MPSL_TIMESLOT_SIGNAL_RADIO doesn't hit
I'm using nRF Connect SDK v2.0.2 (in VSCode, w/ the plugin) on nRF52840-DKs.
Following the MPSL Timeslot sample, in the code shown below, I created a non-preemptible thread that periodically requests a single timeslot.
In the mpsl_timeslot_callback(), the MPSL_TIMESLOT_SIGNAL_START and MPSL_TIMESLOT_SIGNAL_TIMER0 events occur as expected, but the MPSL_TIMESLOT_SIGNAL_RADIO case never happens. Why not? How can I make that happen?
#define TIMESLOT_REQUEST_PERIOD_ms  (250)
/* Timeslot requests */
static mpsl_timeslot_request_t timeslot_request_earliest =
	.request_type             = MPSL_TIMESLOT_REQ_TYPE_EARLIEST,
	.params.earliest.hfclk    = MPSL_TIMESLOT_HFCLK_CFG_NO_GUARANTEE, //TODO: OK?
	.params.earliest.priority = MPSL_TIMESLOT_PRIORITY_HIGH,
	.params.earliest.length_us  = TIMESLOT_LENGTH_US,
	.params.earliest.timeout_us = TIMESLOT_TIMEOUT_US,
static mpsl_timeslot_signal_return_param_t signal_callback_return_param;
static mpsl_timeslot_signal_return_param_t *mpsl_timeslot_callback(
	mpsl_timeslot_session_id_t session_id,
	uint32_t signal_type)
	(void) session_id; /* unused parameter */
	mpsl_timeslot_signal_return_param_t *p_ret_val = NULL;
	switch (signal_type)
		case MPSL_TIMESLOT_SIGNAL_RADIO:
			//NB: this doesn't hit...
		case MPSL_TIMESLOT_SIGNAL_START:
			// this hits
			/* No return action */
			signal_callback_return_param.callback_action =
				MPSL_TIMESLOT_SIGNAL_ACTION_NONE;
			p_ret_val = &signal_callback_return_param;
			/* Setup timer to trigger an interrupt (and thus the TIMER0
			* signal) before timeslot end.
			nrf_timer_cc_set(NRF_TIMER0, NRF_TIMER_CC_CHANNEL0,
				TIMER_EXPIRY_US);
			nrf_timer_int_enable(NRF_TIMER0, NRF_TIMER_INT_COMPARE0_MASK);
		case MPSL_TIMESLOT_SIGNAL_TIMER0:
			// this hits
			/* Clear event */
			nrf_timer_int_disable(NRF_TIMER0, NRF_TIMER_INT_COMPARE0_MASK);
			nrf_timer_event_clear(NRF_TIMER0, NRF_TIMER_EVENT_COMPARE0);
			/* Timeslot will be ended */
				//MPSL_TIMESLOT_SIGNAL_ACTION_END;
		case MPSL_TIMESLOT_SIGNAL_SESSION_IDLE:
		case MPSL_TIMESLOT_SIGNAL_SESSION_CLOSED:
		// case MPSL_TIMESLOT_SIGNAL_BLOCKED:
		// case SIGNAL_CODE_BLOCKED_CANCELLED:
			printk("ERR: unexpected signal: %u\n", signal_type);
			k_oops();
	return p_ret_val;
/* To ensure thread safe operation, call all MPSL APIs from a non-preemptible
 * thread.
static void mpsl_nonpreemptible_thread(void)
	// Open timeslot session, and make periodic timeslot request
	//  (every TIMESLOT_REQUEST_PERIOD_ms)
	int err;
	/* Initialize to invalid session id */
	mpsl_timeslot_session_id_t session_id = 0xFFu;
	err = mpsl_timeslot_session_open(mpsl_timeslot_callback, &session_id);
	if (err) {
		printk("ERR: Timeslot session open error: %d\n", err);
		k_oops();
		while (1)
			osDelay(TIMESLOT_REQUEST_PERIOD_ms);
			err = mpsl_timeslot_request(session_id, &timeslot_request_earliest);
			if (err)
				printk("ERR: Timeslot request error: %d\n", err);
				k_oops();
K_THREAD_DEFINE(mpsl_nonpreemptible_thread_id, STACKSIZE,
		mpsl_nonpreemptible_thread, NULL, NULL, NULL,
		K_PRIO_COOP(MPSL_THREAD_PRIO), 0, 0);
void main(void)
    // do some BLE stuff...
Things I tried, which made no difference:
1. I've tried adding
	nrf_radio_int_enable(NRF_RADIO,
		(NRF_RADIO_INT_CCABUSY_MASK |
		 NRF_RADIO_INT_CCAIDLE_MASK));
in main(), (and I used nrf_radio_int_enable_check() to ensure it set the bits).
2. I also tried using mpsl_radio_notification_cfg_set() such as shown below.
// Following comments from
//  https://github.com/inductivekickback/ncs_ble_esb_demo
// which I used as a sample. Unsure if it still applies.
 * An interrupt vector to use with the Radio Notification feature as well as lowering the
 * priority of the MPSL callback (Zero Latency IRQ workaround). As of NCS v1.6 this doesn't
 * handle MPSL_TIMESLOT_SIGNAL_TIMER0 signals correctly unless it uses priority MPSL_LOW_PRIO
 * or higher.
#define RADIO_IRQN          QDEC_IRQn
#define RADIO_IRQ_NODELABEL qdec
//#define RADIO_IRQN          RADIO_IRQn
//#define RADIO_IRQ_NODELABEL radio
#define RADIO_IRQ_PRIO      4
static void radio_notify_cb(const void *context);
static void setup_radio_notification(void)
	IRQ_CONNECT(DT_IRQN(DT_NODELABEL(RADIO_IRQ_NODELABEL)), RADIO_IRQ_PRIO,
		radio_notify_cb, NULL, 0);
	irq_enable(DT_IRQN(DT_NODELABEL(RADIO_IRQ_NODELABEL)));
	int32_t err = mpsl_radio_notification_cfg_set(MPSL_RADIO_NOTIFICATION_TYPE_INT_ON_ACTIVE,
		MPSL_RADIO_NOTIFICATION_DISTANCE_200US,
		RADIO_IRQN);
	if (err)
		printk("ERR: mpsl_radio_notification_cfg_set() returned %i\n", err);
	// this doesn't hit either
    This signal indicates the RADIO interrupt. If you are not using the radio in the timeslot, I don't see why it's should trigger
  • If you are not using the radio in the timeslot, I don't see why it's should trigger
    Well that makes sense for the MPSL_TIMESLOT_SIGNAL_RADIO case in the mpsl_timeslot_callback. But what I really want is to have a callback that shows me ALL radio activity, like the last code excerpt in my OP does when I'm not using timeslots. Is there a way to achieve this while using timeslots?
    Then it makes more sense to use radio notifications, instead of timeslots.
    Here is some code snippet I used a some months ago when I tested radio notifications. If you add this to e.g. a Bluetooth sample, it should trigger after you e.g. start Bluetooth advertising.
    #include <mpsl_radio_notification.h>
    #include <mpsl.h>
    void radio_handler(const void *context)
    	LOG_INF("radio_handler");
    void setup_radio_notification(const void *context)
    	err = mpsl_radio_notification_cfg_set(MPSL_RADIO_NOTIFICATION_TYPE_INT_ON_ACTIVE,MPSL_RADIO_NOTIFICATION_DISTANCE_5500US,SWI1_IRQn);
    	if (err) {
    		LOG_INF("mpsl_radio_notification_cfg_set failed (err %d)\n", err);
    		return;
    	IRQ_CONNECT(SWI1_IRQn, 7,
    		radio_handler, NULL, 0);
    	irq_enable(SWI1_IRQn);
  • Then it makes more sense to use radio notifications, instead of timeslots.
    I need the timeslots so I can guarantee the radio is not in use for some small periods of time.
    How can I have both the radio notifications (for all activity, or just outside of timeslots) and timeslots? I tried adding your code snippet to mine, but it doesn't hit the radio_handler().
    (EDIT: I removed the unused param from the setup_radio_notification(), and reduced the interrupt priority from 7 to 4 to resolve a compiler error.)
    It works as expected here.
    Where are calling setup_radio_notification? Could you post your main.c file ?
