LTE_BLE_Gateway read and write in characteristic
I would like to know if it is possible to provide an example based on the lte_ble_gateway sample for writing and reading the characteristic!
I changed the example and I'm connecting with an nRF52840, but I'm not able to write or read the characteristics.
I noticed that many people also have difficulty in incrementing this in the example, so I think it would be very useful if they could demonstrate this in an example, most topics about this tell the user to base themselves on the nus_client example, but it's not that trivial, the code bases are very different and even based on this code I could not implement it successfully.
The tutorial in the link below demonstrates very well how to perform this implementation based on NUS, but I find a lot of incompatibility when I try to implement the functionality described in the tutorial for the lte_ble_gateway sample. Is it possible to implement this functionality in the sample? Could you give a very brief example of writing and reading the characteristics?
 Building a Bluetooth application on nRF Connect SDK - Contrasting to SoftDevice - Part 2 Central role
I'm using NCS 2.0.0 and nRF9160DK!
Thank you.
    Perfect, I'm looking forward to it!
    Thank you.
  • Hi
    I was able to replace the Thingy client with the NUS client in the example, and I shared the code here
    The main application is more or less unchanged, I just added a bit of code to log any incoming NUS messages, and echo a reply back to the NUS peripheral whenever it sends a packet.
    As you can see I added a callback function to the ble_init function that will be used to handle incoming messages, and added a ble_data_send(..) function that you can use to send packets over NUS.
    The example has been through limited testing, and could benefit from some additional improvements (like a FIFO to store incoming and outgoing data), but hopefully it can prove useful for you to get started.
    Best regards
    Torbjørn
    Thank's for your time, but unfortunately this example does not allow me to advance anything! It's working basically the same as the modified example of lte_ble_gateway that I sent here... It works well to connect with a uart peripheral, I even managed to send something through ble to the peripheral, but I couldn't read the values ​​of the characteristics and no return on changing these. And it is also not possible to send any command via terminal to the nRF9160 so that this command is sent by the BLE, always get ERROR, exactly the same behavior I had when using the service filter in my code.
    But as you can see from the beginning of the ticket, I need to filter by address to connect to a specific device! And when I change the filter in your code, I find exactly the errors I found in my firmware, duplicate connection attempts, one fails and the other connects.
    [00:00:00.509,918] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.510,131] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:01.225,097] <wrn> bt_hci_core: opcode 0x0000 pool id 3 pool 0x20015268 != &hci_cmd_pool 0x200152d0
    [00:00:01.326,385] <inf> lte_ble_gw: Bluetooth ready
    [00:00:01.326,385] <inf> lte_ble_gw: NUS Client module initialized
    [00:00:01.339,874] <inf> lte_ble_gw: Scanning...
    [00:00:05.879,119] <inf> lte_ble_gw: Device found: 38:31:AC:02:50:0D (public)
    [00:00:05.892,700] <inf> lte_ble_gw: Device found: 38:31:AC:02:50:0D (public)
    [00:00:05.892,700] <err> lte_ble_gw: Connection to peer failed!
    [00:00:06.070,343] <inf> lte_ble_gw: Connected: 38:31:AC:02:50:0D (public)
    [00:00:06.271,514] <inf> lte_ble_gw: MTU exchange done
  • After some time working on the code I managed to evolve a little... The errors mentioned were not resolved, but even with them I was able to send data to the peripheral, filtering by address!
    But I couldn't use the function you created "ble_data_sent", it is not implemented right? Now using the ble_send_data function I managed to send the data, but when my peripheral responds I can't get the data and it goes into an infinite loop, although the peripheral only sent the data once, it seems that the on_ble_received function is called at fixed intervals indefinitely.
    [00:00:06.102,966] <inf> lte_ble_gw: Device found: 38:31:AC:02:50:0D (public)
    [00:00:06.117,919] <inf> lte_ble_gw: Device found: 38:31:AC:02:50:0D (public)
    [00:00:06.117,919] <err> lte_ble_gw: Connection to peer failed!
    [00:00:06.291,320] <inf> lte_ble_gw: Connected: 38:31:AC:02:50:0D (public)
    [00:00:06.492,492] <inf> lte_ble_gw: MTU exchange done
    [00:00:07.642,395] <inf> lte_ble_gw: Service discovery completed
    [00:00:07.642,578] <inf> lte_ble_gw: Enviar dado
    [00:00:07.844,848] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:07.944,854] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.044,799] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.144,866] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.244,842] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.344,879] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.444,885] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.544,891] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.644,866] <inf> lte_ble_gw: Data received (3 bytes):
    [00:00:08.744,934] <inf> lte_ble_gw: Data received (3 bytes):
  • Hi
    The ble_send_data(..) function is implemented, yes, but I recommend only calling it from a thread or work item, not from an interrupt.
    The way my example is set up it will send the string "Packet received!" as a response every time it receives a packet from the connected peripheral. If you connect using a standard peripheral_uart device all you need to do is to wait for the devices to connect, send anything from the peripheral side (remember to press enter at the end of your message), and see if the "Packet received!" message appears on the peripheral_uart side. Are you saying this will not work?
    Best regards
    Torbjørn
