case about ncs v2.0.0 asset_tracker_v2
How to configure the following two CONFIG to connect the nRF9160 module to the nRF Cloud
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME
The measured as follows
1. I set the following options to configure an nRF9160 module (not DK) to connect to the nRF Cloud
2. Configure mode 1 to connect to the nRF Cloud
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y
CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="user-"
3. The nRF Cloud cannot be connected in configuration mode 2
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID="<user-352656100375701>"
Thank you for all your assistance.
Peter.Min
  • Hello Peter.Min,
    Try to replace "<user-352656100375701>" with "user-352656100375701".
    Maria
    I modified and tested according to what you said, but still could not connect to nRF Cloud
    The test log is as follows
    2022-08-05T09:49:30.456Z DEBUG Application data folder: C:\Users\Peter\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2022-08-05T09:49:30.540Z INFO Using nrf-device-lib-js version: 0.4.11
    2022-08-05T09:49:30.540Z INFO Using nrf-device-lib version: 0.11.8
    2022-08-05T09:49:30.540Z INFO Using nrfjprog DLL version: 10.15.4
    2022-08-05T09:49:30.540Z INFO Using JLink version: JLink_V7.66b
    2022-08-05T09:49:30.548Z DEBUG App pc-nrfconnect-linkmonitor v2.0.1 official
    2022-08-05T09:49:30.548Z DEBUG App path: C:\Users\Peter\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2022-08-05T09:49:30.548Z DEBUG nRFConnect 3.11.1, required by the app is (^3.8.0)
    2022-08-05T09:49:30.548Z DEBUG nRFConnect path: C:\Users\Peter\AppData\Local\Programs\nrfconnect\resources\app.asar
    2022-08-05T09:49:30.548Z DEBUG HomeDir: C:\Users\Peter
    2022-08-05T09:49:30.548Z DEBUG TmpDir: C:\Users\Peter\AppData\Local\Temp
    2022-08-05T09:49:30.567Z INFO Installed JLink version does not match the provided version (V7.58b)
    2022-08-05T09:49:32.133Z INFO Modem port is opened
    2022-08-05T09:49:35.440Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-05T09:49:35.452Z DEBUG modem << Attempting to boot slot 0.
    2022-08-05T09:49:35.454Z DEBUG modem << Attempting to boot from address 0x8200.
    2022-08-05T09:49:35.458Z DEBUG modem << Verifying signature against key 0.
    2022-08-05T09:49:35.460Z DEBUG modem << Hash: 0xb2...9e
    2022-08-05T09:49:35.476Z DEBUG modem << Firmware signature verified.
    2022-08-05T09:49:35.481Z DEBUG modem << Firmware version 1
    2022-08-05T09:49:35.483Z DEBUG modem << Booting (0x8200).
    2022-08-05T09:49:35.740Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-05T09:49:35.742Z DEBUG modem << I: Starting bootloader
    2022-08-05T09:49:35.749Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:49:35.756Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:49:35.759Z DEBUG modem << I: Boot source: none
    2022-08-05T09:49:35.763Z DEBUG modem << I: Swap type: none
    2022-08-05T09:49:35.766Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:49:35.774Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:49:35.778Z DEBUG modem << I: Boot source: none
    2022-08-05T09:49:35.780Z DEBUG modem << I: Swap type: none
    2022-08-05T09:49:35.863Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2022-08-05T09:49:35.868Z DEBUG modem << I: Jumping to the first image slot
    2022-08-05T09:49:36.580Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-05T09:49:37.586Z DEBUG modem << [00:00:00.531,097] [0m<inf> app_event_manager: APP_EVT_START[0m
    2022-08-05T09:49:37.620Z DEBUG modem << [00:00:00.532,257] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2022-08-05T09:49:37.624Z DEBUG modem << [00:00:00.534,057] [1;33m<wrn> nrf_cloud_transport: Not configured to for runtime client ID, ignoring[0m
    2022-08-05T09:49:37.626Z DEBUG modem << [00:00:00.584,045] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2022-08-05T09:49:38.615Z DEBUG modem << [00:00:01.559,661] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2022-08-05T09:49:38.623Z DEBUG modem << [00:00:01.560,211] [0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE[0m
    2022-08-05T09:49:44.385Z DEBUG modem << %MDMEV: SEARCH STATUS 1
    2022-08-05T09:49:46.226Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2022-08-05T09:49:46.228Z DEBUG modem << +CEREG: 4
    2022-08-05T09:49:47.234Z DEBUG modem << [00:00:10.177,886] [0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
    2022-08-05T09:49:47.241Z DEBUG modem << [00:00:10.178,527] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2022-08-05T09:50:32.268Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-05T09:50:32.270Z DEBUG modem << Attempting to boot slot 0.
    2022-08-05T09:50:32.274Z DEBUG modem << Attempting to boot from address 0x8200.
    2022-08-05T09:50:32.277Z DEBUG modem << Verifying signature against key 0.
    2022-08-05T09:50:32.279Z DEBUG modem << Hash: 0xb2...9e
    2022-08-05T09:50:32.304Z DEBUG modem << Firmware signature verified.
    2022-08-05T09:50:32.306Z DEBUG modem << Firmware version 1
    2022-08-05T09:50:32.310Z DEBUG modem << Setting monotonic counter (version: 1, slot: 0)
    2022-08-05T09:50:32.312Z DEBUG modem << Booting (0x8200).
    2022-08-05T09:50:32.686Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-05T09:50:32.689Z DEBUG modem << I: Starting bootloader
    2022-08-05T09:50:32.695Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:50:32.702Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:50:32.704Z DEBUG modem << I: Boot source: none
    2022-08-05T09:50:32.706Z DEBUG modem << I: Swap type: none
    2022-08-05T09:50:32.713Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:50:32.719Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-05T09:50:32.721Z DEBUG modem << I: Boot source: none
    2022-08-05T09:50:32.723Z DEBUG modem << I: Swap type: none
    2022-08-05T09:50:32.810Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2022-08-05T09:50:32.813Z DEBUG modem << I: Jumping to the first image slot
    2022-08-05T09:50:33.276Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-05T09:50:34.283Z DEBUG modem << [00:00:00.199,676] [0m<inf> app_event_manager: APP_EVT_START[0m
    2022-08-05T09:50:34.295Z DEBUG modem << [00:00:00.200,897] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2022-08-05T09:50:34.299Z DEBUG modem << [00:00:00.202,728] [1;33m<wrn> nrf_cloud_transport: Not configured to for runtime client ID, ignoring[0m
    2022-08-05T09:50:34.313Z DEBUG modem << [00:00:00.252,777] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2022-08-05T09:50:35.312Z DEBUG modem << [00:00:01.228,210] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2022-08-05T09:50:35.321Z DEBUG modem << [00:00:01.228,759] [0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE[0m
    2022-08-05T09:50:40.919Z DEBUG modem << %MDMEV: SEARCH STATUS 1
    2022-08-05T09:50:42.939Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2022-08-05T09:50:42.943Z DEBUG modem << +CEREG: 4
    2022-08-05T09:50:43.948Z DEBUG modem << [00:00:09.863,128] [0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
    2022-08-05T09:50:43.955Z DEBUG modem << [00:00:09.863,769] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2022-08-05T09:52:34.321Z DEBUG modem << [00:02:01.228,790] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-08-05T09:52:34.333Z DEBUG modem << [00:02:01.229,461] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, MOD_STAT)[0m
    2022-08-05T09:52:34.341Z DEBUG modem << [00:02:01.230,346] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2022-08-05T09:52:34.349Z DEBUG modem << [00:02:01.232,696] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2022-08-05T09:52:34.356Z DEBUG modem << [00:02:01.233,245] [1;31m<err> modem_info_params: Link data not obtained: 8 -22[0m
    2022-08-05T09:52:34.364Z DEBUG modem << [00:02:01.233,764] [1;31m<err> modem_info_params: Link data not obtained: 3 -22[0m
    2022-08-05T09:52:34.371Z DEBUG modem << [00:02:01.236,114] [1;31m<err> modem_info_params: Link data not obtained: 21 -22[0m
    2022-08-05T09:52:34.378Z DEBUG modem << [00:02:01.236,633] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2022-08-05T09:52:34.386Z DEBUG modem << [00:02:01.236,663] [1;31m<err> modem_info_params: Network data not obtained: -93[0m
    2022-08-05T09:52:34.393Z DEBUG modem << [00:02:01.236,694] [1;31m<err> modem_module: modem_info_params_get, error: -11[0m
    2022-08-05T09:52:34.401Z DEBUG modem << [00:02:01.236,755] [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_NOT_READY[0m
    2022-08-05T09:52:34.419Z DEBUG modem << [00:02:01.326,019] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2022-08-05T09:52:34.427Z DEBUG modem << [00:02:01.326,568] [1;31m<err> modem_info_params: Link data not obtained: 8 -22[0m
    2022-08-05T09:52:34.434Z DEBUG modem << [00:02:01.327,087] [1;31m<err> modem_info_params: Link data not obtained: 3 -22[0m
    2022-08-05T09:52:34.442Z DEBUG modem << [00:02:01.329,895] [1;31m<err> modem_info_params: Link data not obtained: 21 -22[0m
    2022-08-05T09:52:34.449Z DEBUG modem << [00:02:01.330,352] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2022-08-05T09:52:34.457Z DEBUG modem << [00:02:01.330,352] [1;31m<err> modem_info_params: Network data not obtained: -93[0m
    2022-08-05T09:52:34.464Z DEBUG modem << [00:02:01.330,383] [1;31m<err> modem_module: modem_info_params_get, error: -11[0m
    2022-08-05T09:52:34.472Z DEBUG modem << [00:02:01.330,444] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2022-08-05T09:52:34.479Z DEBUG modem << [00:02:01.333,404] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2022-08-05T09:52:34.487Z DEBUG modem << [00:02:01.333,953] [1;31m<err> modem_info_params: Link data not obtained: 8 -22[0m
    2022-08-05T09:52:34.494Z DEBUG modem << [00:02:01.334,472] [1;31m<err> modem_info_params: Link data not obtained: 3 -22[0m
    2022-08-05T09:52:34.518Z DEBUG modem << %NCELLMEAS: 1
    2022-08-05T09:52:34.519Z DEBUG modem << +CEREG: 2
    2022-08-05T09:52:35.504Z DEBUG modem << [00:02:01.419,311] [1;31m<err> modem_info_params: Link data not obtained: 21 -22[0m
    2022-08-05T09:52:35.512Z DEBUG modem << [00:02:01.419,769] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2022-08-05T09:52:35.519Z DEBUG modem << [00:02:01.419,799] [1;31m<err> modem_info_params: Network data not obtained: -93[0m
    2022-08-05T09:52:35.526Z DEBUG modem << [00:02:01.419,799] [1;31m<err> modem_module: modem_info_params_get, error: -11[0m
    2022-08-05T09:52:35.534Z DEBUG modem << [00:02:01.419,891] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2022-08-05T09:52:35.542Z DEBUG modem << [00:02:01.442,199] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2022-08-05T09:52:35.549Z DEBUG modem << [00:02:01.442,810] [0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
    2022-08-05T09:52:35.555Z DEBUG modem << [00:02:01.443,603] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    2022-08-05T09:52:42.978Z DEBUG modem << +CEREG: 4
    2022-08-05T09:52:43.985Z DEBUG modem << [00:02:09.900,604] [0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
    2022-08-05T09:54:34.342Z DEBUG modem << [00:04:01.228,790] [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-08-05T09:54:34.353Z DEBUG modem << [00:04:01.229,431] [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS)[0m
    2022-08-05T09:54:34.361Z DEBUG modem << [00:04:01.230,285] [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2022-08-05T09:54:34.369Z DEBUG modem << [00:04:01.241,271] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2022-08-05T09:54:34.376Z DEBUG modem << [00:04:01.241,912] [1;31m<err> modem_info_params: Link data not obtained: 8 -22[0m
    2022-08-05T09:54:34.384Z DEBUG modem << [00:04:01.248,535] [1;31m<err> modem_info_params: Link data not obtained: 3 -22[0m
    2022-08-05T09:54:34.391Z DEBUG modem << [00:04:01.256,988] [1;31m<err> modem_info_params: Link data not obtained: 21 -22[0m
    2022-08-05T09:54:34.399Z DEBUG modem << [00:04:01.257,446] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2022-08-05T09:54:34.406Z DEBUG modem << [00:04:01.257,476] [1;31m<err> modem_info_params: Network data not obtained: -93[0m
    2022-08-05T09:54:34.414Z DEBUG modem << [00:04:01.257,476] [1;31m<err> modem_module: modem_info_params_get, error: -11[0m
    2022-08-05T09:54:34.422Z DEBUG modem << [00:04:01.257,568] [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2022-08-05T09:54:34.472Z DEBUG modem << %NCELLMEAS: 1
    2022-08-05T09:54:35.438Z DEBUG modem << [00:04:01.352,722] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2022-08-05T09:54:35.445Z DEBUG modem << [00:04:01.359,375] [1;31m<err> modem_info_params: Link data not obtained: 8 -22[0m
    2022-08-05T09:54:35.452Z DEBUG modem << [00:04:01.359,893] [1;31m<err> modem_info_params: Link data not obtained: 3 -22[0m
    2022-08-05T09:54:35.460Z DEBUG modem << [00:04:01.362,396] [1;31m<err> modem_info_params: Link data not obtained: 21 -22[0m
    2022-08-05T09:54:35.467Z DEBUG modem << [00:04:01.362,976] [1;31m<err> modem_info_params: Link data not obtained: 20 -5[0m
    2022-08-05T09:54:35.475Z DEBUG modem << [00:04:01.363,006] [1;31m<err> modem_info_params: Network data not obtained: -93[0m
    2022-08-05T09:54:35.482Z DEBUG modem << [00:04:01.363,006] [1;31m<err> modem_module: modem_info_params_get, error: -11[0m
    2022-08-05T09:54:35.490Z DEBUG modem << [00:04:01.363,098] [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    2022-08-05T09:54:35.498Z DEBUG modem << [00:04:01.394,500] [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_NOT_READY[0m
    2022-08-05T09:54:35.505Z DEBUG modem << [00:04:01.395,385] [0m<inf> app_event_manager: DATA_EVT_DATA_READY[0m
    Peter.Min
  • Hello Peter.Min,
    The lines 41-43 in your log shows that the modem is not able to find a network to connect to.
    Are you using LTE-M or NB-IoT? Can you confirm that the one you are using is supported on your SIM card and available in your area?
    BR,
    Maria
  • Hi Maria,
    I changed an NB SIM card for testing, but it still failed to connect.
    2022-08-15T01:40:51.010Z DEBUG Application data folder: C:\Users\Peter\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2022-08-15T01:40:51.092Z INFO Using nrf-device-lib-js version: 0.4.11
    2022-08-15T01:40:51.092Z INFO Using nrf-device-lib version: 0.11.8
    2022-08-15T01:40:51.092Z INFO Using nrfjprog DLL version: 10.15.4
    2022-08-15T01:40:51.092Z INFO Using JLink version: JLink_V7.66b
    2022-08-15T01:40:51.106Z DEBUG App pc-nrfconnect-linkmonitor v2.0.1 official
    2022-08-15T01:40:51.106Z DEBUG App path: C:\Users\Peter\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2022-08-15T01:40:51.106Z DEBUG nRFConnect 3.11.1, required by the app is (^3.8.0)
    2022-08-15T01:40:51.106Z DEBUG nRFConnect path: C:\Users\Peter\AppData\Local\Programs\nrfconnect\resources\app.asar
    2022-08-15T01:40:51.106Z DEBUG HomeDir: C:\Users\Peter
    2022-08-15T01:40:51.106Z DEBUG TmpDir: C:\Users\Peter\AppData\Local\Temp
    2022-08-15T01:40:51.123Z INFO Installed JLink version does not match the provided version (V7.58b)
    2022-08-15T01:40:54.493Z INFO Modem port is opened
    2022-08-15T01:40:56.438Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-15T01:40:56.447Z DEBUG modem << Attempting to boot slot 0.
    2022-08-15T01:40:56.450Z DEBUG modem << Attempting to boot from address 0x8200.
    2022-08-15T01:40:56.453Z DEBUG modem << Verifying signature against key 0.
    2022-08-15T01:40:56.455Z DEBUG modem << Hash: 0x22...3a
    2022-08-15T01:40:56.474Z DEBUG modem << Firmware signature verified.
    2022-08-15T01:40:56.478Z DEBUG modem << Firmware version 1
    2022-08-15T01:40:56.483Z DEBUG modem << Booting (0x8200).
    2022-08-15T01:40:56.736Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-15T01:40:56.738Z DEBUG modem << I: Starting bootloader
    2022-08-15T01:40:56.745Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-15T01:40:56.751Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-15T01:40:56.753Z DEBUG modem << I: Boot source: none
    2022-08-15T01:40:56.760Z DEBUG modem << I: Swap type: none
    2022-08-15T01:40:56.765Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-15T01:40:56.768Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    2022-08-15T01:40:56.770Z DEBUG modem << I: Boot source: none
    2022-08-15T01:40:56.775Z DEBUG modem << I: Swap type: none
    2022-08-15T01:40:56.859Z DEBUG modem << I: Bootloader chainload address offset: 0x28000
    2022-08-15T01:40:56.862Z DEBUG modem << I: Jumping to the first image slot
    2022-08-15T01:40:57.326Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-08-15T01:40:58.332Z DEBUG modem << [00:00:00.199,645] [0m<inf> app_event_manager: APP_EVT_START[0m
    2022-08-15T01:40:58.370Z DEBUG modem << [00:00:00.200,775] [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED[0m
    2022-08-15T01:40:58.371Z DEBUG modem << [00:00:00.202,606] [1;33m<wrn> nrf_cloud_transport: Not configured to for runtime client ID, ignoring[0m
    2022-08-15T01:40:58.375Z DEBUG modem << [00:00:00.252,716] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING[0m
    2022-08-15T01:40:59.362Z DEBUG modem << [00:00:01.228,393] [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT[0m
    2022-08-15T01:40:59.369Z DEBUG modem << [00:00:01.228,942] [0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE[0m
    2022-08-15T01:41:20.009Z DEBUG modem << %CESQ: 52,2,17,2
    2022-08-15T01:41:20.022Z DEBUG modem << +CEREG: 2,"1D2D","0D2A8A4E",9
    2022-08-15T01:41:20.303Z DEBUG modem << +CSCON: 1
    2022-08-15T01:41:21.020Z DEBUG modem << [00:00:22.886,230] [0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
    2022-08-15T01:41:21.027Z DEBUG modem << [00:00:22.886,871] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2022-08-15T01:41:21.504Z DEBUG modem << %CESQ: 52,2,22,3
    2022-08-15T01:41:21.818Z DEBUG modem << %MDMEV: SEARCH STATUS 2
    2022-08-15T01:41:21.823Z DEBUG modem << +CEREG: 1,"1D2D","0D2A8A4E",9,,,"00001010","00100001"
    2022-08-15T01:41:21.845Z DEBUG modem << %XTIME: "23","22805110141223","00"
    2022-08-15T01:41:22.831Z DEBUG modem << [00:00:24.697,296] [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED[0m
    2022-08-15T01:41:22.838Z DEBUG modem << [00:00:24.697,937] [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
    2022-08-15T01:41:22.846Z DEBUG modem << [00:00:24.699,279] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-08-15T01:41:22.855Z DEBUG modem << [00:00:24.699,279] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
    2022-08-15T01:41:22.862Z DEBUG modem << [00:00:24.699,462] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-08-15T01:41:22.868Z DEBUG modem << [00:00:24.700,958] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-08-15T01:41:22.875Z DEBUG modem << [00:00:24.717,773] [0m<inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED[0m
    2022-08-15T01:41:43.400Z DEBUG modem << +CSCON: 0
    2022-08-15T01:41:45.568Z DEBUG modem << %CESQ: 48,2,12,1
    2022-08-15T01:41:45.574Z DEBUG modem << +CEREG: 1,"1D2D","008D2750",9,,,"00001010","00100001"
    2022-08-15T01:41:46.581Z DEBUG modem << [00:00:48.447,631] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2022-08-15T01:41:54.834Z DEBUG modem << [00:00:56.699,462] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT[0m
    2022-08-15T01:41:54.842Z DEBUG modem << [00:00:56.699,981] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
    2022-08-15T01:41:54.851Z DEBUG modem << [00:00:56.699,981] [1;33m<wrn> cloud_module: New connection attempt in 64 seconds if not successful[0m
    2022-08-15T01:41:54.858Z DEBUG modem << [00:00:56.700,134] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-08-15T01:41:54.864Z DEBUG modem << [00:00:56.709,564] [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING[0m
    2022-08-15T01:41:56.258Z DEBUG modem << %CESQ: 59,2,19,2
    2022-08-15T01:41:56.263Z DEBUG modem << +CEREG: 1,"1D2D","0D2A8A4F",9,,,"00001010","00100001"
    2022-08-15T01:41:57.271Z DEBUG modem << [00:00:59.136,932] [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
    2022-08-15T01:41:58.329Z DEBUG modem << %CESQ: 60,3,26,3
    2022-08-15T01:42:00.901Z DEBUG modem << %CESQ: 56,2,11,1
    2022-08-15T01:42:03.402Z DEBUG modem << %CESQ: 255,0,255,0
    2022-08-15T01:42:36.905Z DEBUG modem >> AT+CGDCONT?
    2022-08-15T01:42:36.921Z DEBUG modem << +CGDCONT: 0,"IP","cmnbiot","100.83.1.200",0,0
    2022-08-15T01:42:36.932Z DEBUG modem << OK
    Peter.Min
  • Hello Peter.Min,
    Sorry about the delay. I asked about this internally, which provided me with some options for you.
    You can take a look at the PDN library to configure legacy PCO (Protocol Configuration Options). The AT command %XPCO can also be used to subscribe to PCO notifications and %XEPCO=0 to select PCO to be used.
    Additionally, providing us with a modem trace will be helpful for us to figure out what fails with the connection to nRF Cloud.
    BR,
    Maria
