nrf21540 radio test for nrf52820
Hi All!
I am using nrf5 SDK 17.0.1 and using a radio test example to extend the range of nrf52833/20. Able to compile the example for nrf52833(pca10100).
Now the issue is that I migrated the code as per the instruction on nordic semi docs from pca10100 to pca10100e for nrf52820.
I am getting the following errors as mentioned in the image.
multiple definitions of `UARTE0_UART0_IRQHandler';
I disabled the Uart_enable in sdkconfig.h. Although the error removes but the controller is stuck and unable to run from the main.
I also attached the .emproject file where I tried to port the code from nrf52833 to nrf52820
<!DOCTYPE CrossStudio_Project_File>
<solution Name="radio_test_pca10100e" target="8" version="2">
  <project Name="radio_test_pca10100e">
    <configuration
      Name="Common"
      arm_architecture="v7EM"
      arm_core_type="Cortex-M4"
      arm_endian="Little"
      arm_fp_abi="Soft"
      arm_fpu_type="Soft"
      arm_linker_heap_size="2048"
      arm_linker_process_stack_size="0"
      arm_linker_stack_size="2048"
      arm_linker_treat_warnings_as_errors="No"
      arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
      arm_target_device_name="nRF52820_xxAA"
      arm_target_interface_type="SWD"
      c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10112;BSP_DEFINES_ONLY;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52820_XXAA;NRF21540_DRIVER_ENABLE=1;NRFX_COREDEP_DELAY_US_LOOP_CYCLES=3"
      c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/boards;../../../../../../components/drivers_ext/nrf21540;../../../../../../components/drivers_nrf/nrf_soc_nosd;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bsp;../../../../../../components/libraries/cli;../../../../../../components/libraries/cli/uart;../../../../../../components/libraries/delay;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/fifo;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/memobj;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/ringbuf;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/strerror;../../../../../../components/libraries/timer;../../../../../../components/libraries/uart;../../../../../../components/libraries/util;../../../../../../components/toolchain/cmsis/include;../../..;../../../../../../external/fnmatch;../../../../../../external/fprintf;../../../../../../external/segger_rtt;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config"
      debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52820.svd"
      debug_start_from_entry_point_symbol="No"
      debug_target_connection="J-Link"
      gcc_debugging_level="Level 3"
      gcc_entry_point="Reset_Handler"
      linker_output_format="hex"
      linker_printf_fmt_level="long"
      linker_printf_width_precision_supported="Yes"
      linker_scanf_fmt_level="long"
      linker_section_placement_file="flash_placement.xml"
      linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x40000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x8000;FLASH_START=0x27000;FLASH_SIZE=0x19000;RAM_START=0x20002ae8;RAM_SIZE=0x5518"
      linker_section_placements_segments="FLASH1 RX 0x0 0x40000;RAM1 RWX 0x20000000 0x8000"
      macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
      project_directory=""
      project_type="Executable" />
    <folder Name="Segger Startup Files">
      <file file_name="$(StudioDir)/source/thumb_crt0.s" />
    </folder>
    <folder Name="nRF_Log">
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_uart.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_default_backends.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_frontend.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_str_formatter.c" />
    </folder>
    <folder Name="Board Definition">
      <file file_name="../../../../../../components/boards/boards.c" />
    </folder>
    <folder Name="nRF_Libraries">
      <file file_name="../../../../../../components/libraries/util/app_error.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
      <file file_name="../../../../../../components/libraries/fifo/app_fifo.c" />
      <file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
      <file file_name="../../../../../../components/libraries/timer/app_timer2.c" />
      <file file_name="../../../../../../components/libraries/uart/app_uart_fifo.c" />
      <file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
      <file file_name="../../../../../../components/libraries/timer/drv_rtc.c" />
      <file file_name="../../../../../../external/fnmatch/fnmatch.c" />
      <file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
      <file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
      <file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
      <file file_name="../../../../../../components/libraries/cli/nrf_cli.c" />
      <file file_name="../../../../../../components/libraries/cli/uart/nrf_cli_uart.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
      <file file_name="../../../../../../components/libraries/memobj/nrf_memobj.c" />
      <file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
      <file file_name="../../../../../../components/libraries/queue/nrf_queue.c" />
      <file file_name="../../../../../../components/libraries/ringbuf/nrf_ringbuf.c" />
      <file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
      <file file_name="../../../../../../components/libraries/sortlist/nrf_sortlist.c" />
      <file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
      <file file_name="../../../../../../components/libraries/uart/retarget.c" />
      <file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
    </folder>
    <folder Name="nRF_Drivers">
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
      <file file_name="../../../../../../components/drivers_nrf/nrf_soc_nosd/nrf_nvic.c" />
      <file file_name="../../../../../../components/drivers_nrf/nrf_soc_nosd/nrf_soc.c" />
      <file file_name="../../../../../../modules/nrfx/soc/nrfx_atomic.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_timer.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
    </folder>
    <folder Name="Application">
      <file file_name="../../../main.c" />
      <file file_name="../../../radio_cmd.c" />
      <file file_name="../../../radio_test.c" />
      <file file_name="../config/sdk_config.h" />
    </folder>
    <folder Name="nRF_Segger_RTT">
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
    </folder>
    <folder Name="None">
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52820.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52820.c" />
    </folder>
    <folder Name="nRF_Drivers_External">
      <file file_name="../../../../../../components/drivers_ext/nrf21540/nrf21540.c" />
      <file file_name="../../../../../../components/drivers_ext/nrf21540/nrf21540_gpio.c" />
      <file file_name="../../../../../../components/drivers_ext/nrf21540/nrf21540_spi.c" />
      <file file_name="../../../../../../components/drivers_ext/nrf21540/nrf21540.h" />
      <file file_name="../../../../../../components/drivers_ext/nrf21540/nrf21540_gpio.h" />
      <file file_name="../../../../../../components/drivers_ext/nrf21540/nrf21540_spi.h" />
    </folder>
  </project>
  <configuration
    Name="Release"
    c_preprocessor_definitions="NDEBUG"
    gcc_optimization_level="Optimize For Size"
    link_time_optimization="No" />
  <configuration
    Name="Debug"
    c_preprocessor_definitions="DEBUG; DEBUG_NRF"
    gcc_optimization_level="None" />
</solution>
Can you please help in this regard? thanks in advance.
