Read debugs from nrf52840 dongle on nrf52840 DK
I've surfed through the forum for the lot of similar posts but couldn't get it to work yet. So, apologies if this seems repetitive.
My ultimate goal is to port the program that is running perfectly on nrf52840 DK to nrf52840 dongle. Before we get there, I'm currently trying to read debugs from the dongle on the DK for basic checking.
I've gone through this tutorial and included the voltage setter script in the programs. For more background, I'm trying to follow this tutorial
Problem
This is the code I've uploaded into the dongle. It's just the sample blinky code with voltage setter snippet and printk statement.
 * Copyright (c) 2016 Intel Corporation
#include <zephyr.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
#include <sys/printk.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS   1000
/* The devicetree node identifier for the "led0" alias. */
#define LED0_NODE DT_ALIAS(led0)
#if DT_NODE_HAS_STATUS(LED0_NODE, okay)
#define LED0	DT_GPIO_LABEL(LED0_NODE, gpios)
#define PIN	DT_GPIO_PIN(LED0_NODE, gpios)
#define FLAGS	DT_GPIO_FLAGS(LED0_NODE, gpios)
#else
/* A build error here means your board isn't set up to blink an LED. */
#error "Unsupported board: led0 devicetree alias is not defined"
#define LED0	""
#define PIN	0
#define FLAGS	0
void main(void)
	/* Change voltage if we use nrf DK to program the dongle (code snippet from tutorial)*/
	if ((NRF_UICR->REGOUT0 & UICR_REGOUT0_VOUT_Msk) == (UICR_REGOUT0_VOUT_DEFAULT << UICR_REGOUT0_VOUT_Pos)){
		NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
		while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
		NRF_UICR->REGOUT0 = (NRF_UICR->REGOUT0 & ~((uint32_t)UICR_REGOUT0_VOUT_Msk)) |
							(UICR_REGOUT0_VOUT_3V0 << UICR_REGOUT0_VOUT_Pos);
		NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
		// System reset is needed to update UICR registers.
		NVIC_SystemReset();
	const struct device *dev;
	bool led_is_on = true;
	int ret;
	dev = device_get_binding(LED0);
	if (dev == NULL) {
		return;
	ret = gpio_pin_configure(dev, PIN, GPIO_OUTPUT_ACTIVE | FLAGS);
	if (ret < 0) {
		return;
	while (1) {
		gpio_pin_set(dev, PIN, (int)led_is_on);
		led_is_on = !led_is_on;
		printk("Hello World! %s\n", CONFIG_BOARD);
		k_msleep(SLEEP_TIME_MS);
It's successfully built using the nRF connect for VS code extension and then directly uploading the .hex file using the "nRF connect for Desktop" programmer app. I can see the dongle blinking, so it works.
Now, I've connected the dongle and the DK via SWD interface and DEBUG OUT as seen in the picture.
The dongle is still flashing the green LED but I cannot detect a serial port anymore. Instead, I can only see the two j-link virtual ports. None of them is printing any debug logs. There's also RTT logging feature on the VS code and when it's selected I get this pop up and choose the right board as shown. I can see the green LED on DK board flashing very fast although I have no idea why is that.
However, nothing is still printed.
My DK board is nRF52840_xxAA_Rev3(as seen on the programmer app). I can see the SB19 pad beside the DEBUG OUT header on the DK board but this post states it doesn't need to be soldered to use.
Also, I'm seeing both boards on the programmer which sounds wrong.
I'm sure I'm missing something here but can't figure out what after debugging for over 6 hours, hence seeking help.
Thanks
  • Yes it should be possible to "save" the bootloader. I think what has happened is that you haven't built the application for the Dongle. That will set the BOARD_HAS_NRF5_BOOTLOADER=y for example, which will build the zephyr-app to start after the bootloader (at 0x1000). As long as you use NCS v1.7.0 or newer.
    Simon
  • Hi Simon,
    Yes you are right. I just uploaded the original bootloader and it's working fine now. Moreover, I've started to use SES as my IDE instead of VS code which gives me a better experience debugging. Thanks for all your help. I'd be happy if you would change this post back to public so other ppl can benefit as well, of course with my delivery details deleted.
    [UPDATE] i have edited my reply of sensitive data. So no need to delete it anymore.
    Cheers,
    Naing
