MCUBoot: adding custom serial flash driver as secondary partition
We use spi flash with custom driver and goal is to set it to act as secondary partition for MCUBoot.
The question is how to adapt driver to be accepted by MCUBoot, maybe there is an example on how driver should look like?
As far as I understand Nordic supports mx25r64, what files have to be produced and where to place them to enable custom driver to be accepted by MCUBoot?
  • If this is not preferable, let me know, and I can look into do this out-of-tree.
    Many thanks for fast response.
    Yes, I think it would be better to have out-of-tree solution.
  • Try adding the binding to your board folder like it's done here (<board>/dts/bindings): https://github.com/nrfconnect/sdk-nrf/tree/v2.0.2/boards/arm/thingy91_nrf9160/dts/bindings.
    Regarding adding your driver out-of-tree, I'm not sure if it will work by simply following this approach: https://github.com/nrfconnect/sdk-zephyr/tree/v3.0.99-ncs1/samples/application_development/out_of_tree_driver, since your driver should not be used directly, but rather through the flash.h API. The other flash drivers are put in https://github.com/nrfconnect/sdk-zephyr/tree/v3.0.99-ncs1/drivers/flash.
    I'll ask internally tomorrow how to go about this.
    I realized that it might be possible that the spi_nor driver actually supports the at25xe081, I'll look into this as well.
  • Is it possible to run debugger in bootloader (using VS Code) ?
    I managed to build the project, however get the following error from the bootloader:
    *** Booting Zephyr OS build v2.7.0-ncs1  ***
    00> I: Starting bootloader
    00> W: Failed reading sectors; BOOT_MAX_IMG_SECTORS=128 - too small?
    00> E: ***** MPU FAULT *****
    00> E:   Instruction Access Violation
    00> E: r0/a1:  0x00000000  r1/a2:  0x00000000  r2/a3:  0x20000284
    00> E: r3/a4:  0x00000020 r12/ip:  0xe6f7fbb5 r14/lr:  0x00000e4f
    00> E:  xpsr:  0x61000000
    00> E: Faulting instruction address (r15/pc): 0xe6f7fbb4
    00> E: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
    00> E: Current thread: 0x20000128 (unknown)
    00> E: Resetting system
    And this is my pm_static.yml:
    external_flash:
      address: 0x0
      region: external_flash
    app:
      address: 0xc200
      end_address: 0x6DC80
      region: flash_primary
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
      placement:
        align:
          start: 0x1000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - mcuboot_pad
      - app
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0xc200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x0
      device: at25xe081
      end_address: 0x6DE80
    settings_storage:
      address: 0x7e000
      end_address: 0x80000
      placement:
        before:
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x20010000
      region: sram_primary
  • I just talked to a colleague familiar with this stuff, and asked if at25xe081 was supported by the spi_nor driver. He said as far as he knew, most of the NOR chips should be supported by the spi_nor driver, and most of the commands from the data sheets seems to be generic, so it should not be a problem as far as he knew.
    To get more details, and a more certain answer, try to ask the Zephyr experts on Zephyr Discord, if at25xe081 is supported by the spi_nor driver (Maybe add a link to the data sheet). If that is the case, you may save a lot of time.
    Simon
  • Thank you for information, Simon.
    Maybe you can also provide a hint on how to debug the bootloader?
