MQTT TLS connect blocking
Hi
I am currently working on a custom nrf9160 board and I have a random bug that appears to be in this function mqtt_client_connect_tls.
For 3min, the board consumption is 4mA and then the mqtt returns -116 error (timeout).
I have found in the devzone that is a known bug that should have been corrected in modem version 1.3.0.
 Blocking socket calls in MQTT library
I am sure that only one thread is accessing the socket.
I have also tested increase the config like said. It doesn't change the problem.
CONFIG_NRF_MODEM_LIB_HEAP_SIZE=4096
CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=2048
09:46:17.528) (COM2) (>>) [16:42:30.076,232] <inf> MQTT_STANDARD_MODULE: TLS enabled<CR><LF>
(09:46:17.528) (COM2) (>>) [16:42:30.076,690] <dbg> net_mqtt_sock_tls: (): Created socket 0<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.424,224] <dbg> lte_lc: +CSCON notification<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.424,346] <dbg> lte_lc_helpers: Dispatching events:<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.424,377] <dbg> lte_lc_helpers:  - handler=0x0002ED49<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.424,377] <inf> module_modem: MODEM notification: RRC_UPDATE<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.424,377] <inf> module_modem: RRC mode: Idle<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.424,407] <dbg> lte_lc_helpers: Done<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.818,756] <dbg> lte_lc: +CEREG notification: +CEREG: 5,"C3D5","00136CCF",9,,,"00001010","11000001"<CR><LF>
(09:47:04.943) (COM2) (>>) <CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.818,969] <dbg> lte_lc_helpers: Network registration status: 5<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,000] <dbg> lte_lc_helpers: LTE mode: 9<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,061] <dbg> lte_lc_helpers: Dispatching events:<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,061] <dbg> lte_lc_helpers:  - handler=0x0002ED49<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,061] <inf> module_modem: MODEM notification: CELL_UPDATE<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,091] <inf> module_modem: LTE cell changed: Cell ID: 1273039, Tracking area: 50133<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,091] <dbg> lte_lc_helpers: Done<CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,824] <dbg> lte_lc_helpers: TAU: 1152000 sec, active time: 20 sec<LF><CR><LF>
(09:47:04.943) (COM2) (>>) [16:43:17.819,824] <dbg> lte_lc: TAU: 1152000 sec, active time: 20 sec<LF><CR><LF>
(09:47:24.895) (COM2) (>>) [16:43:37.425,964] <dbg> lte_lc: %XMODEMSLEEP notification<CR><LF>
(09:47:24.895) (COM2) (>>) [16:43:37.426,116] <dbg> lte_lc_helpers: Dispatching events:<CR><LF>
(09:47:24.895) (COM2) (>>) [16:43:37.426,116] <dbg> lte_lc_helpers:  - handler=0x0002ED49<CR><LF>
(09:47:24.895) (COM2) (>>) [16:43:37.426,116] <inf> module_modem: MODEM notification: MODEM_SLEEP_ENTER<CR><LF>
(09:47:24.895) (COM2) (>>) [16:43:37.426,147] <dbg> lte_lc_helpers: Done<CR><LF>
(09:49:03.930) (COM2) (>>) [16:45:16.989,501] <err> MQTT_STANDARD_MODULE: mqtt_connect, error: -116<CR><LF>
(09:49:04.060) (COM2) (>>) [16:45:16.989,532] <wrn> MQTT_STANDARD_MODULE: connection_poll_start failed, error: -116<CR><LF>
(09:49:04.060) (COM2) (>>) [16:45:16.989,532] <inf> MODULE_MQTT: standard_cloud_connect -116<CR><LF>
(09:49:04.060) (COM2) (>>) [16:45:16.989,562] <err> MODULE_MQTT: mqtt_connect -116<CR><LF>
I attach the log that I can have.
Do you know if there is a correction available ?
Thank you in advance
Antoine
(sdk 1.9.1, modem FW 1.3.2)
