I am using nCS and mcuboot in my application for development, on nRF52833.
I build a nCS project, the build bin file (prj.conf as ):
CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_CONSOLE=y CONFIG_PRINTK=y CONFIG_LOG=y CONFIG_LOG_DEFAULT_LEVEL=4 # General configuration CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y CONFIG_HWINFO=y CONFIG_DK_LIBRARY=y # Bluetooth configuration CONFIG_BT=y CONFIG_BT_DEVICE_NAME_DYNAMIC=y CONFIG_BT_L2CAP_TX_MTU=69 CONFIG_BT_L2CAP_TX_BUF_COUNT=8 CONFIG_BT_OBSERVER=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_SETTINGS=y # Disable unused Bluetooth features CONFIG_BT_CTLR_DUP_FILTER_LEN=0 CONFIG_BT_CTLR_LE_ENC=n CONFIG_BT_DATA_LEN_UPDATE=n CONFIG_BT_PHY_UPDATE=n CONFIG_BT_CTLR_CHAN_SEL_2=n CONFIG_BT_CTLR_MIN_USED_CHAN=n CONFIG_BT_CTLR_PRIVACY=n # Bluetooth Mesh configuration CONFIG_BT_MESH=y CONFIG_BT_MESH_RELAY=y CONFIG_BT_MESH_FRIEND=n CONFIG_BT_MESH_ADV_BUF_COUNT=13 CONFIG_BT_MESH_RX_SEG_MAX=32 CONFIG_BT_MESH_TX_SEG_MAX=32 CONFIG_BT_MESH_PB_GATT=y CONFIG_BT_MESH_GATT_PROXY=y CONFIG_BT_MESH_DK_PROV=y CONFIG_BT_MESH_TX_SEG_MSG_COUNT=20 CONFIG_BT_MESH_RX_SEG_MSG_COUNT=20 CONFIG_BT_MESH_SEG_BUFS=250 CONFIG_BT_MESH_MSG_CACHE_SIZE=50 # Enable Bluetooth mesh models debug logs CONFIG_BT_DEBUG_LOG=y CONFIG_BT_MESH_DEBUG=y CONFIG_BT_MESH_DEBUG_MODEL=y #external flash CONFIG_SPI_NOR=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_SPI_NOR_SFDP_RUNTIME=n CONFIG_SPI=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y #provisioning #CONFIG_BT_MESH_DEBUG_PROV_DEVICE=y #mcuboot CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=32 # Enable mcumgr. CONFIG_MCUMGR=y # Enable most core commands. CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_MCUMGR_CMD_OS_MGMT=y # Allow for large Bluetooth data packets. CONFIG_BT_L2CAP_TX_MTU=252 CONFIG_BT_BUF_ACL_RX_SIZE=256 # Enable the Bluetooth (unauthenticated) and shell mcumgr transports. CONFIG_MCUMGR_SMP_BT=y CONFIG_MCUMGR_SMP_BT_AUTHEN=n # Some command handlers require a large stack. CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 #CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y
I broke up into packets using a python script.
Futher these packets I transferred to my board via BLE and dumped into the serial flash, post dumping successfully,
I hard reset the board and got mcuboot logs as in the snap:
I do not understand why mcuboot is not recognizing my image to swap.
my partition is as:
external_flash: address: 0x00000 end_address: 0x80000 region: external_flash size: 0x80000 mcuboot_secondary: address: 0x00000 device: IS25 end_address: 0x64000 region: external_flash size: 0x64000
Am I missing something which marks the image trailer as to be copied..?
I feel I am not rightly using img_mgmt_register_group();
