Dear Support Team,
We are encountering an issue when trying to flash the firmware of our B810 smart tag using the Android DFU Library (https://github.com/NordicSemiconductor/Android-DFU-Library) version ‘no.nordicsemi.android:dfu:1.11.1’ from a Samsung Galaxy S9 using Android 10. We tried to perform the flashing using the NRF connect app for Android, to discriminate whether the problem occurs in the library or in the usage we make of it, but we are encountering the very same issue:
Connection failed (0x85): GATT ERROR
However, this issue does not occur if we try to use the NRF connect app from a Samsung Galaxy S6 using Android 7.
It seems that the problem occurs while trying to connect to BLE device when it is on DFU mode.
You can see attached the logs from the NRF connect app of the firmware update attempts we performed on both the devices.
Can you assist?
Thanks
nRF Connect, 2022-07-26 No name (FF:EC:FF:FE:CE:66) V 16:19:47.881 Connecting to FF:EC:FF:FE:CE:66... D 16:19:47.881 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:19:48.135 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED D 16:19:48.182 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:19:48.182 Connected to FF:EC:FF:FE:CE:66 V 16:19:48.199 Discovering services... D 16:19:48.199 gatt.discoverServices() I 16:19:48.555 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 16:19:49.510 [Callback] Services discovered with status: 0 I 16:19:49.511 Services discovered V 16:19:49.607 Generic Access (0x1800) - Device Name [R W] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Hardware Revision String [R] (0x2A27) - Firmware Revision String [R] (0x2A26) Unknown Service (43ba1a00-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4000-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4001-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4002-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a02-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4200-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4202-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4203-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4204-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a03-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4300-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4301-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4302-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4303-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4304-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a04-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4400-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4401-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4402-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (43ba4403-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4404-4cf5-46d8-a887-a846d9de712d) Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123) - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123) - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123) Client Characteristic Configuration (0x2902) - DFU Version [R] (00001534-1212-efde-1523-785feabcd123) Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e) - TX Characteristic [N R] (6e400003-b5a3-f393-e0a9-e50e24dcca9e) Client Characteristic Configuration (0x2902) - RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e) D 16:19:49.608 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 16:19:49.610 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 16:19:49.612 gatt.setCharacteristicNotification(43ba4000-4cf5-46d8-a887-a846d9de712d, true) D 16:19:49.613 gatt.setCharacteristicNotification(43ba4200-4cf5-46d8-a887-a846d9de712d, true) D 16:19:49.615 gatt.setCharacteristicNotification(43ba4400-4cf5-46d8-a887-a846d9de712d, true) D 16:19:49.616 gatt.setCharacteristicNotification(43ba4402-4cf5-46d8-a887-a846d9de712d, true) D 16:19:49.617 gatt.setCharacteristicNotification(43ba4403-4cf5-46d8-a887-a846d9de712d, true) D 16:19:49.620 gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true) I 16:19:49.651 Connection parameters updated (interval: 348.75ms, latency: 0, timeout: 4000ms) V 16:20:24.776 Reading characteristic 00002a26-0000-1000-8000-00805f9b34fb D 16:20:24.776 gatt.readCharacteristic(00002a26-0000-1000-8000-00805f9b34fb) I 16:20:25.206 Read Response received from 00002a26-0000-1000-8000-00805f9b34fb, value: (0x) 30-32-2E-31-36-2E-30-30, "02.16.00" A 16:20:25.206 "02.16.00" received V 16:20:26.781 Reading characteristic 00002a25-0000-1000-8000-00805f9b34fb D 16:20:26.781 gatt.readCharacteristic(00002a25-0000-1000-8000-00805f9b34fb) I 16:20:27.296 Read Response received from 00002a25-0000-1000-8000-00805f9b34fb, value: (0x) 31-30-30-32-37-32-42-35, "100272B5" A 16:20:27.296 "100272B5" received V 16:20:29.236 Writing request to characteristic 43ba4204-4cf5-46d8-a887-a846d9de712d D 16:20:29.236 gatt.writeCharacteristic(43ba4204-4cf5-46d8-a887-a846d9de712d, value=0xD204) I 16:20:29.741 Data written to 43ba4204-4cf5-46d8-a887-a846d9de712d, value: (0x) D2-04 A 16:20:29.741 "(0x) D2-04" sent V 16:20:37.673 [DFU] DFU service started V 16:20:37.673 [DFU] Opening file... I 16:20:37.686 [DFU] Firmware file opened successfully V 16:20:37.686 [DFU] Connecting to DFU target... D 16:20:37.686 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) I 16:20:37.720 [DFU] Connected to FF:EC:FF:FE:CE:66 V 16:20:37.720 [DFU] Discovering services... D 16:20:37.720 [DFU] gatt.discoverServices() I 16:20:37.720 [DFU] Services discovered D 16:20:37.720 [DFU] wait(1000) V 16:20:38.751 [DFU] Reading DFU version number... D 16:20:38.751 [DFU] gatt.readCharacteristic(00001534-1212-efde-1523-785feabcd123) I 16:20:39.159 [DFU] Read Response received from 00001534-1212-efde-1523-785feabcd123, value (0x): 01-00 A 16:20:39.159 [DFU] Version number read: 0.1 W 16:20:39.159 [DFU] Application with buttonless update found V 16:20:39.159 [DFU] Jumping to the DFU Bootloader... V 16:20:39.159 [DFU] Requesting new MTU... D 16:20:39.159 [DFU] gatt.requestMtu(517) I 16:20:39.857 [DFU] MTU changed to: 23 V 16:20:39.857 [DFU] Enabling notifications for 00001531-1212-efde-1523-785feabcd123 D 16:20:39.857 [DFU] gatt.setCharacteristicNotification(00001531-1212-efde-1523-785feabcd123, true) D 16:20:39.857 [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 16:20:40.912 [DFU] Data written to descr.00001531-1212-efde-1523-785feabcd123, value (0x): 01-00 V 16:20:40.912 [DFU] Notifications enabled for 00001531-1212-efde-1523-785feabcd123 A 16:20:40.912 [DFU] Notifications enabled D 16:20:40.912 [DFU] wait(1000) V 16:20:41.933 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:20:41.933 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) A 16:20:42.295 [DFU] Jump to bootloader sent (Op Code = 1, Upload Mode = 4) D 16:20:42.295 [DFU] gatt.refresh() (hidden) D 16:20:42.312 [DFU] gatt.disconnect() D 16:20:42.312 [DFU] gatt.close() V 16:20:42.345 [DFU] DFU service started I 16:20:42.345 [DFU] Firmware file opened successfully D 16:20:42.345 [DFU] wait(1000) D 16:20:43.331 [DFU] wait(1000) V 16:20:44.346 [DFU] Connecting to DFU target... D 16:20:44.347 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) I 16:20:44.368 [DFU] Connected to FF:EC:FF:FE:CE:66 V 16:20:44.368 [DFU] Discovering services... D 16:20:44.368 [DFU] gatt.discoverServices() I 16:20:45.091 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 16:20:54.868 [Callback] Connection state changed with status: 19 and new state: DISCONNECTED (0) W 16:20:54.869 Connection terminated by peer (status 19) I 16:20:54.869 Disconnected E 16:20:54.979 [DFU] Connection failed (0x13): GATT CONN TERMINATE PEER USER W 16:20:54.980 [DFU] Retrying... D 16:20:54.980 [DFU] gatt.refresh() (hidden) D 16:20:54.980 [DFU] gatt.disconnect() D 16:20:54.980 [DFU] gatt.close() D 16:20:54.980 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:20:55.023 [DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 16:20:55.023 [DFU] DFU service started I 16:20:55.023 [DFU] Firmware file opened successfully D 16:20:55.023 [DFU] wait(1000) D 16:20:56.055 [DFU] wait(1000) V 16:20:57.027 [DFU] Connecting to DFU target... D 16:20:57.027 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) E 16:21:02.071 [DFU] Connection failed (0x85): GATT ERROR W 16:21:02.071 [DFU] Retrying... D 16:21:02.071 [DFU] gatt.refresh() (hidden) D 16:21:02.071 [DFU] gatt.disconnect() D 16:21:02.096 [DFU] gatt.close() V 16:21:02.153 [DFU] DFU service started I 16:21:02.153 [DFU] Firmware file opened successfully D 16:21:02.153 [DFU] wait(1000) D 16:21:03.172 [DFU] wait(1000) V 16:21:04.161 [DFU] Connecting to DFU target... D 16:21:04.161 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) E 16:21:09.250 [DFU] Connection failed (0x85): GATT ERROR D 16:21:09.250 [DFU] gatt.refresh() (hidden) D 16:21:09.250 [DFU] gatt.disconnect() D 16:21:09.282 [DFU] gatt.close() D 16:21:09.282 [DFU] wait(600) D 16:21:09.882 gatt.close() D 16:21:09.891 wait(200) V 16:21:10.093 Connecting to FF:EC:FF:FE:CE:66... D 16:21:10.094 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:21:15.129 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0) E 16:21:15.129 Error 133 (0x85): GATT ERROR I 16:21:15.129 Disconnected
nRF Connect, 2022-07-26 SmartTag (FF:EC:FF:FE:CE:66) V 16:31:59.361 Connecting to FF:EC:FF:FE:CE:66... D 16:31:59.361 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) D 16:31:59.902 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:31:59.902 Connected to FF:EC:FF:FE:CE:66 D 16:31:59.922 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 16:31:59.936 Discovering services... D 16:31:59.936 gatt.discoverServices() D 16:32:01.166 [Callback] Services discovered with status: 0 I 16:32:01.166 Services discovered V 16:32:01.247 Generic Access (0x1800) - Device Name [R W] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Hardware Revision String [R] (0x2A27) - Firmware Revision String [R] (0x2A26) Unknown Service (43ba1a00-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4000-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4001-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4002-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a02-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4200-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4202-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4203-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4204-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a03-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4300-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4301-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4302-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4303-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4304-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a04-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4400-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4401-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4402-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (43ba4403-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4404-4cf5-46d8-a887-a846d9de712d) Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123) - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123) - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123) Client Characteristic Configuration (0x2902) - DFU Version [R] (00001534-1212-efde-1523-785feabcd123) Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e) - TX Characteristic [N R] (6e400003-b5a3-f393-e0a9-e50e24dcca9e) Client Characteristic Configuration (0x2902) - RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e) D 16:32:01.248 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 16:32:01.251 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 16:32:01.253 gatt.setCharacteristicNotification(43ba4000-4cf5-46d8-a887-a846d9de712d, true) D 16:32:01.255 gatt.setCharacteristicNotification(43ba4200-4cf5-46d8-a887-a846d9de712d, true) D 16:32:01.257 gatt.setCharacteristicNotification(43ba4400-4cf5-46d8-a887-a846d9de712d, true) D 16:32:01.261 gatt.setCharacteristicNotification(43ba4402-4cf5-46d8-a887-a846d9de712d, true) D 16:32:01.263 gatt.setCharacteristicNotification(43ba4403-4cf5-46d8-a887-a846d9de712d, true) D 16:32:01.266 gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true) V 16:32:20.430 Writing request to characteristic 43ba4204-4cf5-46d8-a887-a846d9de712d D 16:32:20.431 gatt.writeCharacteristic(43ba4204-4cf5-46d8-a887-a846d9de712d, value=0xD204) I 16:32:21.005 Data written to 43ba4204-4cf5-46d8-a887-a846d9de712d, value: (0x) D2-04 A 16:32:21.006 "(0x) D2-04" sent V 16:32:31.713 [DFU] DFU service started V 16:32:31.713 [DFU] Opening file... I 16:32:31.740 [DFU] Firmware file opened successfully V 16:32:31.740 [DFU] Connecting to DFU target... D 16:32:31.740 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) I 16:32:31.846 [DFU] Connected to FF:EC:FF:FE:CE:66 V 16:32:31.846 [DFU] Discovering services... D 16:32:31.846 [DFU] gatt.discoverServices() I 16:32:31.846 [DFU] Services discovered D 16:32:31.867 [DFU] wait(1000) V 16:32:32.861 [DFU] Reading DFU version number... D 16:32:32.861 [DFU] gatt.readCharacteristic(00001534-1212-efde-1523-785feabcd123) I 16:32:33.563 [DFU] Read Response received from 00001534-1212-efde-1523-785feabcd123, value (0x): 01-00 A 16:32:33.563 [DFU] Version number read: 0.1 W 16:32:33.563 [DFU] Application with buttonless update found V 16:32:33.563 [DFU] Jumping to the DFU Bootloader... V 16:32:33.563 [DFU] Requesting new MTU... D 16:32:33.563 [DFU] gatt.requestMtu(517) I 16:32:34.262 [DFU] MTU changed to: 23 V 16:32:34.262 [DFU] Enabling notifications for 00001531-1212-efde-1523-785feabcd123 D 16:32:34.262 [DFU] gatt.setCharacteristicNotification(00001531-1212-efde-1523-785feabcd123, true) D 16:32:34.262 [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 16:32:34.952 [DFU] Data written to descr.00001531-1212-efde-1523-785feabcd123, value (0x): 01-00 V 16:32:34.954 [DFU] Notifications enabled for 00001531-1212-efde-1523-785feabcd123 A 16:32:34.955 [DFU] Notifications enabled D 16:32:34.955 [DFU] wait(1000) V 16:32:35.976 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:32:35.976 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) A 16:32:36.357 [DFU] Jump to bootloader sent (Op Code = 1, Upload Mode = 4) D 16:32:36.357 [DFU] gatt.refresh() (hidden) D 16:32:36.357 [DFU] gatt.disconnect() D 16:32:36.369 [DFU] gatt.close() V 16:32:36.410 [DFU] DFU service started I 16:32:36.411 [DFU] Firmware file opened successfully D 16:32:36.411 [DFU] wait(1000) D 16:32:37.404 [DFU] wait(1000) V 16:32:38.427 [DFU] Connecting to DFU target... D 16:32:38.429 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) I 16:32:38.569 [DFU] Connected to FF:EC:FF:FE:CE:66 V 16:32:38.569 [DFU] Discovering services... D 16:32:38.569 [DFU] gatt.discoverServices() D 16:32:48.908 [Callback] Connection state changed with status: 19 and new state: DISCONNECTED (0) W 16:32:48.908 Connection terminated by peer (status 19) I 16:32:48.908 Disconnected E 16:32:48.971 [DFU] Connection failed (0x13): GATT CONN TERMINATE PEER USER W 16:32:48.971 [DFU] Retrying... D 16:32:48.971 [DFU] gatt.refresh() (hidden) D 16:32:48.971 [DFU] gatt.disconnect() D 16:32:48.971 [DFU] gatt.close() D 16:32:49.012 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:32:49.055 [DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 16:32:49.093 [DFU] DFU service started I 16:32:49.093 [DFU] Firmware file opened successfully D 16:32:49.093 [DFU] wait(1000) D 16:32:50.094 [DFU] wait(1000) V 16:32:51.081 [DFU] Connecting to DFU target... D 16:32:51.081 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) D 16:32:55.568 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED I 16:32:55.616 [DFU] Connected to FF:EC:FF:FE:CE:66 V 16:32:55.616 [DFU] Discovering services... D 16:32:55.616 [DFU] gatt.discoverServices() D 16:32:55.616 [DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED I 16:32:56.355 [DFU] Services discovered D 16:32:56.357 [DFU] wait(1000) V 16:32:57.354 [DFU] Reading DFU version number... D 16:32:57.354 [DFU] gatt.readCharacteristic(00001534-1212-efde-1523-785feabcd123) I 16:32:57.404 [DFU] Read Response received from 00001534-1212-efde-1523-785feabcd123, value (0x): 08-00 A 16:32:57.405 [DFU] Version number read: 0.8 V 16:32:57.405 [DFU] Requesting new MTU... D 16:32:57.405 [DFU] gatt.requestMtu(517) I 16:32:57.473 [DFU] MTU changed to: 23 D 16:32:57.474 [DFU] wait(1000) V 16:32:58.491 [DFU] Enabling notifications for 00001531-1212-efde-1523-785feabcd123 D 16:32:58.491 [DFU] gatt.setCharacteristicNotification(00001531-1212-efde-1523-785feabcd123, true) D 16:32:58.491 [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 16:32:58.520 [DFU] Data written to descr.00001531-1212-efde-1523-785feabcd123, value (0x): 01-00 V 16:32:58.520 [DFU] Notifications enabled for 00001531-1212-efde-1523-785feabcd123 A 16:32:58.520 [DFU] Notifications enabled D 16:32:58.520 [DFU] wait(1000) V 16:32:59.525 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:32:59.525 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) I 16:32:59.576 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 01-04 A 16:32:59.576 [DFU] DFU Start sent (Op Code = 1, Upload Mode = 4) V 16:32:59.576 [DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123 D 16:32:59.576 [DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123) I 16:32:59.576 [DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): 00-00-00-00-00-00-00-00-00-00-02-00 A 16:32:59.577 [DFU] Firmware image size sent (0b, 0b, 131072b) I 16:33:03.442 [DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-01-01 A 16:33:03.443 [DFU] Response received (Op Code = 1 Status = 1) A 16:33:03.443 [DFU] Writing Initialize DFU Parameters... V 16:33:03.443 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:33:03.443 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) I 16:33:03.509 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 02-00 V 16:33:03.509 [DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123 D 16:33:03.509 [DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123) I 16:33:03.509 [DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): 00-01-00-01-41-00-00-00-01-00-64-00-B6-73 V 16:33:03.510 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:33:03.510 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) I 16:33:03.575 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 02-01 A 16:33:03.575 [DFU] Initialize DFU Parameters completed I 16:33:03.575 [DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-02-01 A 16:33:03.575 [DFU] Response received (Op Code = 2, Status = 1) V 16:33:03.575 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:33:03.575 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) I 16:33:03.629 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 03 A 16:33:03.630 [DFU] Receive Firmware Image request sent A 16:33:03.633 [DFU] Uploading firmware... V 16:33:03.633 [DFU] Sending firmware to characteristic 00001532-1212-efde-1523-785feabcd123... I 16:33:52.903 [DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-03-01 A 16:33:52.903 [DFU] Response received (Op Code = 3, Status = 1) A 16:33:52.903 [DFU] Upload completed in 48444 ms V 16:33:52.903 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:33:52.903 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) I 16:33:52.972 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 04 A 16:33:52.972 [DFU] Validate request sent I 16:33:53.123 [DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-04-01 A 16:33:53.123 [DFU] Response received (Op Code = 4, Status = 1) V 16:33:53.155 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:33:53.155 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) I 16:33:53.203 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 05 A 16:33:53.203 [DFU] Activate and Reset request sent I 16:33:53.415 [DFU] Disconnected by the remote device D 16:33:53.415 [DFU] gatt.refresh() (hidden) D 16:33:53.415 [DFU] gatt.disconnect() D 16:33:53.461 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:33:53.462 [DFU] gatt.close() D 16:33:53.462 [DFU] wait(1400) D 16:33:53.462 [DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:33:54.937 gatt.close() D 16:33:54.940 wait(200) V 16:33:55.147 Connecting to FF:EC:FF:FE:CE:66... D 16:33:55.148 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) D 16:33:55.751 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:33:55.751 Connected to FF:EC:FF:FE:CE:66 D 16:33:55.807 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 16:33:55.808 Discovering services... D 16:33:55.808 gatt.discoverServices() D 16:33:56.819 [Callback] Services discovered with status: 0 I 16:33:56.819 Services discovered V 16:33:56.895 Generic Access (0x1800) - Device Name [R W] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Hardware Revision String [R] (0x2A27) - Firmware Revision String [R] (0x2A26) Unknown Service (43ba1a00-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4000-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4002-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a02-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4200-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4202-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4203-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4204-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4205-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4206-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a03-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4300-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4301-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4303-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a04-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4400-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4401-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4403-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4404-4cf5-46d8-a887-a846d9de712d) Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123) - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123) - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123) Client Characteristic Configuration (0x2902) - DFU Version [R] (00001534-1212-efde-1523-785feabcd123) D 16:33:56.896 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 16:33:56.899 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 16:33:56.902 gatt.setCharacteristicNotification(43ba4000-4cf5-46d8-a887-a846d9de712d, true) D 16:33:56.904 gatt.setCharacteristicNotification(43ba4200-4cf5-46d8-a887-a846d9de712d, true) D 16:33:56.907 gatt.setCharacteristicNotification(43ba4400-4cf5-46d8-a887-a846d9de712d, true) D 16:33:56.910 gatt.setCharacteristicNotification(43ba4403-4cf5-46d8-a887-a846d9de712d, true) V 16:34:11.270 Reading characteristic 00002a26-0000-1000-8000-00805f9b34fb D 16:34:11.270 gatt.readCharacteristic(00002a26-0000-1000-8000-00805f9b34fb) E 16:34:12.318 Error 133 (0x85): GATT ERROR D 16:34:12.353 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 16:34:12.353 Error 8 (0x8): GATT CONN TIMEOUT I 16:34:12.353 Disconnected D 16:34:12.535 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:34:16.473 gatt.close() D 16:34:16.475 wait(200) V 16:34:16.678 Connecting to FF:EC:FF:FE:CE:66... D 16:34:16.679 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) D 16:34:17.393 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:34:17.393 Connected to FF:EC:FF:FE:CE:66 D 16:34:17.432 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 16:34:17.486 Discovering services... D 16:34:17.486 gatt.discoverServices() D 16:34:18.462 [Callback] Services discovered with status: 0 I 16:34:18.462 Services discovered V 16:34:18.546 Generic Access (0x1800) - Device Name [R W] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Hardware Revision String [R] (0x2A27) - Firmware Revision String [R] (0x2A26) Unknown Service (43ba1a00-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4000-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4002-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a02-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4200-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4202-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4203-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4204-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4205-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4206-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a03-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4300-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4301-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4303-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a04-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4400-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4401-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4403-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4404-4cf5-46d8-a887-a846d9de712d) Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123) - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123) - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123) Client Characteristic Configuration (0x2902) - DFU Version [R] (00001534-1212-efde-1523-785feabcd123) D 16:34:18.547 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 16:34:18.550 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 16:34:18.553 gatt.setCharacteristicNotification(43ba4000-4cf5-46d8-a887-a846d9de712d, true) D 16:34:18.555 gatt.setCharacteristicNotification(43ba4200-4cf5-46d8-a887-a846d9de712d, true) D 16:34:18.557 gatt.setCharacteristicNotification(43ba4400-4cf5-46d8-a887-a846d9de712d, true) D 16:34:18.560 gatt.setCharacteristicNotification(43ba4403-4cf5-46d8-a887-a846d9de712d, true) V 16:34:31.203 Reading characteristic 00002a26-0000-1000-8000-00805f9b34fb D 16:34:31.203 gatt.readCharacteristic(00002a26-0000-1000-8000-00805f9b34fb) I 16:34:31.774 Read Response received from 00002a26-0000-1000-8000-00805f9b34fb, value: (0x) 33-2E-36, "3.6" A 16:34:31.774 "3.6" received
nRF Connect, 2022-07-26 No name (FF:EC:FF:FE:CE:66) V 16:12:06.816 Connecting to FF:EC:FF:FE:CE:66... D 16:12:06.816 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:12:07.365 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED D 16:12:07.441 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:12:07.441 Connected to FF:EC:FF:FE:CE:66 V 16:12:07.468 Discovering services... D 16:12:07.468 gatt.discoverServices() I 16:12:07.757 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 16:12:08.727 [Callback] Services discovered with status: 0 I 16:12:08.727 Services discovered V 16:12:08.824 Generic Access (0x1800) - Device Name [R W] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Hardware Revision String [R] (0x2A27) - Firmware Revision String [R] (0x2A26) Unknown Service (43ba1a00-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4000-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4001-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4002-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a02-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4200-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4202-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4203-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4204-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a03-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4300-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4301-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4302-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4303-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [R W] (43ba4304-4cf5-46d8-a887-a846d9de712d) Unknown Service (43ba1a04-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4400-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4401-4cf5-46d8-a887-a846d9de712d) - Unknown Characteristic [N R] (43ba4402-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (43ba4403-4cf5-46d8-a887-a846d9de712d) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W] (43ba4404-4cf5-46d8-a887-a846d9de712d) Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123) - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123) - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123) Client Characteristic Configuration (0x2902) - DFU Version [R] (00001534-1212-efde-1523-785feabcd123) Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e) - TX Characteristic [N R] (6e400003-b5a3-f393-e0a9-e50e24dcca9e) Client Characteristic Configuration (0x2902) - RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e) D 16:12:08.824 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 16:12:08.830 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 16:12:08.831 gatt.setCharacteristicNotification(43ba4000-4cf5-46d8-a887-a846d9de712d, true) D 16:12:08.833 gatt.setCharacteristicNotification(43ba4200-4cf5-46d8-a887-a846d9de712d, true) D 16:12:08.834 gatt.setCharacteristicNotification(43ba4400-4cf5-46d8-a887-a846d9de712d, true) D 16:12:08.835 gatt.setCharacteristicNotification(43ba4402-4cf5-46d8-a887-a846d9de712d, true) D 16:12:08.837 gatt.setCharacteristicNotification(43ba4403-4cf5-46d8-a887-a846d9de712d, true) D 16:12:08.840 gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true) I 16:12:09.090 Connection parameters updated (interval: 348.75ms, latency: 0, timeout: 4000ms) V 16:12:12.239 Reading characteristic 00002a25-0000-1000-8000-00805f9b34fb D 16:12:12.239 gatt.readCharacteristic(00002a25-0000-1000-8000-00805f9b34fb) I 16:12:12.937 Read Response received from 00002a25-0000-1000-8000-00805f9b34fb, value: (0x) 31-30-30-32-37-32-42-35, "100272B5" A 16:12:12.937 "100272B5" received V 16:12:15.996 Reading characteristic 00002a26-0000-1000-8000-00805f9b34fb D 16:12:15.996 gatt.readCharacteristic(00002a26-0000-1000-8000-00805f9b34fb) I 16:12:17.461 Read Response received from 00002a26-0000-1000-8000-00805f9b34fb, value: (0x) 30-32-2E-31-36-2E-30-30, "02.16.00" A 16:12:17.461 "02.16.00" received V 16:12:32.949 Writing request to characteristic 43ba4204-4cf5-46d8-a887-a846d9de712d D 16:12:32.950 gatt.writeCharacteristic(43ba4204-4cf5-46d8-a887-a846d9de712d, value=0xD204) I 16:12:33.503 Data written to 43ba4204-4cf5-46d8-a887-a846d9de712d, value: (0x) D2-04 A 16:12:33.504 "(0x) D2-04" sent V 16:12:46.343 [DFU] DFU service started V 16:12:46.343 [DFU] Opening file... I 16:12:46.357 [DFU] Firmware file opened successfully V 16:12:46.357 [DFU] Connecting to DFU target... D 16:12:46.357 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) I 16:12:46.373 [DFU] Connected to FF:EC:FF:FE:CE:66 V 16:12:46.373 [DFU] Discovering services... D 16:12:46.373 [DFU] gatt.discoverServices() I 16:12:46.390 [DFU] Services discovered D 16:12:46.390 [DFU] wait(1000) V 16:12:47.392 [DFU] Reading DFU version number... D 16:12:47.392 [DFU] gatt.readCharacteristic(00001534-1212-efde-1523-785feabcd123) I 16:12:47.809 [DFU] Read Response received from 00001534-1212-efde-1523-785feabcd123, value (0x): 01-00 A 16:12:47.809 [DFU] Version number read: 0.1 W 16:12:47.809 [DFU] Application with buttonless update found V 16:12:47.809 [DFU] Jumping to the DFU Bootloader... V 16:12:47.809 [DFU] Requesting new MTU... D 16:12:47.809 [DFU] gatt.requestMtu(517) I 16:12:48.860 [DFU] MTU changed to: 23 V 16:12:48.860 [DFU] Enabling notifications for 00001531-1212-efde-1523-785feabcd123 D 16:12:48.860 [DFU] gatt.setCharacteristicNotification(00001531-1212-efde-1523-785feabcd123, true) D 16:12:48.860 [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 16:12:49.545 [DFU] Data written to descr.00001531-1212-efde-1523-785feabcd123, value (0x): 01-00 V 16:12:49.545 [DFU] Notifications enabled for 00001531-1212-efde-1523-785feabcd123 A 16:12:49.545 [DFU] Notifications enabled D 16:12:49.545 [DFU] wait(1000) V 16:12:50.567 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123 D 16:12:50.567 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123) A 16:12:50.948 [DFU] Jump to bootloader sent (Op Code = 1, Upload Mode = 4) D 16:12:50.948 [DFU] gatt.refresh() (hidden) D 16:12:50.948 [DFU] gatt.disconnect() D 16:12:50.948 [DFU] gatt.close() V 16:12:50.965 [DFU] DFU service started I 16:12:50.965 [DFU] Firmware file opened successfully D 16:12:50.965 [DFU] wait(1000) D 16:12:51.967 [DFU] wait(1000) V 16:12:52.988 [DFU] Connecting to DFU target... D 16:12:52.988 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) I 16:12:52.988 [DFU] Connected to FF:EC:FF:FE:CE:66 V 16:12:52.988 [DFU] Discovering services... D 16:12:52.988 [DFU] gatt.discoverServices() I 16:12:53.379 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 16:13:03.516 [Callback] Connection state changed with status: 19 and new state: DISCONNECTED (0) W 16:13:03.517 Connection terminated by peer (status 19) I 16:13:03.517 Disconnected E 16:13:03.524 [DFU] Connection failed (0x13): GATT CONN TERMINATE PEER USER W 16:13:03.524 [DFU] Retrying... D 16:13:03.524 [DFU] gatt.refresh() (hidden) D 16:13:03.524 [DFU] gatt.disconnect() D 16:13:03.622 [DFU] gatt.close() D 16:13:03.629 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:13:03.647 [DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 16:13:03.675 [DFU] DFU service started I 16:13:03.675 [DFU] Firmware file opened successfully D 16:13:03.675 [DFU] wait(1000) D 16:13:04.679 [DFU] wait(1000) V 16:13:05.703 [DFU] Connecting to DFU target... D 16:13:05.704 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) E 16:13:10.723 [DFU] Connection failed (0x85): GATT ERROR W 16:13:10.723 [DFU] Retrying... D 16:13:10.723 [DFU] gatt.refresh() (hidden) D 16:13:10.723 [DFU] gatt.disconnect() D 16:13:10.738 [DFU] gatt.close() V 16:13:10.786 [DFU] DFU service started I 16:13:10.786 [DFU] Firmware file opened successfully D 16:13:10.786 [DFU] wait(1000) D 16:13:11.791 [DFU] wait(1000) V 16:13:12.816 [DFU] Connecting to DFU target... D 16:13:12.816 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M) E 16:13:17.832 [DFU] Connection failed (0x85): GATT ERROR D 16:13:17.832 [DFU] gatt.refresh() (hidden) D 16:13:17.832 [DFU] gatt.disconnect() D 16:13:17.832 [DFU] gatt.close() D 16:13:17.832 [DFU] wait(600) D 16:13:18.436 gatt.close() D 16:13:18.438 wait(200) V 16:13:18.640 Connecting to FF:EC:FF:FE:CE:66... D 16:13:18.640 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:13:23.661 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0) E 16:13:23.661 Error 133 (0x85): GATT ERROR I 16:13:23.662 Disconnected D 16:13:38.058 gatt.close() D 16:13:38.062 wait(200) V 16:13:38.264 Connecting to FF:EC:FF:FE:CE:66... D 16:13:38.264 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:13:43.297 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0) E 16:13:43.297 Error 133 (0x85): GATT ERROR I 16:13:43.297 Disconnected
