I have a Thingy91 that I want to connect to nRFcloud. Not knowing the state of its keys/provisioning I followed the procedure to generate just-in-time keys (as a first attempt).
I cleared the existing keys, generated keys using AT%KEYGEN, parsed the CBOR object into a CSR, created a Device Certificate and provisioned the device with nRFcloud. I then used Link Monitor to load my own CA and the Amazon CA1 certificate into the modem (presumably the private key was stored when it was created?)
I then attempted to submit the public key to nRFcloud using this command:
curl-X POSThttps://api.nrfcloud.com/v1/devices/public-keys--data-binary \src\keys\register.csv-H"Content-Type: application/octet-stream"-H"Authorization: Bearer 3e....8f"
with this in register.csv:
nrf-351358811472304,"-----BEGIN PUBLIC KEY-----
MFkwEwYHKoZIzj0CAQYIKoZIzj0DAQcDQgAE1NdDa66VcX1JBQ7sxDN98blYNQ3C
akfeB9B8Zpjft11E8WDhztDmnVgectG6Lk6Dg1KGCiRwfIV0s5FBsbzb6g==
-----END PUBLIC KEY-----
This was rejected with this message:
{"message":"A total of 1 value(s) failed validation while processing the CSV [failed row indices (1-based)]: {\"DeviceId\":[1]}. See the API docs for this endpoint to find the regex patterns for proper validation.","code":42200,"helpUrl":"">api.nrfcloud.com/.../
I can't see what's wrong though, can you advise please?
I've obfuscated by API key, but the content of register.csv is verbatim.
Frog
