BUTTON_COUNT,
                                  hid_mouse_user_ev_handler,
                                  APP_USBD_HID_SUBCLASS_BOOT
    //APP_USBD_DUMMY_GLOBAL_DEF(m_app_mouse_dummy, APP_USBD_INTERFACE_MOUSE);
     * @brief Global HID keyboard instance
    APP_USBD_HID_KBD_GLOBAL_DEF(m_app_hid_kbd,
                                APP_USBD_INTERFACE_KBD,
                                NRF_DRV_USBD_EPIN2,
                                hid_kbd_user_ev_handler,
    APP_USBD_DUMMY_GLOBAL_DEF(m_app_kbd_dummy, APP_USBD_INTERFACE_KBD);
    APP_TIMER_DEF(m_mouse_move_timer);
    static void kbd_status(void)
        if(app_usbd_hid_kbd_led_state_get(&m_app_hid_kbd, APP_USBD_HID_KBD_LED_NUM_LOCK))
           // bsp_board_led_on(LED_NUMLOCK);
         //  bsp_board_led_off(LED_NUMLOCK);
        if(app_usbd_hid_kbd_led_state_get(&m_app_hid_kbd, APP_USBD_HID_KBD_LED_CAPS_LOCK))
           // bsp_board_led_on(LED_CAPSLOCK);
            //bsp_board_led_off(LED_CAPSLOCK);
     * @brief Class specific event handler.
     * @param p_inst    Class instance.
     * @param event     Class specific event.
        UNUSED_PARAMETER(p_inst);
        switch (event) {
            case APP_USBD_HID_USER_EVT_OUT_REPORT_READY:
                /* No output report defined for HID mouse.*/
                ASSERT(0);
            case APP_USBD_HID_USER_EVT_IN_REPORT_DONE:
                //bsp_board_led_invert(LED_HID_REP);
            case APP_USBD_HID_USER_EVT_SET_BOOT_PROTO:
                UNUSED_RETURN_VALUE(hid_mouse_clear_buffer(p_inst));
    #if PROPAGATE_PROTOCOL
                hid_kbd_on_set_protocol(&m_app_hid_kbd, APP_USBD_HID_USER_EVT_SET_BOOT_PROTO);
            case APP_USBD_HID_USER_EVT_SET_REPORT_PROTO:
                hid_kbd_on_set_protocol(&m_app_hid_kbd, APP_USBD_HID_USER_EVT_SET_REPORT_PROTO);
        switch (event) {
                /* Only one output report IS defined for HID keyboard class. Update LEDs state. */
               // bsp_board_led_invert(LED_HID_REP);
                kbd_status();
                UNUSED_RETURN_VALUE(hid_kbd_clear_buffer(p_inst));
                hid_mouse_on_set_protocol(&m_app_hid_mouse, APP_USBD_HID_USER_EVT_SET_BOOT_PROTO);
                hid_mouse_on_set_protocol(&m_app_hid_mouse, APP_USBD_HID_USER_EVT_SET_REPORT_PROTO);
    static void mic_audio_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                          app_usbd_audio_user_event_t   event);
    #define MIC_TERMINAL_CH_CONFIG()        \
            (APP_USBD_AUDIO_IN_TERM_CH_CONFIG_LEFT_FRONT | APP_USBD_AUDIO_IN_TERM_CH_CONFIG_RIGHT_FRONT)
    #define MIC_FEATURE_CONTROLS()        \
            APP_USBD_U16_TO_RAW_DSC(APP_USBD_AUDIO_FEATURE_UNIT_CONTROL_MUTE),                         \
    APP_USBD_AUDIO_FORMAT_DESCRIPTOR(m_mic_form_desc,
                                     APP_USBD_AUDIO_AS_FORMAT_I_DSC(    /* Format type 1 descriptor */
                                        2,                              /* Number of channels */
                                        2,                              /* Subframe size */
                                        16,                             /* Bit resolution */
                                        1,                              /* Frequency type */
                                        APP_USBD_U24_TO_RAW_DSC(48000)) /* Frequency */
    APP_USBD_AUDIO_INPUT_DESCRIPTOR(m_mic_inp_desc,
                                    APP_USBD_AUDIO_INPUT_TERMINAL_DSC(
                                        1,                                     /* Terminal ID */
                                        APP_USBD_AUDIO_TERMINAL_IN_MICROPHONE, /* Terminal type */
                                        MIC_TERMINAL_CH_CONFIG())              /* Channels config */
    APP_USBD_AUDIO_OUTPUT_DESCRIPTOR(m_mic_out_desc,
                                     APP_USBD_AUDIO_OUTPUT_TERMINAL_DSC(
                                        3,                                     /* Terminal ID */
                                        APP_USBD_AUDIO_TERMINAL_USB_STREAMING, /* Terminal type */
                                        2)                                     /* Source ID */
    APP_USBD_AUDIO_FEATURE_DESCRIPTOR(m_mic_fea_desc,
                                      APP_USBD_AUDIO_FEATURE_UNIT_DSC(
                                        2,                      /* Unit ID */
                                        1,                      /* Source ID */
                                        MIC_FEATURE_CONTROLS()) /* List of controls */
    #define MIC_INTERFACES_CONFIG() APP_USBD_AUDIO_CONFIG_IN(2, 3)
    APP_USBD_AUDIO_GLOBAL_DEF(m_app_audio_microphone,
                              MIC_INTERFACES_CONFIG(),
                              mic_audio_user_ev_handler,
                              &m_mic_form_desc,
                              &m_mic_inp_desc,
                              &m_mic_out_desc,
                              &m_mic_fea_desc,
                              0,
                              APP_USBD_AUDIO_AS_IFACE_FORMAT_PCM,
                              192,
                              APP_USBD_AUDIO_SUBCLASS_AUDIOSTREAMING,
                              3);
    static int16_t  m_temp_buffer[2 * BUFFER_SIZE];
    static size_t m_temp_buffer_size;
    static uint8_t  m_mute_mic;
     * @brief Actual microphone sampling frequency
    static uint32_t m_freq_mic;
    static void mic_audio_user_class_req(app_usbd_class_inst_t const * p_inst)
        app_usbd_audio_t const * p_audio = app_usbd_audio_class_get(p_inst);
        app_usbd_audio_req_t * p_req = app_usbd_audio_class_request_get(p_audio);
        UNUSED_VARIABLE(m_mute_mic);
        UNUSED_VARIABLE(m_freq_mic);
        switch (p_req->req_target)
            case APP_USBD_AUDIO_CLASS_REQ_IN:
                if (p_req->req_type == APP_USBD_AUDIO_REQ_SET_CUR)
                    //Only mute control is defined
                    p_req->payload[0] = m_mute_mic;
            case APP_USBD_AUDIO_CLASS_REQ_OUT:
                    m_mute_mic = p_req->payload[0];
            case APP_USBD_AUDIO_EP_REQ_IN:
            case APP_USBD_AUDIO_EP_REQ_OUT:
                    //Only set frequency is supported
                    m_freq_mic = uint24_decode(p_req->payload);
        UNUSED_VARIABLE(p_audio);
        switch (event)
            case APP_USBD_AUDIO_USER_EVT_CLASS_REQ:
                mic_audio_user_class_req(p_inst);
            case APP_USBD_AUDIO_USER_EVT_TX_DONE:
                //bsp_board_led_invert(LED_AUDIO_TX);
    static void usbd_user_ev_handler(app_usbd_event_type_t event)
        switch (event)
            case APP_USBD_EVT_DRV_SOF:
            case APP_USBD_EVT_DRV_SUSPEND:
    					  app_usbd_suspend_req();
               // bsp_board_leds_off();
            case APP_USBD_EVT_DRV_RESUME:
               // bsp_board_led_on(LED_USB_START);
    				    kbd_status();
            case APP_USBD_EVT_STARTED:
            case APP_USBD_EVT_STOPPED:
                app_usbd_disable();
                //bsp_board_leds_off();
            case APP_USBD_EVT_POWER_DETECTED:
                NRF_LOG_INFO("USB power detected");
                if (!nrf_drv_usbd_is_enabled())
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                NRF_LOG_INFO("USB power removed");
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                NRF_LOG_INFO("USB ready");
                app_usbd_start();
    static void mouse_move_timer_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        UNUSED_RETURN_VALUE(app_usbd_hid_mouse_x_move(&m_app_hid_mouse, CONFIG_MOUSE_MOVE_STEP));
    /*static void bsp_event_callback(bsp_event_t ev)
        switch ((unsigned int)ev)
            case CONCAT_2(BSP_EVENT_KEY_, BTN_MOUSE_X_POS):
                UNUSED_RETURN_VALUE(app_timer_start(m_mouse_move_timer, APP_TIMER_TICKS(CONFIG_MOUSE_MOVE_TIME_MS), NULL));
            case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_MOUSE_X_POS):
                UNUSED_RETURN_VALUE(app_timer_stop(m_mouse_move_timer));
            case CONCAT_2(BSP_EVENT_KEY_, BTN_MOUSE_LEFT):
                UNUSED_RETURN_VALUE(app_usbd_hid_mouse_button_state(&m_app_hid_mouse, 0, true));
            case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_MOUSE_LEFT):
                UNUSED_RETURN_VALUE(app_usbd_hid_mouse_button_state(&m_app_hid_mouse, 0, false));
            case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD_SHIFT):
                UNUSED_RETURN_VALUE(app_usbd_hid_kbd_modifier_state_set(&m_app_hid_kbd, APP_USBD_HID_KBD_MODIFIER_LEFT_SHIFT, true));
            case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD_SHIFT):
                UNUSED_RETURN_VALUE(app_usbd_hid_kbd_modifier_state_set(&m_app_hid_kbd, APP_USBD_HID_KBD_MODIFIER_LEFT_SHIFT, false));
            case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD_LETTER):
                UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, CONFIG_KBD_LETTER, true));
            case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD_LETTER):
                UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, CONFIG_KBD_LETTER, false));
                return; // no implementation needed
    /*#define INIT_BSP_ASSIGN_RELEASE_ACTION(btn)                      \
        APP_ERROR_CHECK(                                             \
                btn,                                                 \
    //static void init_bsp(void)
      //  ret_code_t ret;
        //ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
        //APP_ERROR_CHECK(ret);
       // INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_MOUSE_X_POS);
        //INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_MOUSE_LEFT );
        //INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD_SHIFT  );
        //INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD_LETTER );
    	 /* Configure LEDs */
    /**@brief Function to start scanning. */
    static void scan_start(void)
        ret_code_t ret;
        ret = nrf_ble_scan_start(&m_scan);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                  ble_gap_evt_connected_t const * p_connected =
                                   p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                 NRF_LOG_INFO("Scan timed out.");
                 scan_start();
             } break;
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    /**@brief Function for handling database discovery events.
     * @details This function is a callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function forwards the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t *p_data, uint16_t data_len)
        ret_code_t ret_val;
       /* NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
    		ret_val = app_uart_put(p_data[0]);
    		//app_usbd_hid_kbd_codes_t key = p_data[0];
    		app_usbd_hid_kbd_key_control(&m_app_hid_kbd, p_data[0] , true);
        /*if (ECHOBACK_BLE_UART_DATA)
            // Send data back to the peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
     * @details This function receives a single character from the app_uart module and appends it to
     *          a string. The string is sent over BLE when the last character received is a
     *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
        static uint16_t index = 0;
        uint32_t ret_val;
            /**@snippet [Handling data from UART] */
                index++;
                    (index >= (m_ble_nus_max_data_len)))
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                    } while (ret_val == NRF_ERROR_RESOURCES);
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling Nordic UART Service (NUS) client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
     * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
     * @brief Function for handling shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->conn_handle,
                             p_gap_evt->params.disconnected.reason);
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                // Pairing not supported.
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        switch (event)
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
                err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    			/*  case CONCAT_2(BSP_EVENT_KEY_, BTN_MOUSE_X_POS):
    /**@brief Function for initializing the UART. */
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler   = ble_nus_c_evt_handler;
        init.error_handler = nus_error_handler;
        init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    	 // err_code = bsp_btn_ble_init(NULL, &startup_event);
    	  //bsp_board_init(BSP_INIT_BUTTONS);
    	//bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS)
    	 // ret_code_t ret;
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    /** @brief Function for initializing the database discovery module. */
    static void db_discovery_init(void)
        ble_db_discovery_init_t db_init;
        memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
        db_init.evt_handler  = db_disc_handler;
        db_init.p_gatt_queue = &m_ble_gatt_queue;
        ret_code_t err_code = ble_db_discovery_init(&db_init);
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_state_proc = usbd_user_ev_handler,
            .enable_sof = true
        // Initialize.
        log_init();
    		timer_init();
    		ret = app_timer_create(&m_mouse_move_timer, APP_TIMER_MODE_REPEATED, mouse_move_timer_handler);
    		buttons_leds_init();
    		uart_init();
    		ret = nrf_drv_clock_init();
        while(!nrf_drv_clock_lfclk_is_running())
            /* Just waiting */
    		printf("USBD audio example started.\r\n");
    		NRF_LOG_INFO("USBD audio example started.");
    		ret = app_usbd_init(&usbd_config);
    		app_usbd_class_inst_t const * class_inst_mic =
            app_usbd_audio_class_inst_get(&m_app_audio_microphone);
        ret = app_usbd_class_append(class_inst_mic);
    		app_usbd_class_inst_t const * class_inst_mouse;
    #if CONFIG_HAS_MOUSE
        class_inst_mouse = app_usbd_hid_mouse_class_inst_get(&m_app_hid_mouse);
    #else
        class_inst_mouse = app_usbd_dummy_class_inst_get(&m_app_mouse_dummy);
        ret = app_usbd_class_append(class_inst_mouse);
    		 app_usbd_class_inst_t const * class_inst_kbd;
    #if CONFIG_HAS_KBD
        class_inst_kbd = app_usbd_hid_kbd_class_inst_get(&m_app_hid_kbd);
    #else
        class_inst_kbd = app_usbd_dummy_class_inst_get(&m_app_kbd_dummy);
        ret = app_usbd_class_append(class_inst_kbd);
        NRF_LOG_INFO("USBD HID composite example started.");
    		//init_bsp();
        db_discovery_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        scan_init();
        /* Start execution.
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
        //Enter main loop.
        for (;;)
        // Initialize LEDs and buttons
        //bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
       // app_usbd_class_inst_t const * class_inst_hp =
          //  app_usbd_audio_class_inst_get(&m_app_audio_headphone);
       // ret = app_usbd_audio_sof_interrupt_register(class_inst_hp, hp_sof_ev_handler);
      //  APP_ERROR_CHECK(ret);
       // ret = app_usbd_class_append(class_inst_hp);
    #else
    #if CONFIG_HAS_KBD
    #else
        scan_start();
        if (USBD_POWER_DETECTION)
            ret = app_usbd_power_events_enable();
            NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
            app_usbd_enable();
            app_usbd_start();
        //Enter main loop.
        for (;;)
    			 while (app_usbd_event_queue_process())
                /* Nothing to do */
    				//UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    received characters are sent via HID interface .
  • I will try to use your main.c file and try to replicate the issue tomorrow. Thanks for your patience.
  • hi Susheel,
    Thank you for the consideration.
    I  resolved the issue.
    At receiver side (NRF52840) correction helped me to resolve the issue.
    Kind Regards,
    Deepthi
