NRF Connect v2.0.0 - merging 'alarm' sample with 'peripheral_uart' sample
I am attempting to merge two example programs together and have hit an issue with a hard fault when my timer interrupt triggers.
This works fine in the standalone timer example program.
I suspect the issue is that the BLE code also uses the same time timer rtc0 but I can't see where I can change this.
[00:00:20.279,083] <err> mpsl_init: m_assert_handler: MPSL ASSERT: 112, 2181
[00:00:20.279,113] <err> os: hard_fault: ***** HARD FAULT *****
[00:00:20.279,113] <err> os: hard_fault:   Fault escalation (see below)
[00:00:20.279,144] <err> os: hard_fault: ARCH_EXCEPT with reason 3
[00:00:20.279,144] <err> os: esf_dump: r0/a1:  0x00000003  r1/a2:  0x00000002  r2/a3:  0x00000001
[00:00:20.279,174] <err> os: esf_dump: r3/a4:  0x20001ff8 r12/ip:  0x00000000 r14/lr:  0x00013c59
[00:00:20.279,174] <err> os: esf_dump:  xpsr:  0x4100001b
[00:00:20.279,205] <err> os: esf_dump: Faulting instruction address (r15/pc): 0x0002c4f8
[00:00:20.279,235] <err> os: z_fatal_error: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:20.279,235] <err> os: z_fatal_error: Fault during interrupt handling
[00:00:20.279,266] <err> os: z_fatal_error: Current thread: 0x20002920 (idle)
�*** Booting Zephyr OS build v3.0.99-ncs1  ***tal_error_handler: Resetting system
My combined project prj.conf file contains:
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
CONFIG_COUNTER_RTC0=y
CONFIG_I2C=y
CONFIG_COUNTER=y
thanks...
