nRF Connect for VSCode Task SoftReset Option Has No Effect
I am using nRF Connect for VSCode (v2022.7.242) and discovered that the softreset option for a task has no effect.
Task:
	"type": "nrf-connect-flash",
	"config": "${workspaceFolder}/build",
	"erase": false,
	"recover": false,
	"softreset": true,
	"problemMatcher": [],
	"label": "Flash Target",
	"dependsOn": "Build Target"
Output:
Flashing build to undefined
west flash -d /home/ee/proj/build --skip-rebuild -r nrfjprog --dev-id 821006534
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: /home/ee/proj/build/zephyr/zephyr.hex
Parsing image file.
Verifying programming.
Verified OK.
Enabling pin reset.
Applying pin reset.
-- runners.nrfjprog: Board with serial number 821006534 flashed successfully.
As you can see it is no adding the "--softreset" flag.
This is not the case when the softreset application setting is set to true and I use the nrf Connect Flash button. In this case it works correctly:
west flash -d /home/ee/proj/build --skip-rebuild -r nrfjprog --dev-id 821006534 --softreset
Parsing image file.
Verified OK.
Applying system reset.
Run.
I assume this is a bug or have I configured something wrong?
