Hello All,
I am using RTC interrupt handle on the NRF5340 kit to set the event using k_event_post API from the interrupt context and when I try to wait on this event in the main function using k_event_wait it is never set the event and when I tried to debug using the NRF5340 kit debugger it works using the debugger but when the NRF controller run in freerun mode it didn't work.
and here is the example I am using to test this scenario.
#include <zephyr.h> #include <sys/util.h> #include <sys/printk.h> #include <string.h> #include <stdlib.h> #include <nrfx_rtc.h> #include <nrfx_timer.h> #include <nrfx_dppi.h> #include <nrfx_gpiote.h> #include <hal/nrf_gpiote.h> #include <hal/nrf_timer.h> #include <hal/nrf_gpio.h> #define LED_0 28 #define LED_1 29 #define LED_2 30 #define COMPARE_COUNTERTIME 3 #define RTC_EVENT_PENDING (1 << 2) K_EVENT_DEFINE(RTC_events); const nrfx_rtc_t rtc = NRFX_RTC_INSTANCE(0); uint32_t event_mask; static void rtc_handler(nrfx_rtc_int_type_t int_type) { if (int_type == NRFX_RTC_INT_COMPARE0) { nrf_gpio_pin_toggle(LED_0); } else if (int_type == NRFX_RTC_INT_TICK) { nrf_gpio_pin_toggle(LED_1); printk("Event LED_1!\n"); k_event_post(&RTC_events, RTC_EVENT_PENDING); } } static void rtc_config(void) { uint32_t err_code; nrfx_rtc_config_t config = NRFX_RTC_DEFAULT_CONFIG; config.prescaler = 4095; err_code = nrfx_rtc_init(&rtc, &config, rtc_handler); if (err_code != NRFX_SUCCESS) { printk("Failure in setup\n"); return; } nrfx_rtc_tick_enable(&rtc, true); err_code = nrfx_rtc_cc_set(&rtc, 0, COMPARE_COUNTERTIME * 8, true); if (err_code != NRFX_SUCCESS) { printk("Failure in setup\n"); return; } nrfx_rtc_enable(&rtc); } static void manual_isr_setup() { IRQ_DIRECT_CONNECT(RTC0_IRQn, 0, nrfx_rtc_0_irq_handler, 0); irq_enable(RTC0_IRQn); } void main(void) { printk("Starting rtc sample!\n"); nrf_gpio_cfg_output(LED_0); nrf_gpio_cfg_output(LED_1); nrf_gpio_cfg_output(LED_2); rtc_config(); manual_isr_setup(); while(1) { uint32_t event_mask = k_event_wait(&RTC_events, RTC_EVENT_PENDING, true , K_FOREVER); printk("Event Started!\n"); if(event_mask & RTC_EVENT_PENDING) { nrf_gpio_pin_toggle(LED_2); printk("Event LED_2!\n"); } } }
