nrf_pwr_mgmt_run impact of SCB_SCR_SLEEPDEEP_Msk
Hi
I could not really find a satisfactory answer to my question, what (if any) impact has the setting of the SLEEPDEEEP bit before calling nrf_pwr_mgmt_run? I'm wondering if the SD in  sd_app_evt_wait() overwrites those registers anyway or what it is doing, from what I read is, that it internally also calls the _WFE instruction.
// Set SLEEPDEEP bit of Cortex System Control Register
SCB->SCR |= (uint32_t)SCB_SCR_SLEEPDEEP_Msk;
nrf_pwr_mgmt_run();
Setup:
  • nrf52840
  • SDK 17.x
  • Using the SD 140 (enabled)
Further questions:
  1. Are HFCLK and LFCLK runing in SYSTEM_ON mode? Does SLEEPDEEP have any impact on this?
  2. Does the system wakeup from a timer peripheral interrupt/expiry? TIMER4 in this case system.
  3. Does the system wakeup from the RTC interrupt/expiry.
How I would approach low power consumption with my current knowledge:
  • disable unused peripherals
  • configure perhipherals from which the system shall wakeup from sleep
  • call nrf_pwr_mgmt_run() within the main loop.
Is this approach reasonable?
Thanks in advance for any help.
Cheers David
