How to set up LTE in nRF9160 based board with Hologram SIM Card in Colombia
Hey guys, I'm an embedded software engineer and I am currently working in a prototype, specifically using the Circuitdojo Feather nRF9160, I am also using a Hologram International IoT SIM Card that according to the coverage map Colombia is a country supported and I can see that Colombia is a region that supports 3 different mobile carriers with Hologram.
I am currently testing the `at_client` sample but after playing around with the LTE Link Monitor from nRF Connect for Desktop, I have been unable to get internet access in the nRF9160 microcontroller.
The only steps that I have entered in the LTE Link Monitor are the following:
AT+CFUN?
+CFUN: 0
OK
AT+CFUN?
+CFUN: 0
OK
AT+CFUN=1
OK
AT+CFUN?
+CFUN: 1
OK
AT+CGSN=1+CGSN: "352656103797646"
OK
AT+CGMINordic Semiconductor ASA
OK
AT+CGMMnRF9160-SICA
OK
AT+CGMRmfw_nrf9160_1.2.3
OK
AT+CEMODE?
+CEMODE: 2
OK
AT%XCBAND=?%XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)
OK
AT+CMEE?
+CMEE: 0
OK
AT+CMEE=1
OK
AT+CNEC?
+CNEC: 0
OK
AT+CNEC=24
OK
AT+CGEREP?
+CGEREP: 0,0
OK
AT+CGDCONT?
+CGDCONT: 0,"IP","hologram","",0,0
OK
AT+CGACT?
+CGACT: 0,0
OK
AT+CGEREP=1
OK
AT+CIND=1,1,1
OK
AT+CEREG=5
OK
AT+CEREG?
+CEREG: 5,4,"FFFE","FFFFFFFF",7,0,0,"00000000","00000000"
OK
AT%CESQ=1
OK
AT+CESQ+CESQ: 99,99,255,255,255,255
OK
AT%XSIM=1
OK
AT%XSIM?%XSIM: 1
OK
AT+CPIN?
+CPIN: READY
OK
AT+CPINR="SIM PIN"+CPINR: "SIM PIN",3
OK
AT+CIMI234500007896034OK+CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"AT+CEREG?
+CEREG: 5,2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"
OK
AT+CEREG?
+CEREG: 5,2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"OK
Here's my prj.conf file
# Copyright (c) 2019 Nordic Semiconductor ASA
# General config
CONFIG_ASSERT=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# Modem library
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y
# AT host library
CONFIG_AT_HOST_LIBRARY=y
# Stacks and heaps
CONFIG_MAIN_STACK_SIZE=3072
CONFIG_HEAP_MEM_POOL_SIZE=16384
# Bootloader
CONFIG_BOOTLOADER_MCUBOOT=y
#The correct APN settings are as follows (I took this from hologram's documentation):
# APN: hologram
# APN username: (none)
# APN password: (none)
# IP Address: Dynamic (using DHCP)
# Data Roaming: Enabled
# Set the PDP context
CONFIG_PDN=y
CONFIG_PDN_DEFAULTS_OVERRIDE=y
CONFIG_PDN_SYS_INIT=y
# Note: "ip" is set by PDN_DEFAULT_FAM kconfig's
# example:
# AT+CGDCONT=1,"ip","apn" - below only sets APN field
CONFIG_PDN_DEFAULT_APN="hologram"
# CONFIG_PDN_DEFAULT_FAM_IPV4V6=y
# CONFIG_PDN_DEFAULT_FAM_IPV4=y
And I created this Kconfig file
config PDN_DEFAULT_FAM
	default 0   # set to "IP"
source "Kconfig.zephyr"
Having this documentation in mind, what's necessary to set up the mobile network in case that I need to do it manually in my nRF9160? Do I need to test with a different APN parameter? Like from Tigo, Claro, Movistar?
Thanks for your time.
