Peripheral/radio NRF5 examples not working
We are trying to write a proprietary protocol following the documentation for the RADIO peripheral using the NRF Connect SDK 2.0.
The TX side seems to be working, and all the events (READY, ADDRESS, END,.. ) are raised as expected. On the RX side, the system never receives a packet (Stuck while waiting for the END event)
To troubleshoot this issue, we have also ported the NRF5 SDK radio/transmitter and radio/receiver examples (Minimal changes necessary), but no communication is achieved either.
The hardware has been tested with some BLE examples and it seems to work fine.
Is there anything else that we are missing or that needs to be done when using the new SDK and the RADIO peripheral in this way?
#include "hal/nrf_radio.h"
#include "hal/nrf_clock.h"
#include "zephyr.h"
#include "string.h"
/* These are set to zero as ShockBurst packets don't have corresponding fields. */
#define PACKET_S1_FIELD_SIZE      (0UL)  /**< Packet S1 field size in bits. */
#define PACKET_S0_FIELD_SIZE      (0UL)  /**< Packet S0 field size in bits. */
#define PACKET_LENGTH_FIELD_SIZE  (0UL)  /**< Packet length field size in bits. */
#define PACKET_BASE_ADDRESS_LENGTH  (4UL)                   //!< Packet base address length field size in bytes
#define PACKET_STATIC_LENGTH        (1UL)                   //!< Packet static length in bytes
#define PACKET_PAYLOAD_MAXSIZE      (PACKET_STATIC_LENGTH)  //!< Packet payload maximum size in bytes
 * @brief Function for swapping/mirroring bits in a byte.
 *@verbatim
 * output_bit_7 = input_bit_0
 * output_bit_6 = input_bit_1
 * output_bit_0 = input_bit_7
 *@endverbatim
 * @param[in] inp is the input byte to be swapped.
 * @return
 * Returns the swapped/mirrored input byte.
static uint32_t swap_bits(uint32_t inp);
 * @brief Function for swapping bits in a 32 bit word for each byte individually.
 * The bits are swapped as follows:
 * @verbatim
 * output[31:24] = input[24:31]
 * output[23:16] = input[16:23]
 * output[15:8]  = input[8:15]
 * output[7:0]   = input[0:7]
 * @endverbatim
 * @param[in] input is the input word to be swapped.
 * @return
 * Returns the swapped input byte.
static uint32_t bytewise_bitswap(uint32_t inp);
    uint32_t i;
    uint32_t retval = 0;
    inp = (inp & 0x000000FFUL);
    for (i = 0; i < 8; i++)
        retval |= ((inp >> i) & 0x01) << (7 - i);
    return retval;
      return (swap_bits(inp >> 24) << 24)
           | (swap_bits(inp >> 16) << 16)
           | (swap_bits(inp >> 8) << 8)
           | (swap_bits(inp));
 * @brief Function for configuring the radio to operate in ShockBurst compatible mode.
 * To configure the application running on nRF24L series devices:
 * @verbatim
 * uint8_t tx_address[5] = { 0xC0, 0x01, 0x23, 0x45, 0x67 };
 * hal_nrf_set_rf_channel(7);
 * hal_nrf_set_address_width(HAL_NRF_AW_5BYTES);
 * hal_nrf_set_address(HAL_NRF_TX, tx_address);
 * hal_nrf_set_address(HAL_NRF_PIPE0, tx_address);
 * hal_nrf_open_pipe(0, false);
 * hal_nrf_set_datarate(HAL_NRF_1MBPS);
 * hal_nrf_set_crc_mode(HAL_NRF_CRC_16BIT);
 * hal_nrf_setup_dynamic_payload(0xFF);
 * hal_nrf_enable_dynamic_payload(false);
 * @endverbatim
 * When transmitting packets with hal_nrf_write_tx_payload(const uint8_t *tx_pload, uint8_t length),
 * match the length with PACKET_STATIC_LENGTH.
 * hal_nrf_write_tx_payload(payload, PACKET_STATIC_LENGTH);
void radio_configure()
    // Radio config
    NRF_RADIO->TXPOWER   = (RADIO_TXPOWER_TXPOWER_0dBm << RADIO_TXPOWER_TXPOWER_Pos);
    NRF_RADIO->FREQUENCY = 7UL;  // Frequency bin 7, 2407MHz
    NRF_RADIO->MODE      = (RADIO_MODE_MODE_Nrf_1Mbit << RADIO_MODE_MODE_Pos);
    // Radio address config
    NRF_RADIO->PREFIX0 =
        ((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC1) << 8)  // Prefix byte of address 1 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
    NRF_RADIO->PREFIX1 =
        ((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
    NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL);  // Base address for prefix 0 converted to nRF24L series format
    NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL);  // Base address for prefix 1-7 converted to nRF24L series format
    NRF_RADIO->TXADDRESS   = 0x00UL;  // Set device address 0 to use when transmitting
    NRF_RADIO->RXADDRESSES = 0x01UL;  // Enable device address 0 to use to select which addresses to receive
    // Packet configuration
    NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE     << RADIO_PCNF0_S1LEN_Pos) |
                       (PACKET_S0_FIELD_SIZE     << RADIO_PCNF0_S0LEN_Pos) |
                       (PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
    NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
                       (RADIO_PCNF1_ENDIAN_Big       << RADIO_PCNF1_ENDIAN_Pos)  |
                       (PACKET_BASE_ADDRESS_LENGTH   << RADIO_PCNF1_BALEN_Pos)   |
                       (PACKET_STATIC_LENGTH         << RADIO_PCNF1_STATLEN_Pos) |
                       (PACKET_PAYLOAD_MAXSIZE       << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
    // CRC Config
    NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
    if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
        NRF_RADIO->CRCINIT = 0xFFFFUL;   // Initial value
        NRF_RADIO->CRCPOLY = 0x11021UL;  // CRC poly: x^16 + x^12^x^5 + 1
    else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
        NRF_RADIO->CRCINIT = 0xFFUL;   // Initial value
        NRF_RADIO->CRCPOLY = 0x107UL;  // CRC poly: x^8 + x^2^x^1 + 1
static uint32_t packet;              /**< Packet to transmit. */
void clock_initialization()
    /* Start 16 MHz crystal oscillator */
    NRF_CLOCK->TASKS_HFCLKSTART    = 1;
    /* Wait for the external oscillator to start up */
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        // Do nothing.
    /* Start low frequency crystal oscillator for app_timer(used by bsp)*/
   /* NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART    = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
        // Do nothing.
uint32_t read_packet()
    uint32_t result = 0;
    NRF_RADIO->EVENTS_READY = 0U;
    // Enable radio and wait for ready
    NRF_RADIO->TASKS_RXEN = 1U;
    while (NRF_RADIO->EVENTS_READY == 0U)
        // wait
    NRF_RADIO->EVENTS_END = 0U;
    // Start listening and wait for address received event
    NRF_RADIO->TASKS_START = 1U;
    // Wait for end of packet or buttons state changed
    while (NRF_RADIO->EVENTS_END == 0U)
        // wait
    if (NRF_RADIO->CRCSTATUS == 1U)
        result = packet;
    NRF_RADIO->EVENTS_DISABLED = 0U;
    // Disable radio
    NRF_RADIO->TASKS_DISABLE = 1U;
    while (NRF_RADIO->EVENTS_DISABLED == 0U)
        // wait
    return result;
void send_packet()
    // send the packet:
    NRF_RADIO->TASKS_TXEN   = 1;
        // wait
        // wait
    printk("Packet sent\n");
    // Disable radio
        // wait
void ConfigureRadio(int max_payload_size){
void RadioReceivePacketForever(uint8_t* bufferOut, uint8_t bufferSize, uint8_t* messageSizeOut){
    RadioReceivePacket(bufferOut, bufferSize, messageSizeOut, -1);
void RadioReceivePacket(uint8_t* bufferOut, uint8_t bufferSize, uint8_t* messageSizeOut, int32_t microsTimeout){
    clock_initialization();
    // Set radio configuration parameters
    radio_configure();
    NRF_RADIO->PACKETPTR = (uint32_t)&packet;
    //err_code = bsp_indication_set(BSP_INDICATE_USER_STATE_OFF);
   // NRF_LOG_INFO("Wait for first packet\r\n");
   // APP_ERROR_CHECK(err_code);
   // NRF_LOG_FLUSH();
    while (true)
        uint32_t received = read_packet();
      // err_code = bsp_indication_set(BSP_INDICATE_RCV_OK);
       // NRF_LOG_INFO("Packet was received\r\n");
       // NRF_LOG_INFO("The contents of the package is %u\r\n", (unsigned int)received);
       // NRF_LOG_FLUSH();
       printk("Packet RX!!!");
void RadioSendPacket(uint8_t* bufferIn, uint8_t bufferSize){
    radio_configure();
    // Set payload pointer
    packet=100;
    while (true)
        if (packet != 0)
            send_packet();
            printk("packet sent!\n");
          //  packet = 0;
  • Most of the code looks similar in terms of how you are configuring tx/tx and receive/send implementation. However, I cannot see the contexts in which send/receive are being called. I cannot see the timings and also I do not know if there could be overlap in attempting to do send/receive at the same time? I cannot see the logic to serialize the TX and RX. IF you are able to do TX, then the radio is atleast working ok, it seems like it is only the configuration of the radio in rx mode at the right time.
    Did the radio peripheral example for the sdk as is work ok for you?
  • Managed to find the solution:
    Zephyr will automatically manage the HFCLK, so you can't just enable it using the CLOCK HAL.
    If you want to keep the clock enabled, you should also call "z_nrf_clock_bt_ctlr_hf_request()"
