Hi there,
I'm developing with the nRF52832 right now.
I want to communicate nrf52832 (as master) with MP2723 to read and write data with TWI.
Hi there,
Here's the functional description of the hardware:
You can use either of these two drivers:
http://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/hardware/peripherals/i2c.html
http://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfx/drivers/twi/driver.html
okay.
I've tried the twi example of sdk but I'am facing issue to read the register data.
Then please explain the issues you are facing.
#include <stdio.h> #include "boards.h" #include "app_util_platform.h" #include "app_error.h" #include "pca10040.h" #include "nrf_drv_twi.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" /* TWI instance ID. */ #define TWI_INSTANCE_ID 0 // create a ID constant // create a handle which will point to TWI instance, in this case its TWI_0 static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID); // a function to initialize the twi(i2c) void twi_init(void) { ret_code_t err_code; // a variable to hold error code // Create a struct with configurations and pass the values to these configurations. const nrf_drv_twi_config_t twi_config = { .scl = ARDUINO_SCL_PIN, // P0.27 .sda = ARDUINO_SDA_PIN, // P0.26 .frequency = NRF_DRV_TWI_FREQ_100K, // set the communication speed to 100K, we can select 250k or 400k as well .interrupt_priority = APP_IRQ_PRIORITY_HIGH, // Interrupt priority is set to high, keep in mind to change it if you are using a soft-device .clear_bus_init = false // automatic bus clearing }; err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL); // initialize the twi APP_ERROR_CHECK(err_code); // check if any error occured during initialization nrf_drv_twi_enable(&m_twi); // enable the twi comm so that its ready to communicate with the MP2723 } /** * @brief Function for main application entry. */ int main(void) { ret_code_t err_code; // a variable to hold error code value uint8_t address = 0x4b; // address of the MP2723 uint8_t sample_data = 0x00; // sample data initialized with 0 value. // initialize the Logger so that we can print msgs on the logger APP_ERROR_CHECK(NRF_LOG_INIT(NULL)); NRF_LOG_DEFAULT_BACKENDS_INIT(); NRF_LOG_INFO("Application Started"); NRF_LOG_FLUSH(); // flushing is necessary if deferred is set to 1(check this video tutorial to know it better) twi_init(); // call the twi initialization function // read some data from the sensor err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data)); if(err_code == NRF_SUCCESS) // if reading data was successful { NRF_LOG_INFO("Successfully detected a device at address: 0x%x", address); // let the users know its working } NRF_LOG_FLUSH(); // flushing is important, if you set the deffered to 1, if deffered is set to 0 then we don't need to flush the log buffer. while (true) { /* Empty loop. */ } }
I've attached the sample code.
I want to implement -
1) Read the Register of MP2723 and get register value (whatever it is) in terminal.
2) Write - to make changes and get that value in terminal.
Ok, that's what you want to do, but what is your issue? What isn't working as expected?
