I am working on nrf52840 using nrf connect sdk v2.0.0 example periodic_adv, nrf52840 is prodcasting extended advertising, my app is running on Sony Xperia 1 with bluetooth 5.0 can scan the device, but how can I get the advertising data I print out the scanresult but it shows {}, how can I get the extended advertising data?
Android mainactivity
package com.example.tryble_scanner; import androidx.activity.result.ActivityResultLauncher; import androidx.activity.result.contract.ActivityResultContracts; import androidx.appcompat.app.AppCompatActivity; import android.Manifest; import android.bluetooth.BluetoothAdapter; import android.bluetooth.BluetoothDevice; import android.bluetooth.BluetoothManager; import android.bluetooth.le.BluetoothLeScanner; import android.bluetooth.le.ScanCallback; import android.bluetooth.le.ScanFilter; import android.bluetooth.le.ScanResult; import android.bluetooth.le.ScanSettings; import android.content.Intent; import android.os.Build; import android.os.Bundle; import android.os.Handler; import android.util.Log; import android.util.SparseArray; import android.view.View; import android.widget.Button; import android.widget.Toast; import java.io.UnsupportedEncodingException; import java.nio.ByteBuffer; import java.nio.ByteOrder; import java.nio.charset.StandardCharsets; import java.util.ArrayList; import java.util.Arrays; import java.util.List; import java.util.UUID; public class MainActivity extends AppCompatActivity { private BluetoothAdapter mBluetoothAdapter = null; private BluetoothLeScanner mBluetoothLeScanner = null; public static final int REQUEST_BT_PERMISSIONS = 0; public static final int REQUEST_BT_ENABLE = 1; private boolean mScanning = false; private Handler mHandler = null; private ScanCallback mLeScanCallBack1 = new ScanCallback() { @Override public void onScanResult(int callbackType, final ScanResult result) { //super.onScanResult(callbackType, result); String data=ConverttoString(result.getScanRecord().getManufacturerSpecificData()); BluetoothDevice btdevice = result.getDevice(); Log.d("BLE", btdevice.getAddress()); Log.d("BLE",data); } @Override public void onScanFailed(int errorCode) { super.onScanFailed(errorCode); Log.d("BLE", "error"); } }; private ScanCallback mLeScanCallBack2=new ScanCallback() { @Override public void onScanResult(int callbackType, ScanResult result) { Log.d("BLE","scan stop"); } @Override public void onScanFailed(int errorCode) { Log.d("BLE","stop scan failed"); } }; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); Button btnScan = (Button) findViewById(R.id.btnScan); BluetoothManager bluetoothManager = getSystemService(BluetoothManager.class); mBluetoothAdapter = bluetoothManager.getAdapter(); mBluetoothLeScanner = mBluetoothAdapter.getBluetoothLeScanner(); this.mHandler = new Handler(); } public void stop_scan(View view) { Log.d("Ble","scan stop pressed"); // mBluetoothLeScanner.stopScan(mLeScanCallback2); mBluetoothAdapter.getBluetoothLeScanner().stopScan(mLeScanCallBack2); } public void onBtnScan(View view) { Log.i("Btn","get click"); checkBTPermission(); String[] names=new String[]{"Auden test"}; List<ScanFilter> filters=null; if(names != null){ filters=new ArrayList<>(); for(String name:names){ ScanFilter filter=new ScanFilter.Builder().setDeviceName(name).build(); filters.add(filter); } } ScanSettings scanSettings = new ScanSettings.Builder() //.setScanMode(ScanSettings.SCAN_MODE_LOW_LATENCY) //.setCallbackType(ScanSettings.CALLBACK_TYPE_ALL_MATCHES) //.setMatchMode(ScanSettings.MATCH_MODE_AGGRESSIVE) //.setNumOfMatches(ScanSettings.MATCH_NUM_ONE_ADVERTISEMENT) //.setReportDelay(0L) .setLegacy(false) .build(); if(mBluetoothLeScanner==null){ Log.i("BLE","could not get scanner"); }else{ mBluetoothLeScanner.startScan(filters,scanSettings,mLeScanCallBack1); //filters,scanSettings,mLeScanCallback } } private void checkBTPermission(){ if(Build.VERSION.SDK_INT>Build.VERSION_CODES.LOLLIPOP){ int pc=this.checkSelfPermission("Manifest.permission.ACCESS_FINE_LOCATION"); pc+=this.checkSelfPermission("Manifest.permission.ACCESS_COARSE_LOCATION"); if(pc!=0){ this.requestPermissions(new String[]{Manifest.permission.ACCESS_FINE_LOCATION,Manifest.permission.ACCESS_COARSE_LOCATION},1001); }else { Log.d("BLE","checkBT permission"); } } } public static String ConverttoString (SparseArray<byte[]> array) { if (array == null) { return "null"; } if (array.size() == 0) { return "{}"; } StringBuilder buffer = new StringBuilder(); buffer.append('{'); for (int i = 0; i < array.size(); ++i) { buffer.append(array.keyAt(i)).append("=").append(Arrays.toString(array.valueAt(i))); } buffer.append('}'); Log.d("convert",buffer.toString()); return buffer.toString(); } }
nrf52840
/* * Copyright (c) 2020 Nordic Semiconductor ASA * * SPDX-License-Identifier: Apache-2.0 */ #include <bluetooth/bluetooth.h> static uint8_t mfg_data[] = { 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10, 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10, 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10, 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10}; static const struct bt_data ad[] = { BT_DATA(BT_DATA_MANUFACTURER_DATA, mfg_data, 40), }; void main(void) { struct bt_le_ext_adv *adv; int err; printk("Starting Periodic Advertising Demo\n"); /* Initialize the Bluetooth Subsystem */ err = bt_enable(NULL); if (err) { printk("Bluetooth init failed (err %d)\n", err); return; } /* Create a non-connectable non-scannable advertising set */ err = bt_le_ext_adv_create(BT_LE_EXT_ADV_NCONN_NAME, NULL, &adv); // BT_LE_EXT_ADV_NCONN_NAME BT_LE_EXT_ADV_SCAN_NAME if (err) { printk("Failed to create advertising set (err %d)\n", err); return; } /* Set periodic advertising parameters */ err = bt_le_per_adv_set_param(adv, BT_LE_PER_ADV_DEFAULT); if (err) { printk("Failed to set periodic advertising parameters" " (err %d)\n", err); return; } /* Enable Periodic Advertising */ err = bt_le_per_adv_start(adv); if (err) { printk("Failed to enable periodic advertising (err %d)\n", err); return; } while (true) { printk("Start Extended Advertising..."); err = bt_le_ext_adv_start(adv, BT_LE_EXT_ADV_START_DEFAULT); if (err) { printk("Failed to start extended advertising " "(err %d)\n", err); return; } printk("done.\n"); k_sleep(K_SECONDS(3000)); printk("Stop Extended Advertising..."); err = bt_le_ext_adv_stop(adv); if (err) { printk("Failed to stop extended advertising " "(err %d)\n", err); return; } printk("done.\n"); k_sleep(K_SECONDS(1)); } }
