QSPI chip select not working for a given pin when initialized through Zephyr (2.7.1)
I currently have an issue where by the Chip-Select is not toggled at all when configuring the csn pin to pin <18> on the Nrf52840 using Zephyr (version 2.7.1).
See dts configuration (zephyr.dts) with P0.18 as Chip Select below:
		qspi: qspi@40029000 {
			compatible = "nordic,nrf-qspi";
			#address-cells = < 0x1 >;
			#size-cells = < 0x0 >;
			reg = < 0x40029000 0x1000 >;
			interrupts = < 0x29 0x1 >;
			status = "okay";
			label = "QSPI";
			sck-pin = < 0x13 >;
			io-pins = < 0x15 >, < 0x16 >;
			csn-pins = < 0x12 >;
			mx25l1606: mx25l1606e@0 {
				status = "okay";
				compatible = "nordic,qspi-nor";
				reg = < 0x0 >;
				writeoc = "pp";
				readoc = "fastread";
				sck-frequency = < 0xf42400 >;
				label = "MX25L1606E";
				jedec-id = [ C2 20 15 ];
				sck-delay = < 0x1 >;
				sfdp-bfp = [ E5 20 F1 FF FF FF 7F 00 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00 FF 0C 20 0F 52 10 D8 00 FF 23 72 F5 00 82 ED 04 B7 44 83 38 44 30 B0 30 B0 F7 C4 D5 5C 00 BE 29 FF F0 D0 FF FF ];
				size = < 0x200000 >;
				has-dpd;
				t-enter-dpd = < 0x2710 >;
				t-exit-dpd = < 0x88b8 >;
See dts configuration (zephyr.dts) with P1.05 as Chip Select below:
			status = "okay";
			label = "QSPI";
			sck-pin = < 0x13 >;
			csn-pins = < 0x25 >;
				status = "okay";
				reg = < 0x0 >;
				writeoc = "pp";
				has-dpd;
Searching the zephyr.dts file for any instances of '0x12' shows no GPIO pin conflicts. And using a nrfx implementation using the same pin works correctly.
Zephyr generated nrfx_qspi_config_t struct:
QSPIconfig	nrfx_qspi_config_t	{...}
	xip_offset	uint32_t	0
	pins	nrf_qspi_pins_t	{...}
		sck_pin	uint8_t	19 '\023'
		csn_pin	uint8_t	18 '\022'
		io0_pin	uint8_t	21 '\025'
		io1_pin	uint8_t	22 '\026'
		io2_pin	uint8_t	255 'ÿ'
		io3_pin	uint8_t	255 'ÿ'
	prot_if	nrf_qspi_prot_conf_t	{...}
		readoc	nrf_qspi_readoc_t	NRF_QSPI_READOC_FASTREAD
		writeoc	nrf_qspi_writeoc_t	NRF_QSPI_WRITEOC_PP
		addrmode	nrf_qspi_addrmode_t	NRF_QSPI_ADDRMODE_24BIT
		dpmconfig	_Bool	false
	phy_if	nrf_qspi_phy_conf_t	{...}
		sck_delay	uint8_t	1 '\001'
		dpmen	_Bool	false
		spi_mode	nrf_qspi_spi_mode_t	NRF_QSPI_MODE_0
		sck_freq	nrf_qspi_frequency_t	NRF_QSPI_FREQ_DIV2
	irq_priority	uint8_t	0 '\0'
in-house nrfx_qspi_config_t struct:
qspiConfig	nrfx_qspi_config_t	{...}
		dpmen	_Bool	false
		sck_freq	nrf_qspi_frequency_t	NRF_QSPI_FREQ_32MDIV2
	irq_priority	uint8_t	7 '\a'
Am I missing any other configuration that should be made?
