Hello everyone,
I am working with a BMI160 6-DoF sensor. I have some drivers related to this chip. Using the Segger J-Link debugger the drivers just work fine without any issues I am able to read the data registers on the sensor via SPI interface.
uint8_t getData_bmx160(bmx160_spi * bmxIMU_spi_p, bmx160_sensor_data * sen_data)
uint8_t data[12] = {0,0,0,0,0,0,0,0,0,0,0,0};
result = readReg_bmx160(bmxIMU_spi_p, BMX160_GYR_X_LSB_REG, data, 12);
int readReg_bmx160(bmx160_spi * bmxIMU_spi_p, uint8_t reg, uint8_t *data, size_t len)
int result;
unsigned char tx_buffer[2] = { 0, 0};
tx_buffer[0] = 0x80 | reg;
const struct spi_buf tx_buf = {
.buf = tx_buffer,
.len = 1,
const struct spi_buf_set tx = {
.buffers = &tx_buf,
.count = 1,
struct spi_buf rx_buf[2] = {
.buf = tx_buffer,
.len = 1,
.buf = data,
.len = len,
const struct spi_buf_set rx = {
.buffers = rx_buf,
.count = 2,
gpio_pin_set(bmxIMU_spi_p->gpio0_dev, bmxIMU_spi_p->spi_cs_pin, 1);
result = spi_transceive(bmxIMU_spi_p->spi_dev, &bmxIMU_spi_p->spi_cfg, &tx, &rx);
gpio_pin_set(bmxIMU_spi_p->gpio0_dev, bmxIMU_spi_p->spi_cs_pin, 0);
if (result) {
return result;
return 0;
This is how the registers are read on the driver. However, when I switch to the runtime the 'data' is not updated even though 'spi_transceive(..)' returns >= 0 .
