Cannot run ZAP tool
I am trying to create a Matter device by following the steps in https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_matter_creating_accessory.html
I fail to launch the ZAP tool as it seems that a version the script is looking for is missing and another one is present intead.
Indeed if I go in the folder /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/node_modules/sqlite3/lib/binding I see napi-v3-linux-glibc-x64 instead of v6. (see text in bold below)
⇝ A JavaScript error occurred in the main process
Uncaught Exception:
Error: Cannot find module '/home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/node_modules/sqlite3/lib/binding/napi-v6-linux-glibc-x64/node_sqlite3.node'
Require stack:
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/node_modules/sqlite3/lib/sqlite3-binding.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/node_modules/sqlite3/lib/sqlite3.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/dist/src-electron/db/db-api.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/dist/src-electron/db/query-package.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/dist/src-electron/util/util.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/dist/src-electron/ui/ui-util.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/dist/src-electron/ui/menu.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/dist/src-electron/ui/window.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/dist/src-electron/ui/main-ui.js
- /home/marco/Pingeco/exp/ncs/modules/lib/matter/third_party/zap/repo/node_modules/electron/dist/resources/default_app.asar/main.js
What am I doing wring?
Thank you.
