Hello Sirs,
I loop typing the same command program:
clear>tart_channel 02>output_power pos0dBm>start_tx_modulated_carrier>cancel
After repeating the same instruction program for 5~6 times, RX does not respond normally after typing "start_tx_modulated_carrier".
Any help would be appreciated.
Best Regards,
Lulu
issue log:
2022/7/22 17:19:25.612 [RX] - clear<CR><LF>
<ESC>[H<ESC>[2J<ESC>[1;32muart_cli:~$ <ESC>[1;37m
2022/7/22 17:19:26.008 [TX] - start_channel 02<CR><LF>
2022/7/22 17:19:26.018 [RX] - start_channel 02<CR><LF>
<ESC>[1;32mStart channel set to: 2.<CR>
<CR><LF>
<ESC>[1;37m<ESC>[1;32muart_cli:~$ <ESC>[1;37m
2022/7/22 17:19:26.369 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:19:26.379 [RX] - output_power pos0dBm<CR><LF>
<ESC>[1;32mTX power: NRF_RADIO_TXPOWER_0DBM<CR>
<CR><LF>
2022/7/22 17:19:26.731 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:19:26.740 [RX] - start_tx_modulated_carrier<CR><LF>
<ESC>[1;32mStart the modulated TX carrier.<CR>
<CR><LF>
2022/7/22 17:19:27.055 [TX] - cancel<CR><LF>
2022/7/22 17:19:27.065 [RX] - cancel<CR><LF>
2022/7/22 17:19:28.771 [TX] - clear<CR><LF>
2022/7/22 17:19:28.799 [RX] - clear<CR><LF>
2022/7/22 17:19:29.268 [TX] - start_channel 02<CR><LF>
2022/7/22 17:19:29.278 [RX] - start_channel 02<CR><LF>
<CR><LF>
2022/7/22 17:19:29.610 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:19:29.620 [RX] - output_power pos0dBm<CR><LF>
<CR><LF>
2022/7/22 17:19:29.970 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:19:29.979 [RX] - st
2022/7/22 17:19:30.676 [TX] - cancel<CR><LF>
2022/7/22 17:19:41.771 [TX] - clear<CR><LF>
2022/7/22 17:19:42.608 [TX] - start_channel 02<CR><LF>
2022/7/22 17:19:48.420 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:19:51.564 [TX] - start_tx_modulated_carrier<CR><LF>
Docklight Log File (ASCII) - Started 2022/7/22 17:17:58.877
2022/7/22 17:18:12.040 [TX] - <CR><LF>
2022/7/22 17:18:12.115 [RX] - <CR><LF>
2022/7/22 17:18:13.416 [TX] - clear<CR><LF>
2022/7/22 17:18:13.427 [RX] - clear<CR><LF>
2022/7/22 17:18:14.110 [TX] - start_channel 02<CR><LF>
2022/7/22 17:18:14.121 [RX] - start_channel 02<CR><LF>
<CR><LF>
2022/7/22 17:18:14.667 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:18:14.679 [RX] - output_power pos0dBm<CR><LF>
<CR><LF>
2022/7/22 17:18:15.473 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:18:15.484 [RX] - start_tx_modulated_carrier<CR><LF>
<CR><LF>
2022/7/22 17:18:19.816 [TX] - cancel<CR><LF>
2022/7/22 17:18:19.827 [RX] - cancel<CR><LF>
2022/7/22 17:18:21.723 [TX] - <CR><LF>
2022/7/22 17:18:21.766 [RX] - <CR><LF>
2022/7/22 17:18:23.006 [TX] - clear<CR><LF>
2022/7/22 17:18:23.072 [RX] - clear<CR><LF>
2022/7/22 17:18:23.561 [TX] - start_channel 02<CR><LF>
2022/7/22 17:18:23.571 [RX] - start_channel 02<CR><LF>
<CR><LF>
2022/7/22 17:18:24.085 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:18:24.092 [RX] - output_power pos
2022/7/22 17:18:24.466 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:18:24.477 [RX] - <ESC>[28D<ESC>[J<error> app: ASSERTION FAILED at D:\11_Project\21_Radio_Test(nRF52840)\nRF5X(SDK1710)\components\libraries\cli\uart\nrf_cli_uart.c:95<CR>
<CR><LF>
2022/7/22 17:18:25.189 [TX] - cancel<CR><LF>
2022/7/22 17:18:40.179 [TX] - <CR><LF>
2022/7/22 17:18:42.030 [TX] - clear<CR><LF>
2022/7/22 17:18:42.516 [TX] - start_channel 02<CR><LF>
2022/7/22 17:18:42.909 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:18:43.315 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:18:43.661 [TX] - cancel<CR><LF>
2022/7/22 17:19:04.470 [RX] - <NUL><ESC>[1;37m<ESC>[40m<CR><LF>
<CR><LF>
<ESC>[1;32muart_cli:~$ <ESC>[1;37m<ESC>[12D<ESC>[JRadio test example started.<CR>
<CR><LF>
<ESC>[1;32muart_cli:~$ <ESC>[1;37m<ESC>[12D<ESC>[JStarting Radio Test 220722<ESC>[1;32muart_cli:~$ <ESC>[1;37m
2022/7/22 17:19:07.012 [TX] - <CR><LF>
2022/7/22 17:19:07.086 [RX] - <CR><LF>
2022/7/22 17:19:08.000 [TX] - clear<CR><LF>
2022/7/22 17:19:08.091 [RX] - clear<CR><LF>
2022/7/22 17:19:08.609 [TX] - start_channel 02<CR><LF>
2022/7/22 17:19:08.619 [RX] - start_channel 02<CR><LF>
<CR><LF>
2022/7/22 17:19:09.329 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:19:09.338 [RX] - output_power pos0dBm<CR><LF>
<CR><LF>
2022/7/22 17:19:09.908 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:19:09.917 [RX] - start_tx_modulated_carrier<CR><LF>
<CR><LF>
2022/7/22 17:19:13.055 [TX] - cancel<CR><LF>
2022/7/22 17:19:13.066 [RX] - cancel<CR><LF>
2022/7/22 17:19:15.006 [TX] - clear<CR><LF>
2022/7/22 17:19:15.027 [RX] - clear<CR><LF>
2022/7/22 17:19:15.551 [TX] - start_channel 02<CR><LF>
2022/7/22 17:19:15.561 [RX] - start_channel 02<CR><LF>
<CR><LF>
2022/7/22 17:19:16.013 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:19:16.018 [RX] - output_power pos0dBm<CR><LF>
<CR><LF>
2022/7/22 17:19:16.428 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:19:16.438 [RX] - start_tx_modulated_carrier<CR><LF>
<CR><LF>
2022/7/22 17:19:16.852 [TX] - cancel<CR><LF>
2022/7/22 17:19:16.937 [RX] - cancel<CR><LF>
2022/7/22 17:19:18.770 [TX] - clear<CR><LF>
2022/7/22 17:19:18.847 [RX] - clear<CR><LF>
2022/7/22 17:19:19.350 [TX] - start_channel 02<CR><LF>
2022/7/22 17:19:19.359 [RX] - start_channel 02<CR><LF>
<CR><LF>
2022/7/22 17:19:19.787 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:19:19.797 [RX] - output_power pos0dBm<CR><LF>
<CR><LF>
2022/7/22 17:19:20.177 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:19:20.187 [RX] - start_tx_modulated_carrier<CR><LF>
<CR><LF>
2022/7/22 17:19:20.659 [TX] - cancel<CR><LF>
2022/7/22 17:19:20.757 [RX] - cancel<CR><LF>
2022/7/22 17:19:22.256 [TX] - clear<CR><LF>
2022/7/22 17:19:22.266 [RX] - clear<CR><LF>
2022/7/22 17:19:22.756 [TX] - start_channel 02<CR><LF>
2022/7/22 17:19:22.766 [RX] - start_channel 02<CR><LF>
<CR><LF>
2022/7/22 17:19:23.133 [TX] - output_power pos0dBm<CR><LF>
2022/7/22 17:19:23.144 [RX] - output_power pos0dBm<CR><LF>
<CR><LF>
2022/7/22 17:19:23.493 [TX] - start_tx_modulated_carrier<CR><LF>
2022/7/22 17:19:23.503 [RX] - start_tx_modulated_carrier<CR><LF>
<CR><LF>
2022/7/22 17:19:24.056 [TX] - cancel<CR><LF>
2022/7/22 17:19:24.076 [RX] - cancel<CR><LF>
2022/7/22 17:19:25.601 [TX] - clear<CR><LF>
<CR><LF>
<CR><LF>
<CR><LF>
<CR><LF>
<CR><LF>
