HTTPS client POST/PUT to azure IOT hub failing at socket connect()
The goal is to push a blob to a azure storage container using https on nRF9160.
I am using the nRF/zephyr  socket library to do basic HTTPS POST/PUT
CONFIG_NET_SOCKETS_OFFLOAD_TLS is set to "n" meaning we are not using the certificates in the modem.
Instead add the public and private certificates (signed by CA root) to the TLS using
tls_credential_add(...)
While the same HTTPS requests work on a Postman together with the generated certificates. I am able to upload and append to a storage container using the same PUT/POST methods on postman.
But doing the same using the socket library fails. I get a "connect() failed : err: 111" error which is a "connection refused" error.
Here is the core part of the HTTP request for blob URI.
// A https request using sockets. Derived from https_client sample from nordic.
int send_http_blob_req(const char* blobname)
	int err;
	int fd;
	char *p;
	int bytes;
	size_t off;
	struct addrinfo *res;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM,
        printk("Requesting URI for \"%s\"\r\n", blobname);
        create_request_header(http_header, sizeof(http_header), HOST, DEVICE_NAME, blobname);
	err = getaddrinfo(HOST, NULL, &hints, &res);
	if (err) {
		printk("getaddrinfo() failed, err %d\n", errno);
		return err;
	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTPS_PORT);
	fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
	if (fd == -1) {
		printk("Failed to open socket!\n");
		goto clean_up;
	/* Setup TLS socket options */
	err = tls_setup(fd, HOST);
	if (err) {
		goto clean_up;
	printk("Connecting to %s\n", HOST);
	err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
	if (err) {
		printk("connect() failed, err: %d\n", errno);
		goto clean_up;
	off = 0;
	do {
		bytes = send(fd, &http_header[off], strlen(http_header) - off, 0);
		if (bytes < 0) {
			printk("send() failed, err %d\n", errno);
			goto clean_up;
		off += bytes;
	} while (off < strlen(http_header));
	printk("Sent %d bytes\n", off);
	off = 0;
	do {
		bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off, 0);
		if (bytes < 0) {
			printk("recv() failed, err %d\n", errno);
			goto clean_up;
		off += bytes;
	} while (bytes != 0 /* peer closed connection */);
        // parse sasToken and correlationId
        cJSON* root = cJSON_Parse(strchr(recv_buf, '{'));
        // todo: handle failed request
        strncpy(correlationId, cJSON_GetObjectItem(root, "correlationId")->valuestring, 256);
        strncpy(sasToken, cJSON_GetObjectItem(root, "sasToken")->valuestring, 256);
        strncpy(storageHost, cJSON_GetObjectItem(root, "hostName")->valuestring, 256);
        strncpy(storageContainer, cJSON_GetObjectItem(root, "containerName")->valuestring, 64);
        strncpy(blobName, cJSON_GetObjectItem(root, "blobName")->valuestring, 64);
        printk("correlationId=%s\r\n", correlationId);
        printk("sasToken=%s\r\n", sasToken);
        printk("hostName=%s\r\n", storageHost);
        printk("containerName=%s\r\n", storageContainer);
        printk("blobName=%s\r\n", blobName);
        cJSON_Delete(root);
	printk("Received %d bytes\n", off);
	/* Print HTTP response */
	p = strstr(recv_buf, "\r\n");
	if (p) {
		off = p - recv_buf;
		recv_buf[off + 1] = '\0';
		printk("\n>\t %s\n\n", recv_buf);
	printk("Finished, closing socket.\n");
clean_up:
	freeaddrinfo(res);
	(void)close(fd);
        return 0;
void create_request_header(char* buf, size_t bufsize, const char* hostname,
  const char* devicename, const char* blobname)
  int content_length = 15 + strlen(blobname);
  snprintf(buf, bufsize,
    "POST /devices/%s/files?api-version=2018-06-30 HTTP/1.1\r\n"
    "Host: %s\r\n"
    "Accept: application/json\r\n"
    "Content-Type: application/json\r\n"
    "Connection: close\r\n"
    "Content-Length: %d\r\n"
    "\r\n"
    "{\"blobName\":\"%s\"}",
    devicename, hostname, content_length, blobname);
What am I doing wrong? What could be the cause for connect() err:111?
I am using ncs version1.8.0.
