How to use Zigbee and Thread for multi-protocol.
At the following URL,
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_multiprotocol_support.html
In "The Thread and Zigbee protocols support running another protocol in parallel.", does "another protocol" refer to BLE?
So, as with the following question.
 Concuurent Multiprotocol Communication (BLE ,Zigbee,Thread)
Is Zigbee+Thread still not possible today, and only Zigbee+BLE or Thread+BLE combinations can be run simultaneously?
Is it possible to combine two protocols into one firmware unless Zigbee and Thread are running at the same time?
It is a solution to switch between Zigbee and Thread by giving some kind of trigger. (At least, that trigger is not the incoming signal of the respective protocol.)
And can the protocol switching be done within the application? Or do I have to start from boot when making that switch?
Best Regards,
Yukio Oyama
    This is just an update to let you know that our response time might be a bit longer than usual due to the summer vacation period here in Norway, but I will come back with an answer to your questions before the weekend
    Andreas
  • Hi again,
    Yes, this is correct
    It is ZigBee + BLE or Thread + BLE, not (ZigBee + Thread + BLE), so yes the same as mentioned in the older case you linked.
    Yes, it should be possible, but if you are aiming to do so yourself it might be more complicated than simply using the Multi Protocol Support Library already created by us (and which we really recommend you use). It could be a solution to timeslice the use of the radio yourselves, but we do not have any existing samples that illustrates how to do this other than the MPSL
    I think it should be possible to do so within the application if you implement the proper timeslicing algorithms. I believe the main hurdle here is going to be the protocols competing for the use of the radio
    Andreas
  • Hello, Andreas-san,
    Thanks for your answer.
    The meaning of the question
    "And can the protocol switching be done within the application? Or do I have to start from boot when making that switch?"
    is not intended to be so complex that it can be time-sliced to make it appear as if it is running at the same time.
    For example, if what I want to do is a simple operation like switching between Zigbee and Thread every minute, can I simply switch between Zigbee and Thread within one application?
    Or do I have to go back to reboot to switch between the respective protocols?
    Best Regards,
    Yukio Oyama
    I will have to verify this with a colleague of mine working in the ZigBee developer team when they return from vacation (start of August), but in the meanwhile I believe this should be a sufficient reply:
    Normally you can not swap between protocols without any multi protocol support since the chip only has one radio. For 802.15.4 (ZigBee and Thread) and Bluetooth LE you will have to swap which of the protocols that has access to the radio at a given time. Even though both Thread and ZigBee uses the 802.15.4 driver and the 802.15.4 driver supports swapping, I am not 100% sure that this still is possible to do, so I will ask my colleague when they return about this.
    If it is possible, you will most likely have to disable ZigBee and then enable Thread (and the other way around when going back) within the application. This might in theory work, but I don't believe this is a good solution. This will cause that the device disappears from either the Thread or ZigBee network for a indefinete time. Even though it will return, other devices in the Thread or ZigBee network will consider the device as "gone from the network" unless you swap back again quick enough. In addition you will have to start up and initialize the ZigBee/Thread network every time to rejoin the network.
    If you want the user to choose if this is either a Thread or ZigBee device at startup it should work fine, but not if you want to swap every minute due to how it interacts with keep alive procedures and similar.
    I hope this clarifies your question a bit, and I will return with a verification with regards to this within early next week. In the meanwhile, please let me know if you have any additional question regarding this topic!
    Andreas
  • Hello Andreas-san,
    Your response clarifies what I need to understand. Thank you.
    1, Can two protocols be dynamically swapped for one radio?
    Your answer will mention the possibility, but it will become clear when your colleague in charge returns.
    2, After changing protocols and disappearing from the network, when it reverts back to the original protocol, can it be restored with its previous state intact?
    2-1, Network-side issues (this is not a question for you).
    Does the network have a period of time in which it allows devices to disappear and reappear like ghosts?
    2-2, Device issues (this is a question for you)
    Can the device be resurrected with its previous settings retained when it reverts back to the original network?
    This may bother you as I don't know what to keep as a setting myself
    3, When the network refuses to reinstate the device (this is a question for you)
    Can the device run its protocols from initialization?
    Probably, It can initialize and join the network without having to redo the boot, as the device may still lose the network in normal operation. Is this correct?
    Best Regards,
    Yukio Oyama
