Throughput with Master Emulator (PC -> DK)
Hi
For a test Environment, I use Master Emulator (C#). What is the highest data throughput, I can achieve when I send from PC to DK with the Master Emulator?
I use the following configuration:
  • Master Emulator 2.1.13.14 within C#
  • Dongle with MEFW 0.11.0
  • Connection Intervall 7.5ms
When I send data from DK to PC, I can achieve about 70kbps, which is ok. But when I send data from PC to DK I can only achieve 2-3kpbs which is too slow.
I read through this thread, but I did not found a solution for my problem.
Is there a solution to get more data throughput? Or is an example available in C#, which I can achieve a higher throughput
Thanks
