SHARP Memory Display Breakout - 2.7" 400x240 with nrf52840
I want to use SHARP Memory Display Breakout - 2.7" 400x240 with nrf52840 development kit. I have to interface the lvgl library for the graphics development but from the documentation, I could not figure out how to connect and there is no basic code for interfacing with the nordic SDK. Please suggest any type of reference for examples if available.
Any kind of input or help will be appreciated.
Thanks in Advance,
  • Hi Muhammad,
    At least your output shows that you are now compiling with nRF Connect SDK v2.1.0.
    In the .overlay I provided I accidentally entered default two times(or was it sleep two times). This should be corrected so that the pins are defined for both sleep and default:
    	spi3_default: spi3_default {
    		group1 {
    			psels = <NRF_PSEL(SPIM_SCK, 1, 15)>,
    				<NRF_PSEL(SPIM_MISO, 1, 14)>,
    				<NRF_PSEL(SPIM_MOSI, 1, 13)>;
    	spi3_sleep: spi3_sleep {
    		group1 {
    			low-power-enable;
    Hopefully, you should now be able to compile the project.
    I have not confirmed whether the overlay will work. It probably only configures the part covered by Pin Control correctly. Some work is needed in order to get the rest of the pins work correctly. I will get back to you over the weekend.
    Thanks for the information. I have compiled the sample you provided successfully and I have found some results which I want to share as these are not satisfactory at this moment but I think we are now close.
    The pin mapping on the DK was showing following data on the IDE
    Then I have made changes in the spi pin number based on the above the spi3 has 0.14 and 0.15 pins for miso and sck.
    The edited code shown below.
    	spi3_default: &spi3_default {
    		group1 {
    			psels = <NRF_PSEL(SPIM_SCK, 0, 15)>,
    				<NRF_PSEL(SPIM_MISO, 0, 14)>,
    				<NRF_PSEL(SPIM_MOSI, 0, 13)>;
    	spi3_sleep: &spi3_sleep {
    		group1 {
    			low-power-enable;
    After that, I found the following results on the screen.
    As you can see some number is also shown on the screen and that was updated with time.
    Also, I have connected the rest of the pins as you suggested above. Are there any changes in the pin number which we should make to get a good response?
    What are your suggestions at this stage?
    Do we need to make any changes at this section of the code for the pins to be changed as maybe from the pin mapping picture above you can see pins that are under use and which are free.
        arduino_spi: &spi3 {
            status = "okay";
            cs-gpios = <&arduino_header 16 GPIO_ACTIVE_HIGH>; /* D10 */
            //pinctrl-0 = < &spi3_default >;
            //pinctrl-1 = < &spi3_sleep >;
            //pinctrl-names = "default", "sleep";
            ls0xx: ls0xx@0 {
                compatible = "sharp,ls0xx";
                label = "LS0XX";
                spi-max-frequency = <2000000>;
                reg = <0>;
                width = <400>;
                height = <240>;
                extcomin-gpios = <&arduino_header 14 GPIO_ACTIVE_HIGH>; /* D8 */
                extcomin-frequency = <60>; /* required if extcomin-gpios is defined */
                disp-en-gpios = <&arduino_header 12 GPIO_ACTIVE_HIGH>; /* D6 */
    Thanks for all the support.
  • Thank you for the update and photos. It looks like you are getting closer.
    Could you please upload the project files that caused the output seen in the images?
    Yes, it is your sample as you shared above, I think there were minute changes, I am sharing the version which caused the above output.
    lvgl_sharp_20221011.zip
  • Thank you for uploading.
    I spotted some other mistakes in the initial suggested pins. (I apologize for the mistake. Please note that the initial suggestions were only meant as a mock up example, demonstrating syntax and how to select pins and making use of Pin control.)
    For example, the following code from the overlay translates to P1.12(not P0.16 as I wrote by mistake):
    Here is the corrected table:
    Display module pin name nRF52840 pin name Arduino header Comment
    EXTIN P1.04 D3 (Old pin: P0.14)
    DISP P1.05 D4 (Old pin: P0.12)
    EXTMD 'GND' or 'VDD' I assume this is for toggling display inversion.
    CS
    P1.12 D10 (Old pin: P0.16)
    MOSI
    P1.13 D11 Recommend to use P1.13 or another pin as P0.13 may interfere with the LEDs.
    SCLK P1.15 D13 Recommend to use P1.15 or another pin as P0.15 may interfere with the LEDs.
    GND 'GND'
    3V3 'Vin 3-5V' The DK adjusts the IO voltage according to the voltage provided at the 'Vin 3-5V' pin
    VIN (3.3V-5V) '5V' The DK now supplies the display module with 5V
    P1.14 (MISO) D12 MISO not used by display module. Recommended to use P1.14 or another pin as P1.14 may interfere with the LEDs.
    The pins are updated according to the Arduino header definitions in the board files( nrf52840_nrf52840.dts):
    	arduino_header: connector {
    		compatible = "arduino-header-r3";
    		#gpio-cells = <2>;
    		gpio-map-mask = <0xffffffff 0xffffffc0>;
    		gpio-map-pass-thru = <0 0x3f>;
    		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
    			   <1 0 &gpio0 4 0>,	/* A1 */
    			   <2 0 &gpio0 28 0>,	/* A2 */
    			   <3 0 &gpio0 29 0>,	/* A3 */
    			   <4 0 &gpio0 30 0>,	/* A4 */
    			   <5 0 &gpio0 31 0>,	/* A5 */
    			   <6 0 &gpio1 1 0>,	/* D0 */
    			   <7 0 &gpio1 2 0>,	/* D1 */
    			   <8 0 &gpio1 3 0>,	/* D2 */
    			   <9 0 &gpio1 4 0>,	/* D3 */
    			   <10 0 &gpio1 5 0>,	/* D4 */
    			   <11 0 &gpio1 6 0>,	/* D5 */
    			   <12 0 &gpio1 7 0>,	/* D6 */
    			   <13 0 &gpio1 8 0>,	/* D7 */
    			   <14 0 &gpio1 10 0>,	/* D8 */
    			   <15 0 &gpio1 11 0>,	/* D9 */
    			   <16 0 &gpio1 12 0>,	/* D10 */
    			   <17 0 &gpio1 13 0>,	/* D11 */
    			   <18 0 &gpio1 14 0>,	/* D12 */
    			   <19 0 &gpio1 15 0>,	/* D13 */
    			   <20 0 &gpio0 26 0>,	/* D14 */
    			   <21 0 &gpio0 27 0>;	/* D15 */
