NRF5340: MCU Boot + SMP server callbacks
we use nrf5340 with Connect SDK v2.0.0 and we have adopted rules for indicating the update process and the operation of the bootloader in the device. Therefore, I would like to know:
  1. How can I understand that a connection to the server has occurred? Is it possible to assign a custom callback to SMP server running events?
  2. Similar question for bootloader. Is there a possibility (regular, without editing the sources) to obtain information about the process of transferring an image from one slot to another?
  3. To keep the device running, I need to generate a PWM signal (feature of the circuit). Accordingly, I need to start the PWM module before entering the MCU boot, but I didn't find a way to do it.   I know that it is possible to request a function call before the Zephyr kernel (SYS_INIT(pwmOutInit, PRE_KERNEL_2, 0);) starts, but this call again occurs after the MCU boot has started. Do I need to write my own power driver and replace the existing Zephyr? Or is it possible again to get access directly at the time of launching the MCU?
Thanks
  • To get information about the progress of the update, just use the following code:
    struct img_mgmt_dfu_callbacks_t dfuCallbacks;
    dfuCallbacks.dfu_confirmed_cb = dfu_confirmed;
    dfuCallbacks.dfu_started_cb = dfu_started;
    dfuCallbacks.dfu_stopped_cb = dfu_stopped;
    dfuCallbacks.dfu_pending_cb = dfu_pending;
    img_mgmt_register_callbacks(&dfuCallbacks);
  • What are the CONFIGs to add and header files to include?
  • I don’t remember everything that is needed for this, since the project is now a little abandoned. The project configuration contains the following:
    CONFIG_BT_SMP=y
    CONFIG_MCUBOOT_IMAGE_VERSION="1.1.10+0"
    CONFIG_MCUMGR=y
    CONFIG_MCUMGR_SMP_BT=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    # Enable custom SMP request to erase settings partition.
    CONFIG_MCUMGR_GRP_ZEPHYR_BASIC=y
    CONFIG_MCUMGR_GRP_BASIC_CMD_STORAGE_ERASE=y
    # Bootloader configuration
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
    I did this with an eye on the documentation provided by Nordic. and Google search, of course. and a couple of issues were resolved in the Zephyr discord server
    Good luck!
