MPU6050 cannot calculating the value of 3 axis and the value return is 0. What is problem? How can I fix it ? Thanks for helping me.
AD0 open.Adress is 0x68
Here is my code
Main.c
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "mpu6050.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// initialize the logger
// create arrays which will hold x,y & z co-ordinates values of acc and gyro
static int16_t AccValue[3], GyroValue[3];
bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); // initialize the leds and buttons
// global function in mpu6050.c
twi_master_init(); // initialize the twi
nrf_delay_ms(1000); // give some delay
while (mpu6050_init() == false) // wait until MPU6050 sensor is successfully initialized
NRF_LOG_INFO("MPU_6050 initialization failed!!!"); // if it failed to initialize then print a message
nrf_delay_ms(1000);
NRF_LOG_INFO("MPU6050 Init Successfully!!!");
NRF_LOG_INFO("Reading Values from ACC & GYRO"); // display a message to let the user know that the device is starting to read the values
nrf_delay_ms(2000);
while (true)
{ // global function in mpu6050.c
if (MPU6050_ReadAcc(&AccValue[0], &AccValue[1], &AccValue[2]) == true) // Read acc value from mpu6050 internal registers and save them in the array
NRF_LOG_INFO("ACC Values: x = %d y = %d z = %d", AccValue[0], AccValue[1], AccValue[2]); // display the read values
NRF_LOG_INFO("Reading ACC values Failed!!!"); // if reading was unsuccessful then let the user know about it
if (MPU6050_ReadGyro(&GyroValue[0], &GyroValue[1], &GyroValue[2]) == true) // read the gyro values from mpu6050's internal registers and save them in another array
NRF_LOG_INFO("GYRO Values: x = %d y = %d z = %d", GyroValue[0], GyroValue[1], GyroValue[2]); // display then values
NRF_LOG_INFO("Reading GYRO values Failed!!!");
nrf_delay_ms(100); // give some delay
}mpu6050.c
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
//Initializing TWI0 instance
#define TWI_INSTANCE_ID 0
// A flag to indicate the transfer state
static volatile bool m_xfer_done = false;
// Create a Handle for the twi communication
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
//Event Handler
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
//Check the event to see what type of event occurred
switch (p_event->type)
//If data transmission or receiving is finished
case NRF_DRV_TWI_EVT_DONE:
m_xfer_done = true;//Set the flag
// do nothing
//Initialize the TWI as Master device
void twi_master_init(void)
ret_code_t err_code;
// Configure the settings for twi communication
const nrf_drv_twi_config_t twi_config = {
.scl = TWI_SCL_M, //SCL Pin
.sda = TWI_SDA_M, //SDA Pin
.frequency = NRF_DRV_TWI_FREQ_400K, //Communication Speed
.interrupt_priority = APP_IRQ_PRIORITY_HIGH, //Interrupt Priority(Note: if using Bluetooth then select priority carefully)
.clear_bus_init = false //automatically clear bus
//A function to initialize the twi communication
err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
//Enable the TWI Communication
nrf_drv_twi_enable(&m_twi);
A function to write a Single Byte to MPU6050's internal Register
bool mpu6050_register_write(uint8_t register_address, uint8_t value)
uint8_t tx_buf[MPU6050_ADDRESS_LEN+1];
//Write the register address and data into transmit buffer
tx_buf[0] = register_address;
tx_buf[1] = value;
//Set the flag to false to show the transmission is not yet completed
//Transmit the data over TWI Bus
err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, tx_buf, MPU6050_ADDRESS_LEN+1, false);
//Wait until the transmission of the data is finished
while (m_xfer_done == false)
// if there is no error then return true else return false
if (NRF_SUCCESS != err_code)
return false;
return true;
A Function to read data from the MPU6050
bool mpu6050_register_read(uint8_t register_address, uint8_t * destination, uint8_t number_of_bytes)
//Set the flag to false to show the receiving is not yet completed
// Send the Register address where we want to write the data
err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, ®ister_address, 1, true);
//Wait for the transmission to get completed
while (m_xfer_done == false){}
// If transmission was not successful, exit the function with false as return value
return false;
//set the flag again so that we can read data from the MPU6050's internal register
// Receive the data from the MPU6050
err_code = nrf_drv_twi_rx(&m_twi, MPU6050_ADDRESS, destination, number_of_bytes);
//wait until the transmission is completed
// if data was successfully read, return true else return false
return false;
return true;
A Function to verify the product id
(its a basic test to check if we are communicating with the right slave, every type of I2C Device has
a special WHO_AM_I register which holds a specific value, we can read it from the MPU6050 or any device
to confirm we are communicating with the right device)
bool mpu6050_verify_product_id(void)
uint8_t who_am_i; // create a variable to hold the who am i value
// Note: All the register addresses including WHO_AM_I are declared in
// MPU6050.h file, you can check these addresses and values from the
// datasheet of your slave device.
if (mpu6050_register_read(ADDRESS_WHO_AM_I, &who_am_i, 1))
if (who_am_i != MPU6050_WHO_AM_I)
return false;
return true;
return false;
Function to initialize the mpu6050
bool mpu6050_init(void)
bool transfer_succeeded = true;
//Check the id to confirm that we are communicating with the right device
transfer_succeeded &= mpu6050_verify_product_id();
if(mpu6050_verify_product_id() == false)
return false;
// Set the registers with the required values, see the datasheet to get a good idea of these values
(void)mpu6050_register_write(MPU_PWR_MGMT1_REG , 0x00);
(void)mpu6050_register_write(MPU_SAMPLE_RATE_REG , 0x07);
(void)mpu6050_register_write(MPU_CFG_REG , 0x06);
(void)mpu6050_register_write(MPU_INT_EN_REG, 0x00);
(void)mpu6050_register_write(MPU_GYRO_CFG_REG , 0x18);
(void)mpu6050_register_write(MPU_ACCEL_CFG_REG,0x00);
return transfer_succeeded;
Read the Gyro values from the MPU6050's internal Registers
bool MPU6050_ReadGyro(int16_t *pGYRO_X , int16_t *pGYRO_Y , int16_t *pGYRO_Z )
uint8_t buf[6];
bool ret = false;
if(mpu6050_register_read(MPU6050_GYRO_OUT, buf, 6) == true)
*pGYRO_X = (buf[0] << 8) | buf[1];
if(*pGYRO_X & 0x8000) *pGYRO_X-=65536;
*pGYRO_Y= (buf[2] << 8) | buf[3];
if(*pGYRO_Y & 0x8000) *pGYRO_Y-=65536;
*pGYRO_Z = (buf[4] << 8) | buf[5];
if(*pGYRO_Z & 0x8000) *pGYRO_Z-=65536;
ret = true;
return ret;
A Function to read accelerometer's values from the internal registers of MPU6050
bool MPU6050_ReadAcc( int16_t *pACC_X , int16_t *pACC_Y , int16_t *pACC_Z )
uint8_t buf[6];
bool ret = false;
if(mpu6050_register_read(MPU6050_ACC_OUT, buf, 6) == true)
mpu6050_register_read(MPU6050_ACC_OUT, buf, 6);
*pACC_X = (buf[0] << 8) | buf[1];
if(*pACC_X & 0x8000) *pACC_X-=65536;
*pACC_Y= (buf[2] << 8) | buf[3];
if(*pACC_Y & 0x8000) *pACC_Y-=65536;
*pACC_Z = (buf[4] << 8) | buf[5];
if(*pACC_Z & 0x8000) *pACC_Z-=65536;
ret = true;
return ret;
}mpu6050.h
#ifndef AT24C02_H__ #define AT24C02_H__ #include "nrf_delay.h" //I2C Pins Settings, you change them to any other pins #define TWI_SCL_M 21 //I2C SCL Pin #define TWI_SDA_M 11 //I2C SDA Pin #define MPU6050_ADDRESS_LEN 1 //MPU6050 #define MPU6050_ADDRESS (0x68U) //MPU6050 Device Address #define MPU6050_WHO_AM_I 0x68U //MPU6050 ID #define MPU6050_GYRO_OUT 0x43 #define MPU6050_ACC_OUT 0x3B #define ADDRESS_WHO_AM_I (0x75U) // WHO_AM_I register identifies the device. Expected value is 0x68. #define ADDRESS_SIGNAL_PATH_RESET (0x68U) // //MPU6050 Registers addresses, see datasheet for more info and each register's function #define MPU_SELF_TESTX_REG 0x0D #define MPU_SELF_TESTY_REG 0x0E #define MPU_SELF_TESTZ_REG 0x0F #define MPU_SELF_TESTA_REG 0x10 #define MPU_SAMPLE_RATE_REG 0x19 #define MPU_CFG_REG 0x1A #define MPU_GYRO_CFG_REG 0x1B #define MPU_ACCEL_CFG_REG 0x1C #define MPU_MOTION_DET_REG 0x1F #define MPU_FIFO_EN_REG 0x23 #define MPU_I2CMST_CTRL_REG 0x24 #define MPU_I2CSLV0_ADDR_REG 0x25 #define MPU_I2CSLV0_REG 0x26 #define MPU_I2CSLV0_CTRL_REG 0x27 #define MPU_I2CSLV1_ADDR_REG 0x28 #define MPU_I2CSLV1_REG 0x29 #define MPU_I2CSLV1_CTRL_REG 0x2A #define MPU_I2CSLV2_ADDR_REG 0x2B #define MPU_I2CSLV2_REG 0x2C #define MPU_I2CSLV2_CTRL_REG 0x2D #define MPU_I2CSLV3_ADDR_REG 0x2E #define MPU_I2CSLV3_REG 0x2F #define MPU_I2CSLV3_CTRL_REG 0x30 #define MPU_I2CSLV4_ADDR_REG 0x31 #define MPU_I2CSLV4_REG 0x32 #define MPU_I2CSLV4_DO_REG 0x33 #define MPU_I2CSLV4_CTRL_REG 0x34 #define MPU_I2CSLV4_DI_REG 0x35 #define MPU_PWR_MGMT1_REG 0x6B #define MPU_PWR_MGMT2_REG 0x6C #define MPU_I2CMST_STA_REG 0x36 #define MPU_INTBP_CFG_REG 0x37 #define MPU_INT_EN_REG 0x38 #define MPU_INT_STA_REG 0x3A #define MPU_I2CMST_DELAY_REG 0x67 #define MPU_SIGPATH_RST_REG 0x68 #define MPU_MDETECT_CTRL_REG 0x69 #define MPU_USER_CTRL_REG 0x6A #define MPU_PWR_MGMT1_REG 0x6B #define MPU_PWR_MGMT2_REG 0x6C #define MPU_FIFO_CNTH_REG 0x72 #define MPU_FIFO_CNTL_REG 0x73 #define MPU_FIFO_RW_REG 0x74 #define MPU_DEVICE_ID_REG 0x75 void twi_master_init(void); // initialize the twi communication bool mpu6050_init(void); // initialize the mpu6050 /** @brief Function for writing a MPU6050 register contents over TWI. @param[in] register_address Register address to start writing to @param[in] value Value to write to register @retval true Register write succeeded @retval false Register write failed */ bool mpu6050_register_write(uint8_t register_address, const uint8_t value); /** @brief Function for reading MPU6050 register contents over TWI. Reads one or more consecutive registers. @param[in] register_address Register address to start reading from @param[in] number_of_bytes Number of bytes to read @param[out] destination Pointer to a data buffer where read data will be stored @retval true Register read succeeded @retval false Register read failed */ bool mpu6050_register_read(uint8_t register_address, uint8_t *destination, uint8_t number_of_bytes); /** @brief Function for reading and verifying MPU6050 product ID. @retval true Product ID is what was expected @retval false Product ID was not what was expected */ bool mpu6050_verify_product_id(void); bool MPU6050_ReadGyro(int16_t *pGYRO_X , int16_t *pGYRO_Y , int16_t *pGYRO_Z ); bool MPU6050_ReadAcc( int16_t *pACC_X , int16_t *pACC_Y , int16_t *pACC_Z ); #endif
