sd_ble_gap_sec_params_reply() failed, errCode=0x8
I set static passkey to "123456" and enter "123456" in nRF Connect passkey request dialog. But sd_ble_gap_sec_params_reply() return 0x8 error code.
static void ble_evt_handler(ble_evt_t const* pBleEvt, void* pContext)
    ret_code_t errCode = NRF_SUCCESS;
    switch (pBleEvt->header.evt_id)
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            BLE_UART_SetState(BLE_NUS_STATE_CONNECT);
            errCode = bsp_indication_set(BSP_INDICATE_CONNECTED);
            if (errCode != NRF_SUCCESS) {
                NRF_LOG_WARNING("bsp_indication_set() failed, errCode=0x%x\n", errCode);
                return;
            m_cur_conn_handle = pBleEvt->evt.gap_evt.conn_handle;
            errCode = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_cur_conn_handle);
                NRF_LOG_WARNING("nrf_ble_qwr_conn_handle_assign() failed, errCode=0x%x\n", errCode);
                return;
            ble_gap_sec_params_t secParam;
            secParam.bond           = SEC_PARAM_BOND;
            secParam.mitm           = SEC_PARAM_MITM;
            errCode = sd_ble_gap_authenticate(m_cur_conn_handle, &secParam);
                NRF_LOG_WARNING("sd_ble_gap_authenticate() failed, errCode=0x%x\n", errCode);
                return;
            if (fstorageGetState() == FSTORAGE_STATE_ERASED) {
                fstorageWaitUpdateRecordFinish();
            NRF_LOG_INFO("Disconnected.");
            BLE_UART_SetState(BLE_NUS_STATE_DISCONNECT);
            m_cur_conn_handle = BLE_CONN_HANDLE_INVALID;
            NRF_LOG_INFO("BLE_GAP_EVT_SEC_PARAMS_REQUEST\n");
            securityParametersGet(&secParam);
            errCode = sd_ble_gap_sec_params_reply(m_cur_conn_handle,
                                                  BLE_GAP_SEC_STATUS_SUCCESS,
                                                  &secParam,
                                                  NULL);
                NRF_LOG_WARNING("sd_ble_gap_sec_params_reply() failed, errCode=0x%x\n", errCode);
                return;
        case BLE_GAP_EVT_AUTH_STATUS:
            NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS\n");
            if (pBleEvt->evt.gap_evt.params.auth_status.auth_status != BLE_GAP_SEC_STATUS_SUCCESS) {
                errCode = sd_ble_gap_disconnect(m_cur_conn_handle,
                    NRF_LOG_WARNING("sd_ble_gap_disconnect() failed, errCode=0x%x\n", errCode);
                    return;
            // No implementation needed.
log messages:
 0> <info> app: Version 1.0.0
 0>
 0> <info> app: ========| flash info |========
 0> <info> app: erase unit:   4096 bytes
 0> <info> app: program unit: 4 bytes
 0> <info> app: end address: 0x7FFFF
 0> <info> app: ==============================
 0> <info> app_timer: RTC: initialized.
 0> <debug> app: NOR_DATA_PERIOD=819
 0>
 0> <debug> app: NOR_RECORD_PERIOD=8192
 0>
 0> <info> app: bsp_button_longkey_handler 0.
 0> <warning> app: Battery volage 495mV is too low
 0>
 0> <warning> app: Battery volage 93mV is too low
 0>
 0> <warning> app: Battery volage 8mV is too low
 0>
 0> <warning> app: Battery volage 0mV is too low
 0>
 0> <debug> app: Battery volage 4058mV
 0>
 0> <info> app: POWER_ON.
 0> <info> app: External devices initializing start
 0> <info> app: External devices initializing finish
 0> <info> app: bsp_button_longkey_handler 1.
 0> <debug> nrf_ble_gatt: Requesting to update ATT MTU to 185 bytes on connection 0x0.
 0> <info> app: Connected.
 0> <debug> app: state=1
 0>
 0> <debug> nrf_ble_gatt: ATT MTU updated to 185 bytes on connection 0x0 (response).
 0> <info> app: BLE_GAP_EVT_SEC_PARAMS_REQUEST
 0>
 0> <warning> app: sd_ble_gap_sec_params_reply() failed, errCode=0x8
 0>
 0> <info> app: Connection secured: role: 1, conn_handle: 0x0, procedure: 2.
 0> <info> app: BLE_GAP_EVT_AUTH_STATUS
  • #include "sdk_config.h"
    #include "advertising.h"
    #include "ble_conn_state.h"
    #include "error.h"
    #include "fds.h"
    #include "nrf_log.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "peer_manager_types.h"
    #include "security.h"
    static void _pmEvtHandler(pm_evt_t const * pEvt) {
        ret_code_t errCode;
        switch (pEvt->evt_id) {
            case PM_EVT_BONDED_PEER_CONNECTED:
                NRF_LOG_INFO("Connected to a previously bonded device.");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                             ble_conn_state_role(pEvt->conn_handle),
                             pEvt->conn_handle,
                             pEvt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                NRF_LOG_INFO("Faield to secure connection with handle 0%x.", pEvt->conn_handle);
                errCode = sd_ble_gap_disconnect(pEvt->conn_handle,
                if (errCode != NRF_ERROR_INVALID_STATE)
                    APP_ERROR_CHECK(errCode);
                //pEvt->conn_handle = BLE_CONN_HANDLE_INVALID;
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(pEvt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                errCode = fds_gc();
                if (errCode == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED");
                advertisingStart();
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(pEvt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(pEvt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(pEvt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(pEvt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // This can happen when the local DB has changed.
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    /**@brief Function for the Peer Manager initialization.
    int peerManagerInit(const bool eraseBonds) {
        ret_code_t errCode;
        errCode = pm_init();
            NRF_LOG_WARNING("pm_init() failed, errCode=0x%x\n", errCode);
            return ERROR_PEER_MANAGER_INITIALIZE_FAIL;
        if (eraseBonds) {
            errCode = pm_peers_delete();
                NRF_LOG_WARNING("pm_peers_delete() failed, errCode=0x%x\n", errCode);
            errCode = pm_sec_params_set(&secParam);
                NRF_LOG_WARNING("pm_sec_params_set() failed, errCode=0x%x\n", errCode);
            errCode = pm_register(_pmEvtHandler);
                NRF_LOG_WARNING("pm_register() failed, errCode=0x%x\n", errCode);
        return 0;
    void securityParametersGet(ble_gap_sec_params_t* pSecParam) {
        memset(pSecParam, 0, sizeof(ble_gap_sec_params_t));
        pSecParam->bond           = SEC_PARAM_BOND;
        pSecParam->mitm           = SEC_PARAM_MITM;
        pSecParam->lesc           = SEC_PARAM_LESC;
        pSecParam->keypress       = SEC_PARAM_KEYPRESS;
        pSecParam->io_caps        = SEC_PARAM_IO_CAPABILITIES;
        pSecParam->oob            = SEC_PARAM_OOB;
        pSecParam->min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        pSecParam->max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        pSecParam->kdist_own.enc  = 1;
        pSecParam->kdist_own.id   = 1;
        pSecParam->kdist_peer.enc = 1;
        pSecParam->kdist_peer.id  = 1;
    2818.gap.h
    #include "ble.h"
    #include "ble_conn_params.h"
    #include "ble_gap.h"
    #include "gap.h"
    #include "error.h"
    #define DEVICE_NAME       "ANCS2"                         /**< Name of the device. Will be included in the advertising data. */
    #define STATIC_PASSKEY    "123456"                        /**< Static passkey. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY     0                               /**< Slave latency. */
    #define CONN_SUP_TIMEOUT  MSEC_TO_UNITS(3000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
    static ble_opt_t _gStaticPasskeyOption;	/**< Pointer to the struct containing static pin option. */
    /**@brief Function for initializing GAP connection parameters.
     * @details Use this function to set up all necessary GAP (Generic Access Profile)
     *          parameters of the device. It also sets the permissions and appearance.
    int gapParamsInit(void) {
        ret_code_t              errCode;
        ble_gap_conn_params_t   gapConnParams;
        ble_gap_conn_sec_mode_t secMode;
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&secMode);
        errCode = sd_ble_gap_device_name_set(&secMode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
            NRF_LOG_WARNING("sd_ble_gap_device_name_set() failed, errCode=0x%x", errCode);
            return ERROR_GAP_INITIALIZE_FAIL;
        memset(&gapConnParams, 0, sizeof(gapConnParams));
        gapConnParams.min_conn_interval = MIN_CONN_INTERVAL;
        gapConnParams.max_conn_interval = MAX_CONN_INTERVAL;
        gapConnParams.slave_latency     = SLAVE_LATENCY;
        gapConnParams.conn_sup_timeout  = CONN_SUP_TIMEOUT;
        errCode = sd_ble_gap_ppcp_set(&gapConnParams);
            NRF_LOG_WARNING("sd_ble_gap_ppcp_set() failed, errCode=0x%x", errCode);
        uint8_t passkey[] = STATIC_PASSKEY;
    	_gStaticPasskeyOption.gap_opt.passkey.p_passkey = passkey;
    	errCode = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &_gStaticPasskeyOption);
            NRF_LOG_WARNING("sd_ble_opt_set() failed, errCode=0x%x", errCode);
        return 0;
    3007.security.h
    Error 0x08 means NRF_ERROR_INVALID_STATE, meaning that the other device has not requested a 6-digit passkey at this point in time, which is correct.
    When two devices pair using a 6-digit passkey, one of the devices will provide/display this code, while the other device should enter what is provided/displayed.
    If you didn't change anything in the file security_dispatcher.c (you should not change anything there), then you don't need to do anything else in the BLE_GAP_EVT_SEC_PARAMS_REQUEST event.
    One example that uses 6-digit passkeys (but not static) is the ble_app_gls example. You can see there that it doesn't do anything in the BLE_GAP_EVT_SEC_PARAMS_REQUEST event, other than printing something to the log.
    You can however, try to add the BLE_GAP_EVT_PASSKEY_DISPLAY event, and see if that triggers. Look at the implementation from ble_evt_handler in the ble_app_gls example.
    BR,
    Edvin
  • Thanks for your suggestion! I didn't change anything in the file security_dispatcher.c. And I have removed handling for BLE_GAP_EVT_SEC_PARAMS_REQUEST event.
    log messages:
     0>
     0>
     0>
  • Good stuff,
    When you see the line "Connection secured: role: 1, conn_handle: 0x0, procedure: 2." which is printed from the event PM_EVT_CONN_SEC_SUCCEEDED in peer_manager_handler.c, it means that the link is encrypted. Role 1 means that peripheral, conn_handle is just the connection handle that is encrypted (only relevant if you have several concurrent connections), and procedure:2 means pairing.
    Edvin
