I am trying to run the peripheral_uart service example, with the hci_rpmsg on the network core
When the clock configuration (on the main application core) is set as below, I am able to enable the bluetooth, but the connection made with the device is broken almost instantly with error reason 8.
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_SOC_LFXO_CAP_INT_7PF=y
CONFIG_SOC_HFXO_CAP_INTERNAL=y
CONFIG_SOC_HFXO_CAP_INT_VALUE_X2=27
If on the other hand I use the following, I am stuck waiting for bluetooth to be enabled. This setting used to work initially until the board was reset.
CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM=y
Could you please guide me on what I should do to fix either of the above issues?
Maybe nice to know, I am using the nrf 1.9.1 sdk version with zephyr version 2.7.99
Thank you very much
Sheona
