ncs 2.0.0 Bluetooth Peripheral_uart: cannot send long data stream
Based on the Sample "Bluetooth Peripheral_uart:
My latest attempt to send long data stream:
I send:
1234567890123456789012345678901234567890123456789012345678901234567890\r
80 characters + '\r'
The tablet (nRF Connect) gets:
and this shows up on the terminal:
[00:04:16.589,721] <wrn> bt_att: No ATT channel for MTU 74
[00:04:16.589,752] <wrn> bt_gatt: No buffer available to send notification
[00:04:16.589,843] <wrn> peripheral_uart: Failed to send data over BLE connection
What is going on?
My prj.conf:
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
#CONFIG_UART_INTERRUPT_DRIVEN=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_NUS_UART_BUFFER_SIZE=240
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=244
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
#CONFIG_SDC_MAX_CONN_EVENT_LEN_DEFAULT=50000
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_CONN_TX_MAX=10
CONFIG_BT_L2CAP_TX_BUF_COUNT=10
CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_CTLR_RX_BUFFERS=2
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
# Set output power to +14 dBm (-8 + 22 = +14), SKY66112 PA
CONFIG_BT_CTLR_TX_PWR_MINUS_8=y
# NFC
CONFIG_NFCT_PINS_AS_GPIOS=y
# Enable the NUS service
CONFIG_BT_NUS=y
CONFIG_BT_NUS_UART_ASYNC_ADAPTER=n
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=y
CONFIG_ASSERT=y
### FEM configration
CONFIG_MPSL=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_SIMPLE_GPIO=y
