i am not able make it as a controller
 Hy
i am using a nrf5349 Dk board ,i am able to build and flash the board.
but when i am using this by building and flashing the board with hci_uart .in the linux system i am not able to make it as a controller .can any one help me with the steps to be followed for the board to make it as a controller .
Thanks
  • Hi sigurd
    can you send me the hex file .the image which you flashed
    regards
    achyuth
  • Hi Sigurd,
    I am also trying to make 5340dk as controller only device.
    Can you please tell me the Config changes to be made for the same. I am using "v2.1.0-rc1" setup in  windows. able to  build and create but not able to use it as USB bluetooth dongle in linux.
    path of setup : D:\ncs\v2.1.0-rc1\zephyr\samples\bluetooth\hci_usb
    here is the build log:
    BGH48649@BGHMBCP0775 MINGW64 /d/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb ((v3.1.99-ncs1-rc1))
    $ west build -b nrf5340dk_nrf5340_cpuapp_ns
    -- Application: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb
    -- Using NCS Toolchain 2.0.0 for building. (D:/ncs/toolchains/v2.0.0/cmake)
    -- Found Python3: D:/ncs/toolchains/v2.0.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: D:/ncs/v2.1.0-rc1/zephyr/.cache
    -- Zephyr version: 3.1.99 (D:/ncs/v2.1.0-rc1/zephyr)
    -- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
    -- Board: nrf5340dk_nrf5340_cpuapp_ns
    -- Found host-tools: zephyr 0.14.1 (D:/ncs/toolchains/v2.0.0/opt/zephyr-sdk)
    -- Found dtc: D:/ncs/toolchains/v2.0.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: zephyr 0.14.1 (D:/ncs/toolchains/v2.0.0/opt/zephyr-sdk)
    -- Found BOARD.dts: D:/ncs/v2.1.0-rc1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_ns.dts
    -- Generated zephyr.dts: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/zephyr/dts.cmake
    Parsing D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/Kconfig
    Loaded configuration 'D:/ncs/v2.1.0-rc1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration 'D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/prj.conf'
    Configuration saved to 'D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 10.3.0
    -- The CXX compiler identification is GNU 10.3.0
    -- Found assembler: D:/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    CMake Warning at D:/ncs/v2.1.0-rc1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
    CONFIG_USB_DEVICE_VID has default value 0x2FE3.
    This value is only for testing and MUST be configured for USB products.
    === child image hci_rpmsg - CPUNET begin ===
    loading initial cache file D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg/child_image_preload.cmake
    -- Application: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_rpmsg
    -- Board: nrf5340dk_nrf5340_cpunet
    -- Found BOARD.dts: D:/ncs/v2.1.0-rc1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg/zephyr/dts.cmake
    Parsing D:/ncs/v2.1.0-rc1/zephyr/Kconfig
    Loaded configuration 'D:/ncs/v2.1.0-rc1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
    Merged configuration 'D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_rpmsg/prj.conf'
    Merged configuration 'D:/ncs/v2.1.0-rc1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Configuration saved to 'D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg/zephyr/include/generated/autoconf.h'
    -- libmetal version: 1.2.0 (D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_rpmsg)
    -- Build type:
    -- Host: Windows/AMD64
    -- Target: Generic/arm
    -- Machine: arm
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.2.0 (D:/ncs/v2.1.0-rc1/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS : -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/hci_rpmsg
    === child image hci_rpmsg - CPUNET end ===
    -- libmetal version: 1.2.0 (D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb)
    -- Build type:
    -- Machine: arm
    -- Machine: arm
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    [1/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkcs12.c.obj
    [2/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pem.c.obj
    [3/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkcs5.c.obj
    [4/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkparse.c.obj
    [5/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/dhm.c.obj
    [6/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/cipher.c.obj
    [7/317] Generating include/generated/version.h
    -- Zephyr version: 3.1.99 (D:/ncs/v2.1.0-rc1/zephyr), build: v3.1.99-ncs1-rc1
    [8/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkwrite.c.obj
    [9/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/cipher_wrap.c.obj
    [10/317] Creating directories for 'hci_rpmsg_subimage'
    [11/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pk.c.obj
    [12/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pk_wrap.c.obj
    [13/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/sha1.c.obj
    [14/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/md.c.obj
    [15/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/sha256.c.obj
    [16/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ripemd160.c.obj
    [17/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/md5.c.obj
    [18/317] No download step for 'hci_rpmsg_subimage'
    [19/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/sha512.c.obj
    [20/317] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [21/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/aesni.c.obj
    [22/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/aria.c.obj
    [23/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/cmac.c.obj
    [24/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/camellia.c.obj
    [25/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/des.c.obj
    [26/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ccm.c.obj
    [27/317] No update step for 'hci_rpmsg_subimage'
    [28/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecdsa.c.obj
    [29/317] Generating include/generated/driver-validation.h
    [30/317] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [31/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/chachapoly.c.obj
    [32/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecdh.c.obj
    [33/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecp_curves.c.obj
    [34/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecp.c.obj
    [35/317] No patch step for 'hci_rpmsg_subimage'
    [36/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/hkdf.c.obj
    [37/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/hmac_drbg.c.obj
    [38/317] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [39/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/rsa_alt_helpers.c.obj
    [40/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/gcm.c.obj
    [41/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/entropy.c.obj
    [42/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
    [43/317] No configure step for 'hci_rpmsg_subimage'
    [43/317] Performing build step for 'hci_rpmsg_subimage'
    [1/230] Generating include/generated/version.h
    [2/230] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [3/230] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [4/230] Generating include/generated/driver-validation.h
    [5/230] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [6/230] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [7/230] Generating include/generated/offsets.h
    [8/230] Building C object zephyr/CMakeFiles/zephyr.dir/D_/ncs/v2.1.0-rc1/modules/crypto/tinycrypt/lib/source/aes_encrypt.c.obj
    [9/230] Building C object zephyr/CMakeFiles/zephyr.dir/D_/ncs/v2.1.0-rc1/modules/crypto/tinycrypt/lib/source/aes_decrypt.c.obj
    [10/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_rpmsg.c.obj
    [11/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [12/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/backends/ipc_rpmsg_static_vrings.c.obj
    [13/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [14/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_static_vrings.c.obj
    [15/230] Building C object zephyr/CMakeFiles/zephyr.dir/D_/ncs/v2.1.0-rc1/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [16/230] Building C object zephyr/CMakeFiles/zephyr.dir/D_/ncs/v2.1.0-rc1/modules/crypto/tinycrypt/lib/source/utils.c.obj
    [17/230] Generating linker_zephyr_pre1.cmd
    [18/230] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [19/230] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [20/230] Generating linker_zephyr_pre0.cmd
    [21/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [22/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [23/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [24/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [25/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [26/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [27/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [28/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [29/230] Linking C static library zephyr\arch\common\libisr_tables.a
    [30/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [31/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [32/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [33/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [34/230] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [35/230] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [36/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [37/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [38/230] Linking C static library zephyr\arch\common\libarch__common.a
    [39/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [40/230] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [41/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [42/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [43/230] Linking C static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
    [44/230] Linking C static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
    [45/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [46/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [47/230] Building C object CMakeFiles/app.dir/src/main.c.obj
    [48/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [49/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [50/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [51/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [52/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [53/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [54/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [55/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [56/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [57/230] Linking C static library app\libapp.a
    [58/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [59/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [60/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [61/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [62/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [63/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [64/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [65/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [66/230] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [67/230] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
    [68/230] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [69/230] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [70/230] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [71/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/ipc_service.c.obj
    [72/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [73/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
    [74/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [75/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [76/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [77/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [78/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/dma.c.obj
    [79/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/device.c.obj
    [80/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/io.c.obj
    [81/230] Linking C static library zephyr\libzephyr.a
    [82/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/irq.c.obj
    [83/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/init.c.obj
    [84/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/version.c.obj
    [85/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/shmem.c.obj
    [86/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/alloc.c.obj
    [87/230] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [88/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/condition.c.obj
    [89/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/log.c.obj
    [90/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/softirq.c.obj
    [91/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/shmem.c.obj
    [92/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/irq.c.obj
    [93/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/device.c.obj
    [94/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/init.c.obj
    [95/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/log.c.obj
    [96/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/sys.c.obj
    [97/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/time.c.obj
    [98/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtqueue.c.obj
    [99/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtio.c.obj
    [100/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg.c.obj
    [101/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/version.c.obj
    [102/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg_virtio.c.obj
    [103/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/elf_loader.c.obj
    [104/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc.c.obj
    [105/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc_virtio.c.obj
    [106/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/rsc_table_parser.c.obj
    [107/230] Linking C static library modules\libmetal\libmetal\lib\libmetal.a
    [108/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [109/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [110/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [111/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [112/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [113/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [114/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [115/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [116/230] Linking C static library modules\open-amp\open-amp\lib\libopen_amp.a
    [117/230] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [118/230] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [119/230] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [120/230] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [121/230] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [122/230] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [123/230] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [124/230] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [125/230] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [126/230] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [127/230] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/log.c.obj
    [128/230] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [129/230] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
    [130/230] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_raw.c.obj
    [131/230] Linking C static library zephyr\lib\posix\liblib__posix.a
    [132/230] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [133/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [134/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [135/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [136/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [137/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [138/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [139/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [140/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [141/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [142/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [143/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [144/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [145/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [146/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [147/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [148/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [149/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [150/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [151/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [152/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [153/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [154/230] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [155/230] Linking C static library zephyr\subsys\bluetooth\common\libsubsys__bluetooth__common.a
    [156/230] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [157/230] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [158/230] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [159/230] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [160/230] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [161/230] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [162/230] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [163/230] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [164/230] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
    [165/230] Linking C static library zephyr\subsys\bluetooth\host\libsubsys__bluetooth__host.a
    [166/230] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [167/230] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [168/230] Linking C static library zephyr\subsys\net\libsubsys__net.a
    [169/230] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [170/230] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [171/230] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [172/230] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [173/230] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [174/230] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [175/230] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [176/230] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [177/230] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [178/230] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [179/230] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
    [180/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
    [181/230] Linking C static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
    [182/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/ecdh.c.obj
    [183/230] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [184/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [185/230] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [186/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
    [187/230] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [188/230] Linking C static library zephyr\drivers\mbox\libdrivers__mbox.a
    [189/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [190/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [191/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [192/230] Linking C static library modules\nrf\subsys\bluetooth\controller\lib..__nrf__subsys__bluetooth__controller.a
    [193/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [194/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [195/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [196/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [197/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [198/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [199/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [200/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [201/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [202/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [203/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [204/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [205/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [206/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [207/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [208/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [209/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [210/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [211/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [212/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [213/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [214/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [215/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [216/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [217/230] Linking C static library zephyr\kernel\libkernel.a
    [218/230] Linking C executable zephyr\zephyr_pre0.elf
    [219/230] Generating dev_handles.c
    [220/230] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [221/230] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [222/230] Linking C executable zephyr\zephyr_pre1.elf
    [223/230] Generating linker.cmd
    [224/230] Generating isr_tables.c, isrList.bin
    [225/230] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [226/230] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [227/230] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [228/230] Linking C executable zephyr\zephyr.elf
    Memory region Used Size Region Size %age Used
    FLASH: 179320 B 256 KB 68.41%
    SRAM: 47452 B 64 KB 72.41%
    SRAM1: 0 GB 64 KB 0.00%
    IDT_LIST: 0 GB 2 KB 0.00%
    [229/230] Generating zephyr/app.hex
    [230/230] Generating zephyr/merged_CPUNET.hex
    [61/317] Generating ../../tfm/CMakeCache.txt
    -- Found Python3: C:/Python39/python.exe (found version "3.9.7") found components: Interpreter
    -- Found Python3: C:/Python39/python.exe (found suitable exact version "3.9.7") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb/build/tfm
    [66/317] No configure step for 'tfm'
    [67/317] Performing build step for 'tfm'
    [1/2] Generating ../generated/secure_fw/spm/cmsis_func/tfm_spm_db_func.inc, ../generated/secure_fw/spm/cmsis_func/tfm_veneers.c, ../generated/interface/include/tfm_veneers.h, ../generated/secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc, ../generated/interface/include/psa_manifest/sid.h, ../generated/interface/include/psa_manifest/pid.h, ../generated/interface/include/config_impl.h, ../generated/tools/config_impl.cmake
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [1/168] Building C object lib/fih/CMakeFiles/tfm_fih_implementation.dir/src/fih.o
    [2/168] Linking C static library lib\fih\libtfm_fih_implementation.a
    [3/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/bignum.o
    [4/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/platform.o
    [5/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/nist_kw.o
    [6/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/oid.o
    [7/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/padlock.o
    [8/168] Generating liboberon_mbedcrypto__psa_3.0.11.a
    [9/168] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf5340/gcc/startup_nrf5340_s.o
    [10/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/tfm_psa_api_veneers.o
    [11/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [12/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o
    [13/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [14/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [15/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [16/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [17/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_svc.o
    [18/168] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o
    [19/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_core_utils.o
    [20/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o
    [21/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    [22/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch.o
    [23/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/backend_ipc.o
    [24/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/interrupt.o
    [25/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o
    [26/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o
    [27/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_api.o
    [28/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o
    [29/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o
    [30/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_pools.o
    [31/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz.o
    [32/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    [33/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/thread.o
    [34/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o
    [35/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/idle_partition.o
    [36/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o
    [37/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_svc.o
    [38/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [39/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [40/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [41/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o
    [42/168] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [43/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o
    [44/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [45/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [46/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o
    [47/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [48/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o
    [49/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_main.o
    [50/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o
    [51/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o
    [52/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o
    [53/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [54/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    [55/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    [56/168] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_svc.o
    [57/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [58/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [59/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    [60/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [61/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [62/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [63/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [64/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_svc.o
    [65/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [66/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [67/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [68/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [69/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [70/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [71/168] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [72/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_client.o
    [73/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_hash.o
    [74/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/memory_buffer_alloc.o
    [75/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto.o
    [76/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_aead.o
    [77/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_ecp.o
    [78/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_cipher.o
    [79/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o
    [80/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_slot_management.o
    [81/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_rsa.o
    [82/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_mac.o
    [83/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/psa_crypto_storage.o
    [84/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o
    [85/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkwrite.o
    [86/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/dhm.o
    [87/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkcs12.o
    [88/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkparse.o
    [89/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pkcs5.o
    [90/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/cipher.o
    [91/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pem.o
    [92/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pk_wrap.o
    [93/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/md.o
    [94/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/sha1.o
    [95/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/pk.o
    [96/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/sha256.o
    [97/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/cipher_wrap.o
    [98/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/aria.o
    [99/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/md5.o
    [100/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/sha512.o
    [101/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/aesni.o
    [102/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/camellia.o
    [103/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ripemd160.o
    [104/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/des.o
    [105/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecdh.o
    [106/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecdsa.o
    [107/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/cmac.o
    [108/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ccm.o
    [109/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/chachapoly.o
    [110/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecp.o
    [111/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/hkdf.o
    [112/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/rsa.o
    [113/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/hmac_drbg.o
    [114/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/rsa_alt_helpers.o
    [115/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/ecp_curves.o
    [116/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/gcm.o
    [117/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o
    [118/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o
    [119/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/asn1parse.o
    [120/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o
    [121/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/cb8687a9b3a5d17156fa894e3b52e553/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [122/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/base64.o
    [123/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/asn1write.o
    [124/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/platform_util.o
    [125/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/version.o
    [126/168] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/constant_time.o
    [127/168] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libmbedcrypto_base.a
    [128/168] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [129/168] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_svc.o
    [130/168] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [131/168] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [132/168] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [133/168] Building C object platform/CMakeFiles/platform_s.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [134/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [135/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [136/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [137/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [138/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [139/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [140/168] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o
    [141/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [142/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [143/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o
    [144/168] Building C object platform/CMakeFiles/platform_s.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.o
    [145/168] Building C object platform/CMakeFiles/platform_s.dir/D_/ncs/v2.1.0-rc1/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o
    [146/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf5340/tfm_interrupts.o
    [147/168] Building C object platform/CMakeFiles/platform_s.dir/D_/ncs/v2.1.0-rc1/nrf/modules/tfm/tfm/boards/common/dummy_otp.o
    [148/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf5340/target_cfg.o
    [149/168] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [150/168] Building C object platform/CMakeFiles/platform_s.dir/D_/ncs/v2.1.0-rc1/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o
    [151/168] Building C object platform/CMakeFiles/platform_s.dir/D_/ncs/v2.1.0-rc1/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o
    [152/168] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o
    [153/168] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o
    [154/168] Building C object platform/CMakeFiles/platform_s.dir/D_/ncs/v2.1.0-rc1/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o
    [155/168] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o
    [156/168] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_svc.o
    [157/168] Linking C static library platform\libplatform_s.a
    [158/168] Linking C static library secure_fw\partitions\platform\libtfm_psa_rot_partition_platform.a
    [159/168] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedcrypto.a
    [160/168] Linking C static library secure_fw\partitions\crypto\libtfm_psa_rot_partition_crypto.a
    [161/168] Linking C static library secure_fw\partitions\lib\sprt\libtfm_sprt.a
    [162/168] Linking C static library secure_fw\spm\libtfm_spm.a
    [163/168] Building C object platform/target/nrf5340/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld
    [164/168] Linking C executable bin\tfm_s.axf
    [165/168] Generating ../bin/tfm_s.hex
    [166/168] Generating ../bin/tfm_s.bin
    [167/168] Linking C static library secure_fw\libtfm_s_veneers.a
    [168/168] Generating ../bin/tfm_s.elf
    [69/317] Completed 'hci_rpmsg_subimage'
    [71/317] Generating zephyr/tfm_secure.hex
    [72/317] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [73/317] Completed 'tfm'
    [74/317] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [75/317] Generating include/generated/offsets.h
    [76/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_descriptor.c.obj
    [77/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_transfer.c.obj
    [78/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/bluetooth.c.obj
    [79/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [80/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_rpmsg.c.obj
    [81/317] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [82/317] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [83/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/ipc_service.c.obj
    [84/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/backends/ipc_rpmsg_static_vrings.c.obj
    [85/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_device.c.obj
    [86/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_static_vrings.c.obj
    [87/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [88/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [89/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [90/317] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [91/317] Building C object zephyr/CMakeFiles/zephyr.dir/D_/ncs/v2.1.0-rc1/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [92/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [93/317] Building C object CMakeFiles/app.dir/src/main.c.obj
    [94/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [95/317] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [96/317] Generating linker_zephyr_pre1.cmd
    [97/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [98/317] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [99/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [100/317] Generating linker_zephyr_pre0.cmd
    [101/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [102/317] Linking C static library app\libapp.a
    [103/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [104/317] Linking C static library zephyr\arch\common\libisr_tables.a
    [105/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [106/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [107/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [108/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [109/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [110/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [111/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [112/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [113/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [114/317] Linking C static library zephyr\arch\common\libarch__common.a
    [115/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [116/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [117/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [118/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [119/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [120/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [121/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [122/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [123/317] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/power.c.obj
    [124/317] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
    [125/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [126/317] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [127/317] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [128/317] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_secure.c.obj
    [129/317] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [130/317] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [131/317] Building C object modules/nrf/modules/tfm/zephyr/CMakeFiles/tfm_api_nrf.dir/D_/ncs/v2.1.0-rc1/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_ns_api.c.obj
    [132/317] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [133/317] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_psa_ns_api.c.obj
    [134/317] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_ioctl_core_ns_api.c.obj
    [135/317] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [136/317] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_crypto_ipc_api.c.obj
    [137/317] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj
    [138/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [139/317] Linking C static library zephyr\libzephyr.a
    [140/317] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [141/317] Linking C static library modules\nrf\modules\tfm\zephyr\libtfm_api_nrf.a
    [142/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [143/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
    [144/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
    [145/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [146/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [147/317] Linking C static library modules\trusted-firmware-m\libtfm_api.a
    [148/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [149/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [150/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_usbreg.c.obj
    [151/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/init.c.obj
    [152/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/device.c.obj
    [153/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/io.c.obj
    [154/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/dma.c.obj
    [155/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/irq.c.obj
    [156/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/softirq.c.obj
    [157/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/version.c.obj
    [158/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/log.c.obj
    [159/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/shmem.c.obj
    [160/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/alloc.c.obj
    [161/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/device.c.obj
    [162/317] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/ncs/v2.1.0-rc1/modules/hal/nordic/nrfx/drivers/src/nrfx_usbd.c.obj
    [163/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/condition.c.obj
    [164/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/irq.c.obj
    [165/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/shmem.c.obj
    [166/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/init.c.obj
    [167/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/log.c.obj
    [168/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/sys.c.obj
    [169/317] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/time.c.obj
    [170/317] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [171/317] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [172/317] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [173/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [174/317] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [175/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [176/317] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [177/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [178/317] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [179/317] Linking C static library modules\libmetal\libmetal\lib\libmetal.a
    [180/317] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [181/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [182/317] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [183/317] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [184/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [185/317] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [186/317] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [187/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [188/317] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [189/317] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [190/317] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [191/317] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [192/317] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [193/317] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [194/317] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [195/317] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [196/317] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [197/317] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [198/317] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [199/317] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [200/317] Building C object zephyr/boards/arm/nrf5340dk_nrf5340/CMakeFiles/boards__arm__nrf5340dk_nrf5340.dir/nrf5340_cpunet_reset.c.obj
    [201/317] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [202/317] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/log.c.obj
    [203/317] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [204/317] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [205/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [206/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [207/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [208/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [209/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [210/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [211/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [212/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [213/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [214/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [215/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [216/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [217/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [218/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [219/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [220/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [221/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [222/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [223/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [224/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [225/317] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [226/317] Linking C static library zephyr\lib\posix\liblib__posix.a
    [227/317] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [228/317] Linking C static library zephyr\boards\arm\nrf5340dk_nrf5340\libboards__arm__nrf5340dk_nrf5340.a
    [229/317] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [230/317] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [231/317] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_raw.c.obj
    [232/317] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [233/317] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [234/317] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [235/317] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [236/317] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [237/317] Linking C static library zephyr\subsys\bluetooth\common\libsubsys__bluetooth__common.a
    [238/317] Linking C static library zephyr\subsys\bluetooth\host\libsubsys__bluetooth__host.a
    [239/317] Linking C static library zephyr\subsys\net\libsubsys__net.a
    [240/317] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [241/317] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj
    [242/317] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [243/317] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [244/317] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [245/317] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [246/317] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj
    [247/317] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/D_/ncs/v2.1.0-rc1/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [248/317] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
    [249/317] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [250/317] Building C object zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/rpmsg.c.obj
    [251/317] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [252/317] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [253/317] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [254/317] Linking C static library zephyr\drivers\hwinfo\libdrivers__hwinfo.a
    [255/317] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [256/317] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [257/317] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [258/317] Linking C static library zephyr\drivers\usb\device\libdrivers__usb__device.a
    [259/317] Linking C static library zephyr\drivers\bluetooth\libdrivers__bluetooth.a
    [260/317] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [261/317] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [262/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/version.c.obj
    [263/317] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
    [264/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg.c.obj
    [265/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtio.c.obj
    [266/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtqueue.c.obj
    [267/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg_virtio.c.obj
    [268/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/elf_loader.c.obj
    [269/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc.c.obj
    [270/317] Linking C static library zephyr\drivers\mbox\libdrivers__mbox.a
    [271/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc_virtio.c.obj
    [272/317] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/rsc_table_parser.c.obj
    [273/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [274/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [275/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [276/317] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/D_/ncs/v2.1.0-rc1/mbedtls/library/platform.c.obj
    [277/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [278/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [279/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [280/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [281/317] Linking C static library modules\open-amp\open-amp\lib\libopen_amp.a
    [282/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [283/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [284/317] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\zephyr\libmbedtls_zephyr.a
    [285/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [286/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [287/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [288/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [289/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [290/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [291/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [292/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [293/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [294/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [295/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [296/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [297/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [298/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [299/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [300/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [301/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [302/317] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [303/317] Linking C static library zephyr\kernel\libkernel.a
    [304/317] Linking C executable zephyr\zephyr_pre0.elf
    [305/317] Generating dev_handles.c
    [306/317] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [307/317] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [308/317] Linking C executable zephyr\zephyr_pre1.elf
    [309/317] Generating linker.cmd
    [310/317] Generating isr_tables.c, isrList.bin
    [311/317] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [312/317] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [313/317] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [314/317] Linking C executable zephyr\zephyr.elf
    FLASH: 47332 B 992 KB 4.66%
    SRAM: 21708 B 416 KB 5.10%
    [315/317] Generating zephyr/tfm_nonsecure.hex
    [316/317] Generating zephyr/merged.hex
    [317/317] Generating zephyr/merged_domains.hex
  • Flash Log:
    BGH48649@BGHMBCP0775 MINGW64 /d/ncs/v2.1.0-rc1/zephyr/samples/bluetooth/hci_usb ((v3.1.99-ncs1-rc1))
    $ west flash
    -- west flash: rebuilding
    [0/24] Performing build step for 'tfm'
    ninja: no work to do.
    [1/5] Performing build step for 'hci_rpmsg_subimage'
    -- west flash: using runner nrfjprog
    Using board 960168981
    -- runners.nrfjprog: Flashing file: D:\ncs\v2.1.0-rc1\zephyr\samples\bluetooth\hci_usb\build\zephyr\merged_domains.hex
    -- runners.nrfjprog: D:\ncs\v2.1.0-rc1\zephyr\samples\bluetooth\hci_usb\build\zephyr\merged_domains.hex targets both nRF53 coprocessors; splitting it into: D:\ncs\v2.1.0-rc1\zephyr\samples\bluetooth\hci_usb\build\zephyr\GENERATED_CP_NETWORK_merged_domains.hex and D:\ncs\v2.1.0-rc1\zephyr\samples\bluetooth\hci_usb\build\zephyr\GENERATED_CP_APPLICATION_merged_domains.hex
    Parsing image file.
    Verifying programming.
    Verified OK.
    Parsing image file.
    Verified OK.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 960168981 flashed successfully.
    For pasting long logs, please use the Insert->Code functionality. It will make the case more tidy.
    I build the hci_usb project again for the nRF Connect SDK v2.1.0. Here is the hex: 3480.merged.hex
    Which version of Linux are you using?
    Sigurd Hellesvik
  • Hi sigurd
    i have tried flashing the merged hex file which you sent .
    i am using the 22.04 linux version .
    But when i tried to do btattach .its shows this in the btmon
