nrfjprog program every second time didn't start the application
Hi
When I use the nrfjprog with the command line:
nrfjprog --recover
nrfjprog --eraseall
nrfjprog --program testcode.hex
nrfjprog --rbp ALL
The application is starting and the code running.
If I do the same again (with the same hex or a newer one) the nrf remains in the bootloader.
The only solution is to do it again, every second time this bug is happening, why? What is the solution for this?
Regards, Dominik
  • this code works now:
    @ECHO off
    REM nrfjprog --log
    set "HEX_FILE=testfile.hex"
    echo **********************************************************************
    echo "Recover and disable the read back protection"
    nrfjprog --recover
    echo "%HEX_FILE%"
    echo "Program and reset the Device
    nrfjprog --reset --program %HEX_FILE%
    echo "Verify the device
    nrfjprog --verify --fast %HEX_FILE%
    echo "enable the readback protection"
    nrfjprog --rbp ALL
    pause
