Invalid toolchain installation nrfprog path issue
Fresh ubuntu install of 20.04
Followed the tutorial but still get the following error:
Is there a separate path setting inside visual code?
  • I had to comment out the following lines of the .postinst file to get the nrf tools properly installed and visible
    This looks correct to me - apart from the error message - what happens when you attempt to flash an application through the VSC GUI? Are you able to perform commands such as nrfjprog --version in your terminal?
    Karl
  • Oh, I did not see your comment until now.
    Strange that you have to comment out this - could you still show me the output of the two things I mentioned in my other comment, with these lines of code still in place?
    With these outputs I can mark this for internal review by our nRF Connect SDK command line tool developers.
    Karl
    The nrfjprog worked fine from the command line, But everything in VCS said i had not installed it, I am afraid I did not try the VCS terminal part at this stage.
    But when investigating, the .deb package gave me this error
    billy@ubuntu:~/Downloads$ sudo apt install ./nrf-command-line-tools_10.17.0_amd64.deb
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Note, selecting 'nrf-command-line-tools' instead of './nrf-command-line-tools_10.17.0_amd64.deb'
    nrf-command-line-tools is already the newest version (10.17.0).
    0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
    1 not fully installed or removed.
    After this operation, 0 B of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Setting up nrf-command-line-tools (10.17.0) ...
    dpkg: error: dpkg database lock is locked by another process
    dpkg: error processing package nrf-command-line-tools (--configure):
     installed nrf-command-line-tools package post-installation script subprocess returned error exit status 2
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    This is what I fixed by commenting the lines previously mentioned.  I am in a VMWare VM, after the fix, everything installed without error and VCS works now
    Thank you for the detailed report and log of the update - I will forward this to the developers.
    I am glad to hear that your issue is resolved now! :)
    Please do not hesitate to open another ticket if you should encounter any other issues or questions in the future.
    Karl
