NRF52840 in sleep how to wakeup
How to wakeup while in sleep state via uart
    Please include more details about your current setup and what you are trying to achieve. E.g. should the UART peripheral be disabled in sleep like described here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/drivers/uart_nrf_sw_lpuart.html#low-power-uart-driver? What SDK? Sleep mode?
  • Hi
    I am using STM32H7 and i connect nrf52840 via uart connection and i tried to sleep ON  & OFF using trigger button in stm32
    * I sent data in stm32 via UART  1-> to start & 2-> stop
    Is this is write way i am working with i cannot able to understand
    uart_event_handle(app_uart_evt_t * p_event) // in this fun i used this logic
         if(data_array[0] == '1')
             ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
         else if(data_array[0] == '2')
             sd_ble_gap_adv_stop(m_advertising.adv_handle);
  • I don't see where you are updating the 'data_array'. That should normally be done inside the uart_event_handle() if you are using the app uart libary.
    Like this:
        if (p_event->evt_type == APP_UART_DATA_READY)
            UNUSED_VARIABLE(app_uart_get(&data_array[0]));
  • Hi Vidar Berg
    I tried lots of time but i am not able to ON and OFF
    Receive data via UART data_array[].It get's OFF but not getting ON i don't have Idea
    void uart_event_handle(app_uart_evt_t * p_event)
    static uint8_t data_array[BLE_NUS_MAX_DATA_LEN];
    static uint8_t index = 0;
    uint32_t err_code;
         // ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
         ble_advertising_restart_without_whitelist(&m_advertising);
         sleep_mode_enter();
    switch (p_event->evt_type)
    case APP_UART_DATA_READY:
    index++;
    if ((data_array[index - 1] == '\n') ||
    (data_array[index - 1] == '\r') ||
    (index >= m_ble_nus_max_data_len))
    if (index > 1)
    do
    uint16_t length = (uint16_t)index;
    if ((err_code != NRF_ERROR_INVALID_STATE) &&
    (err_code != NRF_ERROR_RESOURCES) &&
    (err_code != NRF_ERROR_NOT_FOUND))
    } while (err_code == NRF_ERROR_RESOURCES);
    index = 0;
    case APP_UART_COMMUNICATION_ERROR:
    case APP_UART_FIFO_ERROR:
