update failed for project sdk-lc3
Hello.
I had LC3 access granted.
I can access nrfconnect/sdk-lc3 on my web browser.
However, with bash, I get the following error and cannot build nRF5340_audio.
$ west config manifest.group-filter +nrf5340_audio
$ west update
=== updating zephyr (zephyr):
HEAD is now at 0a904d0c17 [nrf fromlist] tfm: Add option for implementation custom reset handler with TF-M
=== updating mcuboot (bootloader/mcuboot):
HEAD is now at 129b6312 [nrf noup] bootutil: loader: Add check for netcore addr if NSIB enabled
=== updating mbedtls-nrf (mbedtls):
HEAD is now at b36261c55 [nrf noup]: Fix unset key bits for nrf_cc3xx v0.9.14
=== updating nrfxlib (nrfxlib):
HEAD is now at 1296d445 doc: version update for NCS 2.0.0
=== updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
HEAD is now at cf76972f [nrf toup] SPM: Call tfm_core_panic instead of halt for access violation
=== updating tfm-mcuboot (modules/tee/tfm-mcuboot):
HEAD is now at 4aa516e7 Bump versions for v1.7.2
=== updating matter (modules/lib/matter):
HEAD is now at 2a120900e [nrf noup] Always set UPDATEABLE_IMAGE_NUMBER=2 for nRF53
Synchronizing submodule url for 'third_party/nlio/repo'
Synchronizing submodule url for 'third_party/nlassert/repo'
Synchronizing submodule url for 'third_party/pigweed/repo'
=== updating cjson (modules/lib/cjson):
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
=== updating sdk-lc3 (modules/lib/lc3):
--- sdk-lc3: fetching, need revision c47d9ee21c9cd8626a903c2e2f0c80c0920a1eb8
fatal: unable to access 'https://github.com/nrfconnect/sdk-lc3/': Failed to connect to github.com port 443: Timed out
=== updating cmock (test/cmock):
HEAD is now at 9d09289 Merge pull request #346 from ThrowTheSwitch/reapply_329
M       vendor/unity
=== updating unity (test/cmock/vendor/unity):
HEAD is now at 74cde08 Merge pull request #540 from numaru/master
=== updating zcbor (modules/lib/zcbor):
HEAD is now at 3d36ae1 include: Define variables to avoid rvalue address errors
=== updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
HEAD is now at b7eea3b Memfault Firmware SDK 0.29.1 (Build 412506)
=== updating cirrus (modules/hal/cirrus-logic):
HEAD is now at 9f6b381 sdk-mcu-drivers: Added build system configs and generated files
=== updating canopennode (modules/lib/canopennode):
HEAD is now at 53d3415 Merge pull request #5 from teslabs/module-name
=== updating chre (modules/lib/chre):
HEAD is now at 0edfe2c2 Merge pull request #1 from yperess/zephyr
=== updating civetweb (modules/lib/civetweb):
HEAD is now at 094aeb41 cmake: relax minimum version requirements
=== updating cmsis (modules/hal/cmsis):
HEAD is now at ed63b70 NN: Integrate CMSIS-NN (CMSIS 5.8.0)
=== updating edtt (tools/edtt):
HEAD is now at 1ea61a3 Fixing error in DLE test cases
=== updating fatfs (modules/fs/fatfs):
HEAD is now at 9237454 fat_fs: Add support for the "win" variable alignment in FATFS struct
=== updating hal_nordic (modules/hal/nordic):
HEAD is now at a85bb36 nrfx: doc: remove references to nrfx_atomic Doxygen group
=== updating hal_st (modules/hal/st):
HEAD is now at 575de9d sensor/stmemsc: Align stmemsc i/f to v2.00
=== updating libmetal (modules/hal/libmetal):
HEAD is now at c6efe09 lib: update libmetal to SHA 695d29ba60a5
=== updating liblc3codec (modules/lib/liblc3codec):
HEAD is now at 3951cf1 Add liblc3 as a zephyr module
=== updating littlefs (modules/fs/littlefs):
HEAD is now at 7b2cf4b zephyr: move CMake glue code for building as a module into Zephyr
=== updating loramac-node (modules/lib/loramac-node):
HEAD is now at 12019623 zephyr: radio: sx127x: override buffer read/write functions
=== updating lvgl (modules/lib/gui/lvgl):
HEAD is now at a2e17073 fix(script): in lv_conf_internal fix some widget dependencies when using Kconfig (#3119)
=== updating lz4 (modules/lib/lz4):
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
=== updating mbedtls (modules/crypto/mbedtls):
HEAD is now at 3e3e58a92 mbedtls: remove static keyword from certain function pointers
=== updating mipi-sys-t (modules/debug/mipi-sys-t):
HEAD is now at 2f51407 library: add sending catalog msgs with prepared argument lists
=== updating nanopb (modules/lib/nanopb):
HEAD is now at d148bd2 Add zephyr module support
=== updating net-tools (tools/net-tools):
HEAD is now at f49bd13 net-capture: Listen captured traffic and save to pcap file
=== updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
HEAD is now at b8cea37 Added overflow event handling and trigger overflow task
=== updating open-amp (modules/lib/open-amp):
HEAD is now at cfd050f lib: update open-amp lib to release v2021.10.0
=== updating openthread (modules/lib/openthread):
HEAD is now at e2a765599 Merge pull request #65 from edmont/pr/upmerge-20220513
=== updating segger (modules/debug/segger):
HEAD is now at 3a52ab2 config: Use zephyr provided options
=== updating tinycbor (modules/lib/tinycbor):
HEAD is now at 9e1f34b module: Deprecate TinyCBOR
=== updating tinycrypt (modules/crypto/tinycrypt):
HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt
=== updating TraceRecorderSource (modules/debug/TraceRecorder):
HEAD is now at e8ca3b6 Merge pull request #7 from tleksell-pe/trace_recorder_4.6.0_update
=== updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
HEAD is now at 5281418 Merge pull request #1 from SebastianBoe/merge_tfm-1.5
=== updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
HEAD is now at 4f45df5 Merge pull request #3 from joerchan/tfm-fix-wdt-timeout-zephyr
=== updating zscilib (modules/lib/zscilib):
HEAD is now at 12bfe3f Merge pull request #28 from microbuilder/doccleanup
ERROR: update failed for project sdk-lc3
How can I resolve this?
Gotoda
