Dear support
I need to pass 128 bits service uuid to discovery process as variable, I have an array of 16 bytes of uuid number, it is divided into five parts as show here
Dear support
further - to make it more strict, code is like below:
w48 = (value[10]<<40) & 0xff0000000000 + (value[11]<<32)&0xff00000000; //this line doesn't work
The compiler (gcc in my test) should warn you when an overflow occurs, like in this case:
warning: left shift count >= width of type [-Wshift-count-overflow]
15 | w48 = (value[10]<<40) + (value[11]<<32); //this line ends up 0
Can you try casting value[10] and [11] to uint64_t to see if this fixes the issue?
Håkon
thank you, Hakon
Casting individual value[10] and value[11] works, but not overall result, my compiler doesn't give out any warnings.
Ping
Hi Ping,
Can you share the content of the value[10..15] as well as the full content of "w48"?
PingISTL said:Casting individual value[10] and value[11] works, but not overall result, my compiler doesn't give out any warnings.
I'm not sure what you mean, were you able to successfully populate the upper 32 bits ?
Håkon
Sorry for that, I didn't make myself clear, your solution works. code as below:
w48 = ((uint64_t)Val[14]<<8)+(uint64_t)Val[15]; w48 += ((uint64_t)Val[12]<<24)+((uint64_t)Val[13]<<16); w48 += ((uint64_t)Val[10]<<40)+((uint64_t)Val[11]<<32);
Thank you!
Ping
