Hi All,
Today I am migrating my project from ncs 1.9.1 to ncs 2.0.0.
The project was building find with ncs 1.9.1
But I do got this build warning with ncs 2.0.0:
-- Found Python3: C:/cm/ncs/toolchains/v2.0.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter === child image mcuboot - begin === loading initial cache file C:/cm/projects/projectX/build/mcuboot/child_image_preload.cmake CMake Warning (dev) at C:\cm\projects\projectX\build\mcuboot\child_image_preload.cmake:5 (set): Syntax error in cmake code at C:\cm\projects\projectX\build\mcuboot\child_image_preload.cmake:5 when parsing string C:\cm\projects\my_own_modules\nrf52_fanboy_SDK Invalid escape sequence \c Policy CMP0010 is not set: Bad variable reference syntax is an error. Run "cmake --help-policy CMP0010" for policy details. Use the cmake_policy command to set the policy and suppress this warning. This warning is for project developers. Use -Wno-dev to suppress it. Loading Zephyr default modules (Zephyr base (cached)). ... CMake Warning at C:\cm\ncs\v2.0.0\zephyr\CMakeLists.txt:814 (message): No SOURCES given to Zephyr library: drivers__console Excluding target from build. -- Configuring done -- Generating done
Any idea / hint / tip how to fix this correctly.
