We are using the nRF Connect SDK and building a Zephyr standalone application. Is there a way to add a post build step to the application CMakeLists.txt file which will run AFTER the zephyr.hex is generated?
Thanks.
Thanks.
Have you looked at extra_post_build_commands? That is the closest I can think of.
No, I have not looked into this. Are there any examples of using this with a Zephyr build?
There are quite a few example of it, I suggest you search for "extra_post_build_commands" in the SDK code base and look at some of the the CMakeLists.txt files that use it.
A more or less random example is from zephyr\boards\arm\faze\CMakeLists.txt:
set_property(GLOBAL APPEND PROPERTY extra_post_build_commands
# Insert checksum (verified by the bootloader) into the zephyr.bin
# and zephyr.hex images.
COMMAND lpc_checksum -f hex ${CMAKE_BINARY_DIR}/zephyr/${KERNEL_HEX_NAME}
COMMAND lpc_checksum -f bin ${CMAKE_BINARY_DIR}/zephyr/${KERNEL_BIN_NAME}
)Hi Einar,
Thank you for pointing me in the right direction. I'm not proficient in CMake so it's been a bit of a struggle. We have created a freestanding Zephyr project and have our own board file defined. In the CMakeLists.txt file in the board directory I added....
# Include post build instructions from build folder.
include(${APPLICATION_CONFIG_DIR}/postbuild.cmake)
Where APPLICATION_CONFIG_DIR is the folder where the application CMakeLists.txt file exists.
Then, in my application folder I created the postbuild.cmake file with the following contents...
set(CMAKE_SREC_TOOL "../../FileTools")
# Add post-build step after final zephyr application is created.
COMMAND "${APPLICATION_CONFIG_DIR}/../createappbin.bat" "${CMAKE_SREC_TOOL}"
This runs AFTER the final zephyr elf file is created. Putting the post build commands in a separate cmake file provides the flexibility of customizing the post build steps by application, not by board.
