BT_HCI_SPI and BSDLib, chasing down increased HCI processing latency
Hey!
I have inherited a project with a nRF9160 + nRF52480 combination to do LTE and BLE communication.
The setup is as follows:
- nRF9160 using BSDlib @ NCS 1.5.0
- nRF52840 running HCI_SPI example acting as a controller
Issue:
Host (nRF9160) is unable to keep up with interrupts generated by HCI controller. When the IRQ is lost / not processed quickly enough the HCI layer gets stuck in a situation where the HCI controller waits for the host to read data, and the host waits for an interrupt that never comes (the IRQ is trigger by GPIO state change, but the IRQ pin is already active (low on our board).
I have gone through the threads running in this application (7 in total) and they are all with lower priority than the HCI SPI thread. The only thing I have found that have higher priority (except for kernel stuff) is the BSDLib interrupts.
This also correlates with my findings when probing the IRQ pin, activity stops dead when there is LTE traffic (MQTT data in this application).
My question is then:
Does it sound reasonable that HCI SPI processing gets interrupted and delayed by BSDLib? Any tips on how I can verify/debunk my theory?
EDIT: bluetooth is running a a simple passive advertisement scanner
    Thanks for your queries.
    Have you reset the IRQ pin after getting the interrupt?
    Best Regards,
    Kazi Afroza Sultana
  • Hey and thank you for the answer
    Yes, the IRQ pin is reenabled after the SPI read (the HCI spi code is untouched). I can also mention that the hardware setup is verified using more simple examples, the issue only seems to appear when introducing the actual product application.
  • Hi, I see that the only thing the ISR does is give a semaphore. So even if that's delayed, the message shouldn't get lost, it's only the big while loop that does the processing that will be delayed.
    If it does indeed get lost, I think that would indicate a problem on the controller side, e.g., discarding buffers not received in time. But I think that's also not the case since you say it gets stuck (so it must be filling up a buffer pool that doesn't get emptied by the other side).
    Could you instrument zephyr/drivers/bluetooth/hci/spi.c in a few strategic places to confirm if processing is stuck? Like a log_dbg right after the while(true) (~L285) but before the sem take, also between the two sem takes a line or two below. There's already one after the second sem take.
    I'm also wondering if your interrupt pin isn't getting reconfigured by the rest of the application, that could also be why you're seeing erratic behavior. You could try also putting a log_dbg inside the spi.c ISR.
    You can try to add log-dbg after the while loop before first semaphore (Line 285) the way Jonathan Rico suggested.  Your NCS version (NCS 1.5) is also quite old. Berkeley Software Distribution (BSD) library is now called modemlib. You may consider to upgrade the version of NCS.
    Thanks.
    Best Regards,
    Kazi Afroza Sultana
