I am doing "application update" using AWS FOTA with presigned URL.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.1/nrf/samples/nrf9160/aws_fota/README.htmlI
I am getting following error during the fota download process.
[00:00:37.020,751] <dbg> aws_iot: broker_init: IPv4 Address found 52.40.13.127 [00:00:45.354,827] <dbg> aws_iot: connect_client: Using send socket timeout of 60 seconds [00:00:45.354,858] <dbg> aws_iot: aws_iot_cloud_poll: AWS IoT broker connection request sent [00:00:45.777,923] <dbg> aws_iot: mqtt_evt_handler: MQTT client connected! [00:00:45.779,083] <dbg> aws_iot: aws_iot_send: Publishing to topic: $aws/things/830_test1/shadow/update [00:00:45.781,280] <dbg> aws_iot: aws_iot_send: Publishing to topic: $aws/things/830_test1/shadow/get [00:00:45.782,287] <dbg> aws_iot: device_shadow_document_request: Device shadow document requested [00:00:45.980,651] <dbg> at_monitor: at_monitor_task: AT notif: +CEREG: 1,"909D","09547000",7,,,"00011110","10111110" [00:00:45.980,682] <dbg> at_monitor: at_monitor_task: Dispatching to 0x3ba09 [00:00:46.061,065] <dbg> at_monitor: at_monitor_task: AT notif: %XTIME: ,"22805060813563", [00:00:46.061,126] <dbg> at_monitor: at_monitor_task: Dispatching to 0x3fd05 [00:00:46.185,150] <dbg> aws_iot: mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2112 result = 0 [00:00:46.456,298] <dbg> aws_iot: mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2114 result = 0 [00:00:46.989,807] <dbg> aws_iot: mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 5 len = 411 [00:00:48.271,026] <dbg> aws_iot: mqtt_evt_handler: MQTT_EVT_PUBACK: id = 6042 result = 0 [00:00:48.271,301] <err> aws_fota: Error when getting the payload: -122 [00:00:48.271,301] <err> aws_iot: aws_fota_mqtt_evt_handler, error: -122 [00:00:48.271,331] <dbg> aws_iot: mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 0 len = 1605 [00:00:51.514,953] <inf> cpu_load: Load:6,546% [00:00:53.515,045] <inf> cpu_load: Load:8,938% [00:00:54.981,353] <err> aws_fota: Error when getting the payload: -122 [00:00:54.981,384] <err> aws_iot: aws_fota_mqtt_evt_handler, error: -122 [00:00:54.981,384] <dbg> aws_iot: mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 4 len = 1588 [00:00:55.515,136] <inf> cpu_load: Load:10,317%
My environment
1. nrf SDK 1.9.1
2. prj.conf
CONFIG_TRUSTED_EXECUTION_NONSECURE=y # General config CONFIG_REBOOT=y # CONFIG_RTT_CONSOLE=y # CONFIG_USE_SEGGER_RTT=y CONFIG_RING_BUFFER=y # LOGGNG CONFIG_LOG=y CONFIG_LOG_BUFFER_SIZE=2048 # CONFIG_LOG_PRINTK=y # CONFIG_LOG_BACKEND_RTT=y # CONFIG_LOG_BACKEND_UART=n CONFIG_LOG2_MODE_DEFERRED=y CONFIG_CBPRINTF_FP_SUPPORT=y CONFIG_LOG_DEFAULT_LEVEL=4 # Console CONFIG_PRINTK=y # CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=n CONFIG_SHELL=y CONFIG_KERNEL_SHELL=y CONFIG_DEVICE_SHELL=y CONFIG_POSIX_CLOCK=y CONFIG_DATE_SHELL=y #CONFIG_SHELL_MINIMAL=y CONFIG_SHELL_STACK_SIZE=1024 CONFIG_SHELL_BACKEND_SERIAL=n CONFIG_SHELL_LOG_BACKEND=y CONFIG_SHELL_RTT_LOG_LEVEL_DBG=y CONFIG_SHELL_RTT_INIT_LOG_LEVEL_WRN=y CONFIG_THREAD_MONITOR=y CONFIG_INIT_STACKS=y CONFIG_BOOT_BANNER=n CONFIG_THREAD_NAME=y #enable RTT shell CONFIG_USE_SEGGER_RTT=y CONFIG_SHELL_BACKEND_RTT=y CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=32 # UART CONFIG_UART_ASYNC_API=y # Modem library CONFIG_NRF_MODEM_LIB=y #CONFIG_POSIX_MAX_FDS=8 CONFIG_MODEM_INFO=y CONFIG_MODEM_KEY_MGMT=y CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 CONFIG_NEWLIB_LIBC=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_NETWORK_MODE_LTE_M=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n CONFIG_LTE_LOCK_BANDS=y CONFIG_LTE_LOCK_BAND_MASK="0000000001000000000000000001" # Network CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_OFFLOAD=y # PDN library CONFIG_PDN=y CONFIG_PDN_SYS_INIT=y CONFIG_PDN_DEFAULTS_OVERRIDE=y CONFIG_PDN_DEFAULT_APN="iijmobile.biz" CONFIG_PDN_DEFAULT_FAM_IPV4=y CONFIG_PDN_DEFAULT_AUTH_CHAP=y CONFIG_PDN_DEFAULT_USERNAME="mobile@iij" CONFIG_PDN_DEFAULT_PASSWORD="iij" # Stacks and heaps CONFIG_HEAP_MEM_POOL_SIZE=16384 # for debug CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_DEBUG_THREAD_INFO=y CONFIG_OPENOCD_SUPPORT=y CONFIG_MAIN_STACK_SIZE=8192 CONFIG_PRIVILEGED_STACK_SIZE=1024 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 # Flash CONFIG_SPI=y CONFIG_FLASH=y # I2C CONFIG_I2C_NRFX=y CONFIG_I2C=y #IMU CONFIG_SENSOR=y CONFIG_ICM42605=y CONFIG_ICM42605_TRIGGER_NONE=y # json CONFIG_JSON_LIBRARY=y # float CONFIG_NEWLIB_LIBC=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y # for Zmod library CONFIG_FPU=y CONFIG_FPU_SHARING=y CONFIG_FP_HARDABI=y CONFIG_CPU_LOAD=y CONFIG_CPU_LOAD_LOG_INTERVAL=2000 CONFIG_CPU_LOAD_LOG_PERIODIC=y CONFIG_DATE_TIME=y # CJSON CONFIG_CJSON_LIB=y # AWS IoT library CONFIG_AWS_IOT=y CONFIG_AWS_IOT_CLIENT_ID_STATIC="830_test1" CONFIG_AWS_IOT_BROKER_HOST_NAME="xxxxxxxxxxxxxxxx-ats.iot.us-west-2.amazonaws.com" CONFIG_AWS_IOT_SEC_TAG=42 CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=2 CONFIG_AWS_IOT_AUTO_DEVICE_SHADOW_REQUEST=y CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y CONFIG_AWS_IOT_LAST_WILL=y CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y CONFIG_PUBLICATION_INTERVAL_SECONDS=30 CONFIG_AWS_IOT_MQTT_PAYLOAD_BUFFER_LEN=2048 CONFIG_AWS_IOT_MQTT_RX_TX_BUFFER_LEN=2048 CONFIG_AWS_IOT_LOG_LEVEL_DBG=y # MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core CONFIG_MQTT_KEEPALIVE=1200 # Date Time library CONFIG_DATE_TIME=y # MCUBOOT CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUBOOT_IMG_MANAGER=y # Image manager CONFIG_IMG_MANAGER=y CONFIG_FLASH=y CONFIG_IMG_ERASE_PROGRESSIVELY=y #AWS FOTA CONFIG_AWS_FOTA=y CONFIG_FOTA_DOWNLOAD=y CONFIG_AWS_FOTA_DOWNLOAD_SECURITY_TAG=42 CONFIG_DFU_TARGET=y #CONFIG_AWS_FOTA_PAYLOAD_SIZE=2048 #CONFIG_NRF_MODEM_LIB_SYS_INIT=y #CONFIG_AWS_FOTA_FILE_PATH_MAX_LEN=2048 #CONFIG_DOWNLOAD_CLIENT_MAX_FILENAME_SIZE=2048 CONFIG_FOTA_SOCKET_RETRIES=10 #CONFIG_AWS_FOTA_LOG_LEVEL_DBG=y #CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG=y #CONFIG_DOWNLOAD_CLIENT_LOG_HEADERS=y CONFIG_APP_VERSION="v1.0.1" CONFIG_WARNING_BUZZER=n CONFIG_DEVELOP_MODE=n
I also tried to increase the payload size i didn't help me.
Please help me in investigating the issue.
Regards
Praveen Deshmane
