[nRF Connect SDK](Urgent)Assert after DFU via OTA
Target nRF52832(nrf52dk_nrf52832)
SDK NCS v1.9.1
Normally OTA works well.
I found unexpected assert after OTA is done.
Can you please review my assert code with my elf.
00> I: SoftDevice Controller build revision:
00> I: 0e e7 c5 66 67 18 3c ac |...fg.<.
00> I: b3 d2 cc 81 a3 dc f1 c0 |........
00> I: c0 36 02 22 |.6."
00> I: No ID address. App must call settings_load()
00> E: ***** MPU FAULT *****
00> E: Stacking error (context area might be not valid)
00> E: Data Access Violation
00> E: MMFAR Address: 0x20006190
00> E: r0/a1: 0x00000000 r1/a2: 0x000347f9 r2/a3: 0x00000000
00> E: r3/a4: 0x000347f9 r12/ip: 0xec7ff16f r14/lr: 0x29302810
00> E: xpsr: 0x38132000
00> E: Faulting instruction address (r15/pc): 0xf2e63a6d
00> E: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
00> E: Current thread: 0x20002350 (unknown)
00> E: Resetting system
6165.build.7z
  • Thanks for good information. it is very helpful.
    My project requires maximum performance. We read UART from host and send it to Android via BLE.
    (bandwidth 60 KBytes/sec). So that it need much ram to run.
    What I asked you was if "Used 99.8%" itself is fine.
    2048 bytes of CONFIG_MAIN_STACK_SIZE is fine?
    0.02% of ram is left. Is it okay?
    If we need more margin(0.02%), I have to reduce my buffer for ring buffer or so.
    What is your opinion?
    I will test "CONFIG_MAIN_STACK_SIZE=2048" until today.
    Thanks.
  • Hello.
    I did stress test with two product. And one of device was reset without any log last night. (Stress test means receiving data from UART and send it to Android)
    I already did lots of times it was fine so far.
    [rtt log] silent reset
    00> connect_done secmode(4)
    00> auth_handler 1
    00> *** Booting Zephyr OS build v2.7.99-ncs1-1 ***
    00>
    00> Starting Bluetooth Peripheral HIDS keyboard example for RFR
    00> ## build time: Jul 26 2022 09:49:04
    00> ver V1.3.7
    [Changes & SRAM]
    V1.3.6
    CONFIG_MAIN_STACK_SIZE=1024
    CONFIG_BT_MAX_PAIRED=6
    RINGBUFFER size: 24KB
    [264/272] Linking C executable zephyr\zephyr.elf
    Memory region Used Size Region Size %age Used
    FLASH: 214636 B 232960 B 92.13%
    SRAM: 64672 B 64 KB 98.68%
    IDT_LIST: 0 GB 2 KB 0.00%
    [272/272] Generating zephyr/merged.hex
    v1.3.7
    CONFIG_BT_MAX_PAIRED=4
    SRAM: 65408 B 64 KB 99.80%
     V1.3.8 <- Under Testing
    RINGBUFFER size: 24KB -> 22KB
    SRAM: 63360 B 64 KB 96.68%
    Stress test requires lots of time(a day). So I hope you give me your opinion current my project situation.
  • I have to tell you another view of this issue.
    When this issue was made, BLE was reset repeatedly with those logs.
    I have no choice but to flash same binary to recover it.
    After then I cannot made this issue again easily. ( I could not make same issue again)
    On the other hand I change CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE from 2048 to 512.
    I could this issue immediately.
    I'm not sure if this issue is from stack over flow.
    Soon, one of my customer will test our product to buy.
    I'm expecting you give me any opinion.
    Thank you.
  • Hello, sorry for the delay on this. In July, most of the support team are on vacation and you can expect slower responses. I will reply tomorrow (Friday)
    Simon
    I think it should be fine.
    Okay, so right after you change CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE from 2048 to 512 the issue happens, then it's likely a stack overflow.
    I'm not sure if I understood your questions correctly, let me know if not.
    However, I will go on vacation the next two weeks, so I'm not able to reply until 15th of Aug. If that is too long to wait, could you open a new ticket and point to this one?
    Simon
