Kconfig selection error in lwm2m client project
I am working on adding a new LWM2M object (3302 Presence) to the lwm2m client project from SDK version 1.9.1. After creating and including the file "Kconfig.ipso_presence_sensor" which is located in the ipso folder, I now receive the below build errors:
warning: the default selection LWM2M_IPSO_PRESENCE_VERSION_1_0 (defined at C:\code\TWPS\src\ipso\Kconfig.ipso_presence_sensor:24, c:\code\TWPS\build\subsys\net\lib\lwm2m\Kconfig.ipso:310) of <choice> (defined at C:\code\TWPS\src\ipso\Kconfig.ipso_presence_sensor:20) is not contained in the choice
warning: the choice symbol LWM2M_IPSO_PRESENCE_VERSION_1_0 (defined at C:\code\TWPS\src\ipso\Kconfig.ipso_presence_sensor:24, c:\code\TWPS\build\subsys\net\lib\lwm2m\Kconfig.ipso:310) is defined with a prompt outside the choice
warning: the choice symbol LWM2M_IPSO_PRESENCE_VERSION_1_1 (defined at C:\code\TWPS\src\ipso\Kconfig.ipso_presence_sensor:27, c:\code\TWPS\build\subsys\net\lib\lwm2m\Kconfig.ipso:313) is defined with a prompt outside the choice
warning: the choice symbol LWM2M_IPSO_Parsing C:/code/TWPS/Kconfig
Loaded configuration 'C:/code/TWPS/build/zephyr/.config'
error: Aborting due to Kconfig warnings
Here is the file code:
# Copyright (c) 2021 Nordic Semiconductor ASA
config LWM2M_APP_PRESENCE
    bool
    help
      This IPSO object should be used to report detected presence
if LWM2M_APP_PRESENCE
config LWM2M_IPSO_PRESENCE_INSTANCE_COUNT
    int
    default 3
    help
      Total count of IPSO Presence instances available to the LWM2M client.
choice
    prompt "Select IPSO Presence object version"
    default LWM2M_IPSO_PRESENCE_VERSION_1_0
config LWM2M_IPSO_PRESENCE_VERSION_1_0
    bool "Version 1.0"
config LWM2M_IPSO_PRESENCE_VERSION_1_1
    bool "Version 1.1"
endchoice # IPSO Presence object version
endif # LWM2M_APP_PRESENCE
I am not sure why I am receiving this error since the file contents are formatted exactly like the file Kconfig.ipso_colour_sensor which is located in the same folder.
