mcuboot not recognizing the image to swap
I am using nCS and mcuboot in my application for development, on nRF52833.
I build a nCS project, the build bin file (prj.conf as ):
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_CONSOLE=y
CONFIG_PRINTK=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
# General configuration
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_HWINFO=y
CONFIG_DK_LIBRARY=y
# Bluetooth configuration
CONFIG_BT=y
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_L2CAP_TX_MTU=69
CONFIG_BT_L2CAP_TX_BUF_COUNT=8
CONFIG_BT_OBSERVER=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_SETTINGS=y
# Disable unused Bluetooth features
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_DATA_LEN_UPDATE=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_PRIVACY=n
# Bluetooth Mesh configuration
CONFIG_BT_MESH=y
CONFIG_BT_MESH_RELAY=y
CONFIG_BT_MESH_FRIEND=n
CONFIG_BT_MESH_ADV_BUF_COUNT=13
CONFIG_BT_MESH_RX_SEG_MAX=32
CONFIG_BT_MESH_TX_SEG_MAX=32
CONFIG_BT_MESH_PB_GATT=y
CONFIG_BT_MESH_GATT_PROXY=y
CONFIG_BT_MESH_DK_PROV=y
CONFIG_BT_MESH_TX_SEG_MSG_COUNT=20
CONFIG_BT_MESH_RX_SEG_MSG_COUNT=20
CONFIG_BT_MESH_SEG_BUFS=250
CONFIG_BT_MESH_MSG_CACHE_SIZE=50
# Enable Bluetooth mesh models debug logs
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_MESH_DEBUG=y
CONFIG_BT_MESH_DEBUG_MODEL=y
#external flash
CONFIG_SPI_NOR=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_SPI_NOR_SFDP_RUNTIME=n
CONFIG_SPI=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_SERIAL=y
#provisioning
#CONFIG_BT_MESH_DEBUG_PROV_DEVICE=y
#mcuboot
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=32
# Enable mcumgr.
CONFIG_MCUMGR=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# Allow for large Bluetooth data packets.
CONFIG_BT_L2CAP_TX_MTU=252
CONFIG_BT_BUF_ACL_RX_SIZE=256
# Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_BT_AUTHEN=n
# Some command handlers require a large stack.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
#CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
I broke up into packets using a python script.
Futher these packets I transferred to my board via BLE and dumped into the serial flash, post dumping successfully,
I hard reset the board and got mcuboot logs as in the snap:
I do not understand why mcuboot is not recognizing my image to swap.
my partition is as:
external_flash:
  address: 0x00000
  end_address: 0x80000
  region: external_flash
mcuboot_secondary:
  address: 0x00000
  device: IS25
  end_address: 0x64000
Am I missing something which marks the image trailer as to be copied..?
I feel I am not rightly using img_mgmt_register_group();
