How to reconnect when Disconnection appear : BLEHci.conn_failed_to_be_established [pc_ble_driver_py]
Hello, I am using the nordic nRF52840-DK with the package pc-ble-driver-py and the example heart_rate_collector.py.
My problem is that sometimes the Bluetooth connection can't connect to the device with this error :
New connection, conn_handle: 0
Disconnected, conn_handle: 0, reason: BLEHci.conn_failed_to_be_established
I know that this error can sometimes occurred. But I would like to know how can I reconnect automatically just after this error ?
Knowing that this error is problematic because it stop my python script lunched from a batch file.
Thanks in advance.
Gaetan
  • Yes the function on_gap_evt_disconnected() is triggered when it disconnect but as you can see in the picture, a raise NordicSemiException appear and stop the code. Because of that exception the script stop and i can't try to reconnect.
    Do you have an idea to solve this ?
    BR,
    Gaetan
  • My service discovery doesn't look like that. I see that the latest version on github has the same implementation as you, though.
    FYI, mine looks like this:
        @NordicSemiErrorCheck(expected=BLEGattStatusCode.success)
        def service_discovery(self, conn_handle, uuid=None):
            vendor_services = []
            self.driver.ble_gattc_prim_srvc_disc(conn_handle, uuid, 0x0001)
            while True:
                response = self.evt_sync[conn_handle].wait(
                    evt=BLEEvtID.gattc_evt_prim_srvc_disc_rsp
                if response["status"] == BLEGattStatusCode.success:
                    for s in response["services"]:
                        if s.uuid.value == BLEUUID.Standard.unknown:
                            vendor_services.append(s)
                        else:
                            self.db_conns[conn_handle].services.append(s)
                elif response["status"] == BLEGattStatusCode.attribute_not_found:
                    break
                else:
                    return response["status"]
                if response["services"][-1].end_handle == 0xFFFF:
                    break
                else:
                        conn_handle, uuid, response["services"][-1].end_handle + 1
            for s in vendor_services:
                # Read service handle to obtain full 128-bit UUID.
                self.driver.ble_gattc_read(conn_handle, s.start_handle, 0)
                response = self.evt_sync[conn_handle].wait(evt=BLEEvtID.gattc_evt_read_rsp)
                if response["status"] != BLEGattStatusCode.success:
                    continue
                # Check response length.
                if len(response["data"]) != 16:
                    continue
                # Create UUIDBase object and register it in softdevice
                base = BLEUUIDBase(
                    response["data"][::-1], driver.BLE_UUID_TYPE_VENDOR_BEGIN
                self.driver.ble_vs_uuid_add(base)
                # Rediscover this service.
                self.driver.ble_gattc_prim_srvc_disc(conn_handle, uuid, s.start_handle)
                    # Assign UUIDBase manually
                    # See:
                    #  https://github.com/NordicSemiconductor/pc-ble-driver-py/issues/38
                        s.uuid.base = base
                    self.db_conns[conn_handle].services.extend(response["services"])
            for s in self.db_conns[conn_handle].services:
                self.driver.ble_gattc_char_disc(conn_handle, s.start_handle, s.end_handle)
                while True:
                        evt=BLEEvtID.gattc_evt_char_disc_rsp
                        for char in response["characteristics"]:
                            s.char_add(char)
                        break
                    else:
                        conn_handle,
                        response["characteristics"][-1].handle_decl + 1,
                        s.end_handle,
                for ch in s.chars:
                    self.driver.ble_gattc_desc_disc(
                        conn_handle, ch.handle_value, ch.end_handle
                    while True:
                            evt=BLEEvtID.gattc_evt_desc_disc_rsp
                            ch.descs.extend(response["descriptors"])
                            break
                        else:
                        if response["descriptors"][-1].handle == ch.end_handle:
                            break
                        else:
                                conn_handle,
                                response["descriptors"][-1].handle + 1,
                                ch.end_handle,
            return BLEGattStatusCode.success
    Either way, if you want to continue after the disconnection, you should remove the exception that is raised. There is no need to continue the service discovery if they are not connected. Instead, you should start scanning again after the disconnect.
    Edvin
  • Yes it is exactly what i want to do ! I want to stop the service discovery after a disconnection and start scanning again after the disconnect.
    But how can I do this because my code will continue to be execute ?
    Gaetan
  • Did you try to remove the line that raises the exception?
    If not, please try this.
  • Yes I already try it but when I have the connection pb the program remains in the while true and cannot get out of it
