nrf connect sdk example periodic advertising stop changing mac address
HI guys I am working on nrf connect sdk v2.0.0, I am trying to modify periodic_adv example to stop changing mac address every time an advertising restart.
#include <bluetooth/bluetooth.h>
static uint8_t mfg_data[] = { 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10,
							  0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10};
static const struct bt_data ad[] = {
	BT_DATA(BT_DATA_MANUFACTURER_DATA, mfg_data, 40),
void main(void)
	struct bt_le_ext_adv *adv;
	int err;
	printk("Starting Periodic Advertising Demo\n");
	/* Initialize the Bluetooth Subsystem */
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	/* Create a non-connectable non-scannable advertising set */
	err = bt_le_ext_adv_create(BT_LE_EXT_ADV_NCONN_NAME, NULL, &adv); //  BT_LE_EXT_ADV_NCONN_NAME  BT_LE_EXT_ADV_SCAN_NAME
	if (err) {
		printk("Failed to create advertising set (err %d)\n", err);
		return;
	/* Set periodic advertising parameters */
	err = bt_le_per_adv_set_param(adv, BT_LE_PER_ADV_DEFAULT);
	if (err) {
		printk("Failed to set periodic advertising parameters"
		       " (err %d)\n", err);
		return;
	/* Enable Periodic Advertising */
	err = bt_le_per_adv_start(adv);
	if (err) {
		printk("Failed to enable periodic advertising (err %d)\n", err);
		return;
	while (true) {
		printk("Start Extended Advertising...");
		err = bt_le_ext_adv_start(adv, BT_LE_EXT_ADV_START_DEFAULT);
		if (err) {
			printk("Failed to start extended advertising "
			       "(err %d)\n", err);
			return;
		printk("done.\n");
		k_sleep(K_SECONDS(3));
		printk("Stop Extended Advertising...");
		err = bt_le_ext_adv_stop(adv);
		if (err) {
			printk("Failed to stop extended advertising "
			       "(err %d)\n", err);
			return;
		printk("done.\n");
		k_sleep(K_SECONDS(1));
