Is it possible to use two identical MIPI RFFE slave devices (BGS18MA12) in parallel on the nRF9160?
The RF signal-flow between the two RF-switches would be identical to the original Thingy:91 design which used the obsolete QM12038.
Both devices would always be addressed in parrallel - knowing that this would be limited to write operations only since read operatins would give conflicts on the bus.
My second question is whether the VIO output can be used as supply for the BGS18MA12 or if it is intended for signaling only?
