I've installed nRF Connect and VSCode on a MacBook Air M1. Whenever I try to build my existing firmware that builds fine under Windows, I get the following error:
The terminal process failed to launch (exit code: 1).
I tried reinstalling VSCode, but this did not help. I've used this MacBook Air previously for builds, but had to switch to Windows because of some tool problems with MCUBOOT builds. I'm trying to switch back to the MacBook Air now to try to use SDK v2.0.0.
My support information is below. I suspect this issue occurs because of the line "shell": null.
How do I set the shell to be used for builds?
Steve
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
"platform": {
"os": "darwin",
"osVersion": "Darwin Kernel Version 21.4.0: Fri Mar 18 00:47:26 PDT 2022; root:xnu-8020.101.4~15/RELEASE_ARM64_T8101",
"osKernel": "21.4.0",
"vscode": "1.70.1",
"electron": "18.3.5",
"node": "v16.13.2"
"system": {
"date": "2022-08-11T12:08:15.848Z",
"vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
"vscodeUptime": "00:16:15",
"osUptime": "14:26:18",
"cpu": {
"model": "Apple M1",
"speed": "24 MHz",
"count": 4
"memory": {
"total": "16.00 GB",
"free": "0.24 GB"
"workspace": {
"name": "display-firmware",
"workspaceFile": null,
"folders": [
"/Users/Steve/Projects/display-firmware"
"extensions": {
"internal": {
"version": "2022.7.242",
"path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-connect-2022.7.242-darwin-x64",
"isActive": true
"version": "2022.7.21",
"path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.7.21",
"isActive": true
"version": "2022.7.36",
"path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2022.7.36",
"isActive": true
"version": "2022.7.24",
"path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2022.7.24",
"isActive": true
"external": {
"marus25.cortex-debug": "1.4.4",
"ms-vscode.cpptools": "1.11.5",
"ms-vscode.js-debug": "1.70.0",
"ms-vscode.js-debug-companion": "1.0.18",
"ms-vscode.vscode-js-profile-table": "1.0.3",
"twxs.cmake": "0.0.17"
"tools": {
"/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.14.1",
"/Applications/SEGGER/JLink/JLinkExe": "7.64c",
"/usr/local/bin/nrfjprog": "10.15.4",
"nrfutil": "Not found",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/cmake": "3.20.5",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/west": "0.13.1",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/python3": "3.9.6",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/ninja": "1.10.2",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/gperf": "3.1",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/dtc": "1.6.1",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/gn": "2039",
"/opt/nordic/ncs/toolchains/v2.0.0/bin/git": "2.32.0"
"sdks": [
"version": "2.0.0",
"path": "/opt/nordic/ncs/v2.0.0"
"version": "1.9.1",
"path": "/opt/nordic/ncs/v1.9.1"
"toolchains": [
"version": "1.9.1",
"path": {
"$mid": 1,
"fsPath": "/opt/nordic/ncs/v1.9.1/toolchain",
"path": "/opt/nordic/ncs/v1.9.1/toolchain",
"scheme": "file"
"version": "2.0.0",
"path": {
"$mid": 1,
"fsPath": "/opt/nordic/ncs/toolchains/v2.0.0",
"path": "/opt/nordic/ncs/toolchains/v2.0.0",
"scheme": "file"
"connectedDevices": [],
"deviceProviders": [
"nrfjprog"
"config": {
"topdir": "${nrf-connect.sdk:2.0.0}",
"toolchain": {
"path": "${nrf-connect.toolchain:2.0.0}"
"ozonePath": "",
"applications": [
"${workspaceFolder}"
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"welcome": {
"showOnStartup": true
"west": {
"env": {
"$base": "terminal"
"boardRoots": [
"enableTelemetry": true,
"taskBindings": {},
"debugging": {
"backend": "Cortex-Debug"
"activeAppFollowActiveEditor": true
"terminalMode": "character"
"marus25.cortex-debug": {
"armToolchainPath": null,
"armToolchainPrefix": "arm-none-eabi",
"gdbPath": null,
"objdumpPath": null,
"JLinkGDBServerPath": null,
"openocdPath": null,
"pyocdPath": null,
"PEGDBServerPath": null,
"stutilPath": null,
"stlinkPath": null,
"stm32cubeprogrammer": null,
"flattenAnonymous": false,
"registerUseNaturalFormat": true,
"variableUseNaturalFormat": true,
"dbgServerLogfile": null,
"showRTOS": false,
"showDevDebugOutput": "none"
"environment": {
"westExe": "west",
"westEnv": {
"ELECTRON_RUN_AS_NODE": "1",
"GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/v2.0.0/Cellar/git/2.32.0_1/libexec/git-core",
"HOME": "/Users/Steve",
"PATH": "/opt/nordic/ncs/toolchains/v2.0.0/bin:/opt/nordic/ncs/toolchains/v2.0.0/opt/bin:/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/v2.0.0/arm-zephyr-eabi/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
"ZEPHYR_BASE": "/opt/nordic/ncs/v2.0.0/zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk",
"USER": "Steve"
"inherited": {
"PATH": "/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
"USER": "Steve"
"toolchainPath": "/opt/nordic/ncs/toolchains/v2.0.0",
"toolchainBinPath": "/opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin",
"toolchainVersion": "2.0.0"
"terminal": {
"shell": null,
"defaultProfile": null
